土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 疫情这两年,文体运动中心的设计,有什么样的变化?
发布于:2022-09-08 11:35:08 来自:建筑结构/混凝土结构 [复制转发]
文体运动中心,贯彻健康日常
VCS体育建筑
文体运动在发生
什么样的变化?
随着疫情生活常态化,普通人日常生活对运动和积极生活的欣赏,逐渐内化。体育设施的要求,也从单一独立的场所正向社区活动的公共中心转变。在过去20多年的事件中,VCS也一直亲历文体运动的转变,   可持续性一直存在于VenhoevenCS的DNA中,除了巴黎2024   水上运动中心外,VCS对不同类型的可持续体育场馆还做了许多探索与实践。
The normalization of life, the popularization of sports and social activities, the popularization of public-oriented activities, the popularization of social activities, and the enthusiasm of the masses. In addition to Paris April 4, 2024, VCS has also been conducting sports exploration and practice in various types of in-person museums in the Foreign Sports Center. Sustainabilityhas always existed in the DNA of VenhoevenCS. In addition to the Paris 2024Aquatic Center, VCS has also done a lot of exploration and practice ondifferent types of sustainable stadiums.
Blasio inflatables, 1998,  Netherlands Architecture Institute Rotterdam in collaboration with the Blasio Foundation
“可持续原则
的社区体现”
洛克伦体育中心
地点:比利时洛克伦
规模:4600 m2
客户:洛克伦市政厅
建筑师选择了可再生的天然和本地产品的材料,这些产品和材料不含化学品,并且易于适应或将来重复使用-例如木制屋顶结构和立面中的木材。高效的建筑能源技术和光伏电池板的屋顶使建筑的能耗降至最低,以可持续的方式与环境相适应,加强了建筑内外空间的联系,与建筑周围宜人的绿色空间形成公共整体。
The architects chose materials from renewable natural and local products that are free of chemicals and easy to adapt or reuse in the future - such as the wooden roof structure and the wood in the fa?ade. Efficient building energy technologies and a roof with photovoltaic panels minimize the energy consumption of the building, adapt to the environment in a sustainable way, strengthen the connection between the interior and exterior spaces of the building, and form a public whole with the pleasant green spaces surrounding the building.
餐厅和阳光明媚的露台加强了现有与新事物之间以及内部和外部之间的联系。前院在水平和游戏元素上存在差异,也邀请户外游戏和会议。建筑群周围以前支离破碎的空间将很快形成一个宜人的绿色和公共整体。因此,该公园可以在Lokerse Feesten期间完全使用,并将成为整个节日区域的一部分。
As a leading sports and exercise facility, Gymworld means an inspiring and sustainable environment for everyone. The sports center consists of several volumes, all of which are suspended from the ground. The composition is reminiscent of artificial clouds floating on land. Stairs and elevators protrude from the clouds, inviting visitors to enter.
?  Architecture: VenhoevenCS /B2Ai architects / Image: Joris Bourgeois
洛克里体育中心
地点:比利时奥蒂尼-鲁汶-新城
规模:5860 m2
客户:ARTES, Municipality of Ottignies-Louvain-la-Neuve
获奖:Gemma Smid Architecture Audience Award
Piscine de Blocry拥有奥林匹克规模的游泳池(50×25米),可容纳各种运动的全国比赛,如长距离游泳,花样游泳和水球,将成为瓦隆最大的游泳池之一。然而,建筑体积非常紧凑。这可以最大限度地保护现有的树木和其他植被 - 因为该建筑位于拥有丰富和生物多样性森林的Natura 2000区旁边。
With an Olympic-sized swimming pool (50×25 m), accommodating national competitions for a diverse range of sports such as long-distance swimming, synchronized swimming and water polo, Piscine de Blocry will become one of the largest swimming pools in Wallonia. The building volume, however, is very compact. This allows for a maximum preservation of the existing trees and other vegetation – as the building is located next to a Natura 2000 zone with a rich and biodiverse forest. Simultaneously we were able to bring the use of energy to a minimum and reach the high energy performance ambitions.
建筑尊重周围特定的建筑环境,高度是适度的,立面覆层为精致的无烟煤色金属板。大型水平窗户突出了水平建筑的体积,这些窗户提供日光和绿色环境的全景。在室内,对比鲜明的颜色和材料有助于不同空间的表达和访客的取向。
Respecting the particular building context, the architecture is modest, with a fa?ade cladding of refined anthracite-coloured metal panels. The horizontal building volume is accentuated by large horizontal windows that provide daylight and panoramic views of the green surroundings. In the interior, contrasting colours and materials contribute to the articulation of different spaces and the orientation of visitors.
