土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 楼板分层浇筑,楼板支撑受力时程分析怎么做?
发布于:2022-08-31 10:11:31 来自:建筑结构/混凝土结构 [复制转发]
3.25m厚板,先浇2m,后再浇1.25m,先浇部分能承受多少后浇部分的自重?这些怎么算,没思路!
140.17 万条内容 · 2229 人订阅
极简现代,多层办公楼
德国杜伊斯堡的墨卡托一号大楼是一座“开拓性”的建筑,也是一座具有代表性的城市入口。独特的后退扇形立面在短端旋转,引导从侧面中央火车站的旅客和通勤者流,以及从内城的行人流。与此同时,它不寻常的轮廓创造了新的和令人惊讶的视线,一次又一次地把这个大约100米长,17米宽,26米高的建筑变成了周围城区的地标。 A ‘trailblazing’ building and a representational entryway to the city are arising with the new construction of Mercator One in Duisburg, Germany. The distinctive retreating fan-shaped fa?ade that pivots at the short ends guides the streams of travelers and commuters from the flanking central railway station together with pedestrian flows from the inner city. At the same time, its out-of-the-ordinary silhouette that spawns new and surprising sightlines, again and again, turns the roughly 100-meter-long, 17-meter-wide, and 26-meter-high structure into a landmark for the surrounding urban quarter.
