土木在线论坛 \ 建筑结构 \ 钢结构工程 \ 网格状外立面,钻石般的办公公寓
网格状外立面,钻石般的办公公寓
发布于:2022-08-25 09:45:25 来自:建筑结构/钢结构工程 [复制转发]
Paragon是一栋位于墨尔本CBD珍贵角落的住宅建筑,它讲述了这座城市的过去、现在和未来的多层叙事。Paragon是为大都市生活而设计的,通过将墨尔本的一片城市景观转变为城市避难所,为居民创造了一种认同感。
Paragon is a residential building on a prized corner of Melbourne’s CBD that tells a multi-layered narrative of the city’s past, present, and future. Designed for metropolitan living, Paragon creates a sense of identity for its residents by transforming a piece of the Melbourne cityscape into an urban sanctuary.
之前是墨尔本凯尔特人俱乐部的主场,原始遗产建筑的立面受到了尊重的保护,恢复和庆祝。玻璃大厦在它上面升起,在反射的表面上有优雅的凯尔特风格的对角网格图案。在地面上的遗产立面旁边,一个规则的网格反映了传统建筑的基准线,但以一种最小的更正交的方式。
Previously the home to Melbourne’s Celtic Club, the facade of the original heritage building was respectfully protected, restored, and celebrated. The glass tower rising above it features an elegant Celtic-inspired diagonal grid pattern across the reflective surface. Adjacent to the heritage fa?ade at ground level, a regular grid reflects the datums of the traditional architecture, but in a minimal more orthogonal manner.
横跨三层楼,一个活生生的绿色元素作为所有公共连接区域的支柱。这个像温室一样的空间在主塔和遗产立面之间提供了缓解。这个郁郁葱葱的避难所,配有精致的水磨石和户外座椅,为人们提供了一个远离喧嚣的街景的静谧空间。
Unfurling across three stories, a living green element serves as the backbone of all the common linked areas. This conservatory-like space provides relief between the main tower and the heritage facade. The lush sanctuary, complete with refined terrazzo and outdoor seating, offers a tranquil escape from the bustling streetscape below.
一个健康绿洲提供了一系列的豪华设施休息和放松,一系列正式和非正式的区域模糊了公共和私人领域之间的界限,为居民提供一个专属的俱乐部。高质量的设施是建筑用户的核心利益,提供了一个聚集、见面和形成社区的地方。团体可以占用空间并享受各种用途,包括一个设备齐全的健身房、游泳池和娱乐区。图书馆、私人剧院和放映厅进一步扩展了设施,增加了高水平的细节和功能。
A wellness oasis offers an array of luxury amenities for rest and relaxation, and a series of formal and informal zones blur the line between the public and private domain to present an exclusive club for residents. High-quality amenities are a core benefit for users of the building, providing a place to gather, meet, and form the community. Groups can occupy the space and enjoy a variety of uses, including a fully equipped gym, swimming pool, and entertaining areas. Extending the amenity further, a library, private theatre, and screening lounge add a high level of detail and function.
尽管这座塔高达48层,但它有一个精心设计的小规模住宅密度。原计划的280套公寓减少到227套,以允许每层最多6套公寓。由于场地的限制,公寓的楼板比一般的公寓要浅,这样可以获得更多的自然光线和绝佳的角落景观。在核心墙上安装了128块横跨158平方米的垂直太阳能电池板系统,不仅具有创新性,而且具有诱人的附加值。
Though the tower rises to 48 levels, it has a deliberately small-scale residential density. The original scheme of 280 apartments was reduced to 227 to allow for a maximum of 6 apartments per floor. Site constraints meant th     at floor plates are shallower than typical apartments, allowing for greater levels of natural light and excellent corner vistas. The implementation of a vertical solar panel system boasting 128 panels spanning 158sqm installed on the core walls proved not only innovative but to be an attractive value-add。
平面图
建筑师:Fender Katsalidis Architects
地点:澳大利亚
面积:2900平方米
年份:2021
钢结构工程
46.53 万条内容 · 1223 人订阅
“超流线”曲线外立面,极简手法,营造极具美感的效果
“超流线”曲线艺术,延伸全新城市界面   徐辉设计         从古至今,追寻自然的本能让人们对临水而居的生活充满向往。水之灵,山之秀,总会在潜移默化中赋予人们内心的洗礼。