屋顶由木材建造而成,通过减少二氧化碳排放和长期储存二氧化碳,增加了建筑物的可持续性。其他可持续措施包括整合节能装置和完全覆盖建筑物屋顶的太阳能电池板。
The roof is constructed in wood, which adds to the building’s sustainability by reducing CO2 emissions and the long term storing of CO2. Other sustainable measures are the integration of energy efficient installations and solar panels fully covering the building’s roof.
? Architecture: VenhoevenCS /B2Ai architects/ Image: VenhoevenCS, B1 Design (renders)
Gymworld文化体育中心
地点:荷兰祖特尔梅尔
规模:5100 m2
客户:祖特尔梅尔市政厅
作为领先的体育和锻炼设施,Gymworld意味着为每个人提供一个鼓舞人心和可持续的环境。体育中心由几个体量组成,这些体量都悬挂在地面上。这种成分让人想起漂浮在陆地上的人造云。楼梯和电梯从云层中伸出,邀请游客进入。
Gymworld背后的设计灵感来自Constant Nieuwenhuys的艺术作品“New Babylon”。“New Babylon”是一系列相互联系的可变形结构,其中一些结构本身只有一个小城市的大小,漂浮在地面上。作为一种生活方式,它将主要回应对游戏,冒险,持续移动的需求,以及促进自由运动,自由奔跑和自由创造自己现实的条件。
The design behind Gymworld was inspired by the artwork "New Babylon" by Constant Nieuwenhuys. 'New Babylon' is a series of interconnected deformable structures, some of which themselves are the size of a small city, floating above the ground. As a way of life, it will primarily respond to the need for play, adventure, constant movement, and conditions that promote freedom of movement, freedom to run, and freedom to create one's own reality.
? Architecture: VenhoevenCS / Image: Photos by Ossip van Duivenbode and Marloes Koster
罗斯科体育中心
地点:     比利时罗斯科
规模:   3700 m2
客户:   Municipality of Ronse
Ronse的水上运动中心't Rosco是该市新的休闲景点。该综合体弥合了绿色和城市地区之间的过渡,是现有体育馆及其运动场的延伸。通过此扩展,在现有建筑和新游泳池的各种运动和使用选项之间建立了视觉和功能连接。
Aquatic centre ‘t Rosco in Ronse is the new recreational attraction of the city. The complex, bridging the transition between green and urban area, is an extension of the existing sports hall and its sports fields. With this extension, a visual and functional connection is made between the various sports and usage options of the existing building and the new swimming pool. Thus, ‘t Rosco transforms from sports hall to sports complex.
通过战略性地放置立面开口以及开放式和封闭式建筑之间的交替,日光从四面八方流入。各种不同的窗户开口确保了每种类型的使用都可以依靠最佳的日光量和透明度。玻璃开口也用于允许内部可见性和与外部世界接触。通过这种方式,透明度有助于建筑与环境之间的相互作用,并邀请路人进行锻炼。
With strategically placed fa?ade openings and an alternation between open and closed volumes, daylight flows in from all sides. An extensive range of different window openings ensures that every type of use can count on an optimal amount of daylight and transparency. Glass openings are also used to allow internal visibility and contact with the outside world. In this way, transparency contributes to the interaction between the building and the environment and invites passers-by to exercise.
? Architecture: VenhoevenCS /B2AI/ Image: Ossip van Duivenbode (photos); Mateja Pipan (photos)
该屋顶由层压木梁的正交网格构成。   1.75米×1.75米的网格不仅提供了结构,而且还有助于其他自由计划的组织顺序:   所有空间,   天窗和箱体体积都根据屋顶网格的尺寸量身定制。   根据活动的不同,房间可以断开连接或合并。   这种开放式结构在游泳池的开放式平面图和现有体育馆的隐蔽性之间提供了平衡。
This roof is constructed from an orthogonal grid of laminated wooden beams. The 1.75 m by 1.75 m grid not only provides structure, but also contributes to the organizational order of the otherwise free plan: all spaces, skylights and box volumes are tailored to the dimensions of the roof grid. Depending on the activities, rooms can be disconnected or merged. This open structure provides a balance between the open floor plan of the swimming pool and the seclusion of the existing sports hall.
