土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 公寓立面:随观看角度变化而变化
公寓立面:随观看角度变化而变化
发布于:2022-09-08 11:41:08 来自:建筑结构/混凝土结构 [复制转发]
Harmonia 1250为新一代的混合用途建筑打下了基础,在建筑中设计了商店、办公室和公寓的垂直项目,以应对房地产市场的标准化简化。
Foreshadowing a new generation of mixed-use buildings, Harmonia 1250 proposes a vertical program of stores, offices, and apartments in a building designed in reaction to the standardized simplification practiced by the real estate market.
其不规则形状的土地由几个预先存在的小地块组成,激发了建造一座建筑的灵感,该建筑有两个突出的末端,由一个细长的主体连接起来,就像一条人行道,将两侧连接到一个垂直流通的中心区域。
Its irregularly shaped land, composed of several small pre-existing lots, inspired the creation of a building with two protruding ends joined by an elongated body that works like a walkway, connecting both sides to a central area with vertical circulation.
基于地形及其高度测量的特殊性,对建筑基本元素的体积重新排列,产生了具有多种视图和方向的建筑,与土壤、植被和公共空间建立了流动而复杂的关系。因此,Harmonia 1250 具有不同的外观,这取决于观察它的角度。该建筑拥有商店、办公室和住宅公寓的垂直项目,预示着圣保罗新一代的多功能建筑。Harmonia 1250 位于同名地址,构成了繁华的 Vila Madalena 社区的天际线。
The volumetric rearrangement of essential elements of architecture, based on the specificities of the terrain and its altimetry, gave rise to a building with multiple views and orientations that establishes a fluid and intricate relationship with the soil, vegetation, and public spaces. As a result, Harmonia 1250 has different appearances, which vary depending on the point of view from which it is viewed. The building hosts a vertical program of stores, offices, and residential apartments that foreshadow a new generation of mixed-use buildings in S?o Paulo. Located at the address of the same name, the Harmonia 1250 composes the skyline of the bustling Vila Madalena neighborhood.
它的底层在视觉上是通透的,就像一个活跃的立面,有几个通道穿过。在所有楼层,内部空间直接连续地延伸到外部,提供了城市非凡的城市全景。
Its ground floor is visually permeable and behaves like an active fa?ade crossed by several accesses. On all floors, the internal spaces extend to the outside in direct continuity, offering a view of the extraordinary urban panorama of the city.
事实上,它的办公室立面是由金属遮阳板和植物层保护的梯田,形成一层覆盖和保护建筑物的表皮,同时保持其“透气”并向城市开放。放置在立面上的花盆由集成滴灌系统灌溉,旨在确保低耗水量。用于住宅用途的较高楼层具有不同的物质性,证明了混合项目的存在。
Its office fa?ades are, in fact, terraces protected by metallic brise soleils and a vegetal layer, forming a skin that covers and protects the building while keeping it "breathable" and open to the city. The plant pots placed on the fa?ades are irrigated by an integrated drip system, designed to ensure low water consumption. The upper floors, intended for residential use, have different materiality, evidencing the existence of a mixed program.
平面图
立面图
建筑师:Triptyque
地点:巴西
面积:11173平方米
年份:2020
140.17 万条内容 · 2232 人订阅
未来校园:解决高容积率中,大空间功能的布置,干净纯粹的外观效果
深圳市红山中学 华阳国际 ? 行知影像-李逸 ? 行知影像-李逸 当下高密度城市环境,在高效运作的教学空间之外,未来校园应该是什么模样?深圳市红山中学,把连接性、社交性、地域性作为设计核心要素,凭借设计的创意和张力打造一系列生动空间,让同学们在探索式、漫游式校园中成为更好的自己。
