土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 办公立面:双层表皮设计
办公立面:双层表皮设计
发布于:2022-09-07 10:35:07 来自:建筑结构/混凝土结构 [复制转发]
Suanphlu办公室是一间私人办公室,业主的顶层阁楼位于顶层。它坐落在老挝普陀孔神社旁边,这是一座Suanphlu社区的历史神社。该建筑的主要朝向朝向神龛,神龛也在西面,接受大量阳光。邻居成为立面设计中的一个重要因素。立面设计不仅要考虑用户在内部的视野和穿过建筑物的阳光量,还要注意,该立面也作为社区的背景,有可能将刺眼的阳光反射到邻近的神龛上。
Suanphlu Office is a private office with the owner's penthouse on the top floor. It is situated next to Lao Pueng Thao Kong shrine, a historical shrine of Suanphlu’s community. The building’s main orientation faces the shrine, which is also in the west direction that receives a lot of sunlight. The neighbor becomes an important factor in the facade design. The facade design has to not only consider the view of the users on the inside and the amount of sunlight getting through the building but also be aware that this facade also serves as a backdrop for the community with the potential to reflect the harsh sunlight onto the neighboring shrine.
由于物业面积限制,该建筑的特点是从底部向上延伸的绿色袖珍庭院的凹面插入。口袋庭院在每一层上不断交替放置,每一层都有不同层次的绿色景观。这一理念不仅改善了建筑的立面美学,还为建筑内部的办公空间创造了袖珍绿化景观。
Due to the property size limitation, the building features concave insertions of green pocket courts, climbing from the base up the side. The pocket courtyards are continuously placed on each level alternatively from floor to floor resulting in the different layers of green views on each floor. This idea not only improves the building’s elevation aesthetics but also creates views of pocket greenery for the office spaces inside the building.
双层表皮立面的设计旨在保护建筑免受刺眼的阳光照射,减少玻璃立面上的反射,并鼓励气流和通风。该建筑的玻璃立面由铝覆层覆盖,以减少进入建筑的热量和阳光量,同时通过其清晰、穿孔和不透明的设计,仍能为外部提供可视性。
The double-skin facade is designed to protect the building from harsh sunlight, reduce the reflection on the glass facade, and encourage wind flow and ventilation. The building’s glass facade is covered by aluminum cladding to reduce the heat and the amount of sunlight entering the building, while still providing visibility to the outside through its clear, perforated, and opaque design.
半光泽钛包层以不同角度添加,从而形成一整天都在变化的阴影图案。平面以不同的角度弯曲,以避免强烈的阳光反射到邻居身上,而设计中的对角线切割将立面视觉上分隔为整个建筑的面板,从而产生运动和动态添加。立面成为一个可识别的特征,按照业主的意图为项目添加了独特的特征,因此,项目能够提高内部用户的生活质量,同时也考虑到现有的周围社区。
The semi-gloss titanium claddings are added at different angles which results in a shadow pattern that changes throughout the day. The planes are bent at different angles to avoid harsh sunlight reflection onto the neighbors while the diagonal cuts in the design visually separate the facade into panels across the building, creating movements and adding dynamically. The facade becomes a recognizable feature that adds a unique characteristic to the project as the owner has intended and as a result, the project is able to enhance the quality of life for the users on the inside while also being considerate to the existing surrounding community.
平面图
立面图
剖面图
构造生成
建筑师:IDIN Architects
地点:泰国
面积:2290平方米
年份:2020
140.17 万条内容 · 2232 人订阅
慎用掺加钢渣的混凝土砖或砌块
为了保护环境,利用工业废渣来生产建筑材料是当下一种普遍的做法。废渣主要有粉煤灰、炼铁产生的粒化高炉矿渣、炼钢产生的钢渣等。 钢渣用在混凝土砌块或混凝土砖中,若使用不当,后果将会很严重。 因为在现行混凝土砌块或混凝土砖的国家标准中,没有关于体积安定性检测的相关技术要求。某住宅小区使用掺有钢渣的混凝土砌块建成,在施工完成5~6年后,外围护墙体出现大面积开裂现象,凿开面层发现砌块也有同样的裂缝(图1、图2)。在某综合楼施工6年后(施工日期为2014年)也出现大量裂缝,同时导致窗户变形(图3、图4)。