“室内与室外共创
无限延展的文体公园”
普林纽斯休闲公园
地点:比利时通厄伦
规模:220000 m2
客户:NV Plinius
在前休闲公园的位置上,已经实现了新的城市公园。Plinius公园是通往Tongeren的新旅游入口,Tongeren是比利时最古老的城市,拥有高卢罗马和中世纪的过去。Plinius公园是该市的一片绿洲,拥有独特的氛围,指的是历史悠久的场地,设有一个用于娱乐目的的露天游泳池。
On the location of a former leisure park, a new city park has been realized. Plinius park is the new touristic entry to Tongeren, the eldest city of Belgium with a Gallo Roman and Medieval past. The Plinius park is a green oasis in the city with a characteristic atmosphere referring to the historic grounds, with an open air pool for recreation purposes.
古老的和仍然存在的贝托城堡为公园的设计树立了榜样,并树立了新的标志:凸起的游泳池位于山顶的平台,可以欣赏到景观的美景,指的是古老的城堡。普林纽斯泉水为公园内游泳池和池塘的水提供水源。
The old and still existing Beto castle sets an example for the design of the park and a new icon: the raised swimming pool is situated as a platform on top of the hill, offering a great view over the landscape, referring to the old castles. The Plinius spring feeds the water of the swimming pool and the pond in the park.
? Architecture: VenhoevenCS /Landscape architect: OKRA Landschapsarchitecten/ Image: Ossip van Duivenbode (photos)
为了将旧贝托城堡与“新城堡”(游泳池)连接起来,公园将Haspengouw景观与Tongeren的历史中心连接起来。它是许多旅游步行穿过Haspengouw和Tongeren景观的起点。
To link the old Beto castle with the ‘new castle’, the swimming pool, the park connects the Haspengouw landscape with the historic centre of Tongeren. It is the start point of many touristic walks through the landscape of Haspengouw and Tongeren.
法兰克福雷布斯托克巴德
地点:法兰克福雷布斯托克巴德
规模:18700 m2
客户:B?derBetriebe Frankfurt GmbH
公园的现有地形被用作设计的起点,并导致建筑部件作为石头躺在公园的草坪上。通往入口的路线被设计为穿过壮观峡谷的通道。参观者自然被引导进入建筑物,直接进入奇观之中。在这里,在建筑的中心,所有设施都相互连接:接待处,所有泳池区的入口,餐厅和办公室。这个中央空间令人兴奋,并为行动提供了视觉,周围公园的景观是令人惊叹的装饰。
The route towards the entrance is designed as a pathway through a spectacular canyon. The visitor is naturally guided into the building, directly entering in the midst of the spectacle. Here, in the heart of the building, all facilities are connected: the reception, the entrances to all pool areas, the restaurant and offices. This central space excites and provides sight to the action, with the landscape of the surrounding parc as a stunning décor.
Rebstockbad的这种智能而紧凑的设计实现了所有以环境为中心的雄心壮志:使用的材料是可回收的,并且由于使用了可再生的安装技术,例如地热能,雨水和屋顶上的太阳能电池的再利用,建筑物可以产生和收集自己的能源。
This smart and compact design for the Rebstockbad lives up to all of the environ-mentally focused ambitions: the used materials are recyclable and the building generates and collects its own energy thanks to the use of renewable installation techniques such as geothermal energy, the reuse of rainwater and solar cells on the roofs.
立面纹理中使用穿孔铝,在白天和夜间营造出明亮而诱人的氛围。随着时间的推移,外墙将被植物和其他绿色植物覆盖,以进一步将建筑物与公园周围的景观联系起来。新Rebstockbad的这种架构设计允许在视角和视图方面不断重定向;非常适合想要刺激锻炼的建筑物。
The use of perforated aluminium in the fa?ade’s texture creates a light and inviting ambiance in both daytime and nighttime. Over time, the facades will be overgrown by plants and other greens to further connect the building with the surrounding landscape of the park. This architectural design for the new Rebstockbad allows for a constant redirection in terms of perspectives and views; perfectly fitting to a building wanting to stimulate exercise.
? Architecture: VenhoevenCS /MOW architekten/ Image: B1 Design (renders), VenhoevenCS & MOW (other images)
Mercator体育中心
地点:荷兰阿姆斯特丹
规模:7100 m2
客户:Sportfondsenbad Nederland and Municipality of Amsterdam, De Baarsjes district
获奖:提名 阿姆斯特丹最具可持续性公共建筑 2008| 提名 密斯凡德罗奖 2007| 提名 荷兰建筑奖 2007
阿姆斯特丹的De Baarsjes是一个多元文化的社区,是来自129个不同国家的人们的家园。这个综合体的每个元素都旨在吸引不同的目标群体,因此社区中的每个人都能够使用它。另一个额外的设计挑战是创造一个看不见的绿色建筑,以保持该地区的绿色特征。
De Baarsjes in Amsterdam is a multicultural community home to people from 129 different countries. Every element of this complex is designed to appeal to a different target group, so everyone in the community is able to use it. Another additional design challenge was to create an invisible green building to maintain the green character of the area.
该建筑被设计成一个城市 - 一个微型社会 -一个绿色山坡下的洞穴。该建筑充满了视线廊道,为建筑物中的各种游客,活动和文化提供了视觉通廊。阳光通过屋顶上的各种开口深入建筑物的内部。低矮的窗户享有街道和阳光露台的景致。人们可以享受这里的设施,但他们也可以看到许多其他活动,吸引他们的兴趣并激励他们使用这些设施。
The building is designed as a city - a micro-society - a cave under a green hillside. The building is filled with sight corridors that provide visual corridors for the various visitors, events and cultures in the building. Sunlight penetrates into the interior of the building through various openings in the roof. Low windows offer street and sun terrace views. People can enjoy the facilities here, but they can also see many other activities that capture their interest and motivate them to use the facilities.
“体育中心也是
社区疗愈中心”
祖特尔梅尔水上运动中心
地点:荷兰祖特尔梅尔
规模:6850 m2
客户:祖特尔梅尔市政厅
Zoetermeer的新水上运动中心将嵌入Van Tuyllpark,这是Zoetermeer的绿色运动和休闲区。对于这种设计,VenhoevenCS的灵感来自“温泉”,这是一个传统的日本澡堂,热水来自间歇泉。因此,游泳池被设计成自然界中的木制凉亭。木屋顶和立面的玻璃开口让大量的光线通过,加强了泳池与绿色环境的关系。
The new aquatic centre for Zoetermeer will be embedded in the Van Tuyllpark, the green sports and recreation area of Zoetermeer. For this design VenhoevenCS was inspired by the ”Onsen”, a traditional Japanese bathhouse with hot water originating from a geyser. The swimming pool is consequently designed as a wooden pavilion in nature. The glass openings in the wooden roof and in the facade let a lot of light through and strengthen the relationship between the pools and the green environment.
在炎热的夏季,休闲池的外墙可以完全打开,让游客在露天游泳,并创造通往日光浴区的通道。即使在冬天,在外面的感觉仍然存在:通过天窗,大量的日光进入,天空总是可见的。这种感觉因内陆郁郁葱葱的绿色植被而进一步增强。
During hot summer days, the facade of the recreational pools can be fully opened, allowing the visitor to swim in the open air and creating a passage to the sunbathing area. Even in winter the feeling of being outside remains: through the skylights a lot of daylight enters and the sky is always visible. This feeling is further enhanced by the lush green vegetation in the interior.
新的水上运动中心主要用于娱乐:将有各种娱乐元素,例如大型滑梯。还将有一个带有八条车道的比赛池和一个带有可移动地板的游泳池。这个团体游泳池可用于游泳课程或“水上健身”。除了游泳比赛外,比赛池还提供线游泳和水球的可能性。
The new aquatic centre is primarily intended for recreation: there will be various recreational elements, such as a large slide. There will also be a competition pool with eight lanes and a pool with a movable floor. This group pool can be used for swimming lessons or ‘aquagym’. In addition to swimming competitions, the competition pool also offers the possibility of line swimming and water polo.
? Architecture: VenhoevenCS/ Landscape Architecture: bureau Wissing/ Image: VenhoevenCS
德斯特尔体育中心
地点:荷兰乌特勒支
规模:1000 m2
客户:Team Liquid Enterprise
坎彭市的新游泳池不仅是实现现代游泳住宿的绝佳机会,而且还提供了一个很好的机会,可以将“Groene Hart”的绿地从封闭的场地再生为多功能休闲公园。
The new swimming pool in the city of Kampen was not only a great chance to realize a modern swimming accommodation, but it also offered a good opportunity to regenerate the green area of the ‘Groene Hart’ from a closed off site into a multifunctional recreational park.
前“Steur”遗址被改造成公园内的一个大型绿色开放空间,游泳池像别墅一样俯瞰周围环境。游泳池在公园内形成一个凉亭,将绿地和游泳池融为一体。
The former ‘Steur’ site is transformed into a large green open space in the park, where the swimming pool, like a villa, overlooks its surroundings. The swimming pool forms a pavilion within the park, integrating the green space and pool into one.
游泳池享有该地区的全景。在夏季,玻璃幕墙可以完全打开,以便将内部休闲游泳池与露台和室外游泳池连接起来。在冬季,草坪的大门是开放的。这使得游泳池的室外区域成为通过公园的休闲路线的一部分。
The pool offers a panoramic view over the area. In summertime, the glass facade can be fully opened, in order to link the interior recreational pools with the terrace and outdoor pools. In wintertime, the gates of the lawn are open. This allows the outdoor area of the pool to become part of the recreational route through the park.
? Architecture: VenhoevenCS/ Landscape Architecture: bureau Wissing/ Image: Ossip van Duivenbode (photos)
“运动界面也是
新的城市界面”
阿梅雷纳水上运动中心
地点:荷兰阿默斯福特
规模:18500 m2
客户:阿默斯福特市政府
新的Amerena体育中心提供10,500平方米的广泛体育项目。凭借其醒目的色彩和夜间照明装饰,该建筑从阿默斯福特的入口处引人注目。从各个方面看,建筑中的不同功能都可以通过其独特的立面开口来识别。在Buurtas,建筑是开放的,入口和露台很温馨。在Waterwingebied和Spreeuwenstraat的一侧,该建筑具有景观外观,带有屋顶露台和绿色屋顶。
The new Amerena sports complex offers an extensive sports program of 10,500 m2. With its striking color and nighttime illuminated trim, the building is an eyecatcher from the entry of Amersfoort. From all sides the different functions in the building are recognizable by its distinctive fa?ade openings. On the Buurtas the building is open and inviting with the entrance and terraces. To the side of Waterwingebied and Spreeuwenstraat the building has a landscaped appearance with roof terraces and a green roof.
内部光线充足,重点是该地区的质量和氛围。对建筑物的使用和使用者的观察以及光线的反射和周围环境的特定视图都起着重要作用。最佳性能促进是Hogekwartier体育综合体的主要关注点。
The interior is light and the emphasis is on the quality and atmosphere of the areas. The viewing on use and users of the building plays an important role, as well as the reflection of the light and the particular view of the surroundings. The optimum facilitation of performance is the main focus of the Hogekwartier sports complex.
? Architecture: VenhoevenCS /Landscape architect: MTD Landschaparchitecten/ Image: Ossip van Duivenbode (photos)
阿尔克马尔体育中心
地点:荷兰阿尔克马尔
规模:10000 m2
客户:阿尔克马尔市政厅
旧的体育中心进行了彻底的改造和大规模的扩建,有一个新的(顶部)体育馆,几个健身房,新的更衣室和一个突出的新入口。De Meent促进顶级运动和休闲运动。将有单独的健身房,用于蹦床,体操,击剑,乒乓球和滑冰。促进体育教育是住宿的重要组成部分,但De Meent也为大型体育赛事提供了舞台。
The old sports complex got a complete makeover and a large extension, with a new (top)sports hall, several gyms, new dressing rooms and a prominent new entry. De Meent facilitates both top sport and recreational sport. There will be separate gyms for trampolining, gymnastics, fencing and table tennis and ice skating. The facilitation of sports education is an important part of the accommodation, but De Meent also offers a stage for big sports events.
新体育综合体的设计旨在使人们对体育充满热情。新建筑的建筑强调了阿尔克马尔的体育雄心。贯穿整栋建筑的视觉线条展示了不同的设施,并将内部和外部连接起来。
The design of the new sports complex is intended to make people enthusiastic for sports. The architecture of the new building emphasizes Alkmaar’s sports ambition. Visual lines through the whole building show the different facilities and connects interior with exterior.
内部的“街道”作为建筑物的支柱,提供清晰的路线和可访问的方向。“街道”不仅具有物流功能,而且是一个重要的聚会场所,社交方面在人们做运动的动力中起着重要作用。
Inside a ‘street’ functions as the backbone of the building, offering a clear route and accessible orientation. The ‘street’ does not only have a logistic function, but is also an important meeting place, where the social aspect plays an important role in the motivation for people to do sports.
? Architecture: VenhoevenCS / Image: Ossip van Duivenbode (photos)Ossip van Duivenbode (photos)
“ 见证时代对于
文体运动的新定义   "
Alienware外星人电竞场馆
地点:荷兰乌特勒支
规模:1000 m2
该设施位于新社区建筑Het Platform(也由VenhoevenCS设计)的中心地带,俯瞰着车站广场。由于位置和穿过建筑物的公共通道,Team Liquid俱乐部玩家可以训练和竞争,同时与充满活力的乌得勒支市保持联系。
Situated in the heart of the new community building Het Platform (also designed by VenhoevenCS), the facility overlooks the Station Square. Thanks to the location and a public passage through the building, Team Liquid players can train and compete and at the same time stay connected with the vibrant city of Utrecht.
这个项目完美地说明了游戏设计和数字艺术如何成为建筑师新的和典型的灵感来源。这里的建筑是二元性的缩影:在真实和可以想象之间,什么都没有。宁静的极简主义和高科技,前卫的游戏美学的混合;通常永远不会结合的功能的混合体,例如带有纱布室的餐厅和带玩家休息室的画廊。
This project Is the perfect illustration of how game design and digital art can become new and quintessential sources of inspiration for architects. The architecture here is the epitome of duality: between what is real and what can be imagined and where nothing is what it seems.
对内饰材料的富有想象力的使用也创造了真实与想象之间的相互作用,大胆的颜色和材料选择突出了不同的空间和功能。氛围巧妙地从别致和动态到专业和专注交替,以反映空间的功能。黑色,白色,竹子,蓝色鬃毛和六边形被锻造成一个大胆而坚固的场景;而品牌的身份既明确地表现出来,也体现在隐藏的复活节彩蛋中。通过使用生物基和回收材料,高效安装,智能声学,照明和预制件元素,我们为Team Liquid创造了一个可持续,健康和舒适的工作空间。
The imaginative use of the interior’s materials also creates an interplay between the real and the imagined, with a daring choice of colours and materials accentuating different spaces and functions. Atmospheres skilfully alternate from chic and dynamic to professional and focused to reflect the function of the space. Black, white, bamboo, blue manes and hexagons are forged into a bold, yet sturdy, mise en scene; while the brand’s identity is represented both explicitly and within hidden easter eggs. By using bio-based and recycled materials, efficient installations, smart acoustics, lighting, and prefab elements, we have created a sustainable, healthy and comfortable workspace for Team Liquid.
? Architecture: VenhoevenCS /AHH Architects/ Image: Teo Krijgsman
德雷伯赫特文体中心
地点:荷兰蒂尔堡
规模:12500 m2
客户:蒂尔堡市政厅
Tiburg-North的Wagner广场周围的开发项目旨在使该社区对更广泛的公众更具吸引力。德瑞伯赫特体育中心及其差异化的设施在这一发展中发挥着重要作用。Drieburcht被设计成一个理想的微型社会。虽然建筑物外的社会可以分为不同的群体,彼此并排生活(或背靠着彼此),但在建筑物内部,我们努力以轻松,非正式的方式将人们聚集在一起。
The developments around the Wagner square in Tiburg-North are intended to make the neighbourhood more attractive to a broader spectrum of the public. The Drieburcht Sports Complex, with its differentiated facilities, plays an important role in this development. Drieburcht is designed as an  an ideal society in miniature. While society outside the building may be divided into different groups living alongside each other (or with their backs to each other), inside the building we strive to bring people together in relaxed, informal ways.
这座建筑的氛围和活动呈现出“城市戏剧”的形式。人们最初是为了游泳或健身训练而来的,但还是会因为热闹的气氛而不断回来。最迷人的方面是彼此的视角,看到和被看到。
The atmosphere and activity in this building take on the form of ‘urban theatre.’ People initially come for the swimming or the fitness training, but keep coming back for the lively atmosphere. The most fascinating aspect is the view of each other, the seeing and being seen.
尽管建筑物内部的景色非常壮观,但建筑物的外观也将令人眼前一亮。它与艺术家Jean-Luc Moerman合作创作,突出了体积的非凡相互作用,并为建筑项目提供了力量,速度和流动性,形成了建筑内部功能的完美补充。
As spectacular as the views inside the building are, the building’s exterior will also turn heads. Created in collaboration with artist Jean-Luc Moerman, it accentuates an extraordinary interplay of volumes and gives the building project a strength, speed and fluidity that form a perfect complement to the functions inside the building.
? Architecture: VenhoevenCS/ Image: Filip Dujardin (photos)
奥斯坦德文化体育中心设计
地点:比利时奥斯坦德
规模:16000 m2
客户:Sportsbuilders NV, Stad Oostende, FARYS|TMVW and WoonWel
通过将一个大型公共游泳池和22套公寓组合在一栋建筑中,该建筑完美地融入了现有的城市环境。同时,该建筑与邻近高尔夫球场和沿海地带的绿色环境相得益彰。这些公寓位于水上运动中心的顶部,分为两个独立的体量,有助于提高综合大楼的可识别性。
By combining a large public swimming pool and 22 apartments in one building, the building blends perfectly into the existing urban context. At the same time, the building fits in with the green surroundings of the neighbouring golf course and the coastal strip. The apartments, housed in two separate volumes on top of the aquatic centre, contribute to the recognizability of the complex.
该建筑在各个方面都以不同的方式呈现自己。除了温暖的室内空间外,它还为所有居民带来了宜人的户外空间,这要归功于绿色的屋顶和种植的树木。同时,建筑的能源成本很低,因为所需的热量和电力的很大一部分是通过自身产生的。
The building presents itself in different ways in every way. In addition to warm indoor spaces, it also brings pleasant outdoor spaces to all residents, thanks to a green roof and planted trees. At the same time, the energy cost of the building is low because a large part of the required heat and electricity is generated by itself.
? Architecture: VenhoevenCS/B2Ai architects  / Image: photo by Klaas Verdru
"文体教育也是
高等教育的一部分 "
欧洲公园文体中心设计
地点:荷兰格罗宁根
规模:5500 m2
客户:格罗宁根市政厅
获奖:2019年格罗宁根最佳建筑二等奖(专业评审团)| 2019年格罗宁根最佳建筑二等奖(公共评审团)
体育运动空间在建筑的各个部分都清晰可见。户外运动活动在户外露台上进行,大多数训练室都位于入口广场周围。除了“常规”体育设施外,这座能源中和的建筑还拥有额外的教育设施,如教室和考场以及餐厅。
Sports spaces are clearly visible in all parts of the building. Outdoor sports activities take place on outdoor patios and most training rooms are located around the entrance plaza. In addition to the "regular" sports facilities, the energy-neutral building has additional educational facilities such as classrooms and examination rooms as well as a cafeteria.
在内部,所有空间都是轻盈的,没有不必要的细节。产生噪音(运动)的空间和需要安静的空间(教育)的结合是一项重大的设计挑战。通过所需空间的智能布局,和室内吸音木板的材料使用完美的解决了这个问题。为了给格罗宁根提供面向未来和可持续的建筑,该建筑的可能扩建已经整合到设计中。
Inside, all spaces are light and free of unnecessary details. The combination of spaces that generate noise (motion) and spaces that require quietness (education) is a significant design challenge. Through the intelligent layout of the required space, and the material use of interior sound-absorbing wood panels, this style is perfectly solved. In order to provide Groningen with a future-oriented and sustainable building, a possible extension of the building has been integrated into the design.
? Ar chitecture: VenhoevenCS /Landscape architect: Martijn AI/ Im age:   Photo s by Ossip van Duivenbod
鹿特丹伊拉姆斯可持续体育中心设计
地点:荷兰鹿特丹
规模:8800 m2
客户:鹿特丹伊拉姆斯大学
新的体育中心位于校园的入口,被设计为一个培训和体育设施,为学生提供的不仅仅是锻炼或进行团队运动的场所。该综合体的形状如堆叠和连接的“运动箱”,在半透明的皮肤后面,创造了一种雕塑效果。诗意而轻薄的立面将跟随视角、时间、照明和季节而变化,并将一座简单的体育建筑变成一个动态的生活对象。
The building is located at the entrance to the campus, the new Sports Centre is designed as a training and sports facility, offering students more than a place to exercise or play team sports. The complex is shaped like stacked and connected "exercise boxes" behind a translucent skin, creating a sculptural effect. The poetic and light fa?ade will change with perspective, time, lighting and seasons and transform a simple sports building into a dynamic living object.
体育中心围绕着连接两个主楼体的内街而建。内部街道是建筑物的骨干,两侧有入口,提供了清晰的方向。这条街不仅具有物流功能,而且是一个重要的聚会场所,毕竟,社交是人们做运动的重要动力。同时,该建筑的设计是能源中性的,并将主要由可循环的建筑材料建造。
The sports center is built around the inner street that connects the two main buildings. Internal streets are the backbone of the building, with entrances on either side, providing clear orientation. This street not only has a logistic function, but also an important meeting place, after all, socializing is an important motivation for people to do sports. At the same time, the building is designed to be energy neutral and will be constructed primarily from recycled building materials.
? Architecture: VenhoevenCS  / Image: b1design (renders)
巴黎-萨克雷大学文体中心
地点:法国巴黎
规模:4500 m2
客户: 巴黎萨克莱大学
巴黎萨克莱大学校园位于巴黎西南部。科技园区是巴黎顶尖大学和研究所的所在地,在这个“法国硅谷”中,培训和研究加强了初创企业和扩大规模,反之亦然。与生活、饮食、购物和运动的纠葛,使校园本身就是一座城市。 MEGA 游泳和运动综合体被设计成一个开放、社交和运动的交汇点,紧凑而透明,并与 Plateau de Saclay 的景观交织在一起。
Campus Université Paris-Saclay is located just southwest of Paris. The tech campus is home to top Parisian universities and institutes and has been given the subtitle ‘innovation playground’. In this ‘Silicon Valley of France’ training and research strengthen start-ups and scale-ups and vice versa.  The swimming and sports complex OMEGA is designed as an open, social, and sportive meeting point, compact and transparent, and intertwined with the landscape of the Plateau de Saclay.
自然与水的平衡
为了不扰乱土壤性质和地下水结构,水池不会开挖,而是放置在高原上,周围有高架。宽阔的楼梯和它们上方的悬臂形成了一种强调入口的欢迎姿态。 体积尽可能紧凑,为景观和生物多样性提供空间。 生态结构包括日光浴场、游戏场和运动场,以及精心挑选植被的花园,包括 为咖啡馆提供水果的果园。 花园中的水池缓冲雨水,也来自绿色屋顶,以供重复使用。
The wide stairs and the cantilever above them form a welcoming gesture that emphasizes the entrance. The volume is as compact as possible to give space to the landscape and to biodiversity. Included in the ecological structure are fields for sunbathing, games and sports and gardens with carefully chosen vegetation including an orchard that supplies the cafe with fruit. Pools in the gardens buffer rainwater, also from the green roofs, for reuse.
一个有风景的游泳池
游泳池、 健康和健身将在矩形连接的体积中相遇, 与整个校园的建筑风格相呼应。立面由一条连续的玻璃条组成,上面是阳极氧化铝板,在季节和一天中的时间的影响下,周围的树木在其上玩着颜色和阴影的游戏。由于透明的底座,从街上可以看到竞技运动和游泳课程;在泳池中,沐浴者可以从略微升高的位置看到周围的绿色植物。康体设施位于大楼中心的封闭花园内。
In line with the architecture on the entire campus, OMEGA will have an abstract appearance. Swimming pools, wellness and fitness will meet in rectangular, connected volumes. The facade consists of a continuous strip of glass with anodized aluminum panels above, on which, under the influence of the seasons and the time of day, the surrounding trees play a game with color and shadow. Due to the transparent base, competitive sports and swimming lessons are visible from the street; in the pools, bathers have a view of the surrounding greenery from their slightly elevated position. The wellness facilities can be found in an enclosed garden in the heart of the complex.
? ? Architecture: VenhoevenCS  / Image: b1design (renders)
最后作为VCS多年文体运动中心的集大成者,巴黎2020水上运动场馆, 被提名为MIPIM 国际奖项的最佳未来项目类别的四名决赛入围者之一。
The MIPIM Awards 2022 shortlists are out! And we’re proud to find the Aquatics Centre for Paris2024 nominated as one of four finalists in the Best Futura Project category of this internationally renowned real estate competition.
140.17 万条内容 · 2232 人订阅
变电站方案设计 十例
案例一 芬兰Imatra某变电站 / Virkkunen&Co Architects 案例二 美国 Larkin
