土木在线论坛 \ 建筑结构 \ 结构新鲜事 \ 极简现代:多层办公建筑
极简现代:多层办公建筑
发布于:2022-08-04 09:28:04 来自:建筑结构/结构新鲜事 [复制转发]
位于Chartres-de-Bretagne,在住宅区和协会大楼之间,ASSIA(个人援助协会)的总部希望在现有部分的南面扩展到一个600平方米的地块。
Located in Chartres-de-Bretagne, between a residential area and association buildings, the headquarters of ASSIA (an association for personal assistance) is looking to extend onto a 600 square meters plot to the south of the existing part.
新大楼有三层楼高,提供了很大的建筑面积,同时保留了最大限度的免费土地。独立的扩建部分仅通过玻璃走道连接,允许在两个部分之间创建一个种植空间。
The new one is three stories high, providing a large floor area while preserving a maximum amount of free land. The detached extension is connected only by a glass walkway allowing the creation of a planted space between the two parts.
我们的思考使我们对一个可以随时间发展的具体方案作出回应。我们在地块的南侧创造了一个独立的托盘,在一个由木柱和木梁组成的建设性框架上,间隔三米。这个框架允许至少11平方米的办公室,可以组合成几个实体。
Our thinking led us to respond to a specific program that could evolve over time. We have created a free-standing tray on the south side of the plot, on a constructive framework of wooden posts and beams, spaced three meters apart. This framework allows for a minimum of 11m2 of offices that can be grouped into several entities.
它们位于南部,利用开阔的视野和光线。一个老化的木制遮阳伞在夏天保护工作空间免受阳光直射。硬核由预制混凝土制成(楼梯、电梯和技术室),毗邻自由的木地板。走廊为不同的办公室提供电力和通风的技术支持(假天花板)。
They are positioned to the south to take advantage of the open views and light. A pre-aged wooden sunshade protects the workspaces from direct sunlight in summer. The hardcore, made of prefabricated concrete (staircases, lifts, and technical rooms) is adjacent to the free wooden floor. A corridor serves the different offices as technical support for electricity and ventilation (false ceiling).
整个项目是预制的;中央混凝土核心和木柱梁系统以及CLT地板。所有的材料都暴露在外,以确认施工方法和不同的材料处理。遮阳伞和包层由提前老化的木材制成,有5厘米宽的叶片,展示了立面处理的薄度。
The entire project is prefabricated; both the central concrete core and the wooden post and beam system and CLT floors. All the materials are left exposed to affirm the construction methods and the different material treatments. The sunshades and the cladding are made of pre-aged wood, with five centimeters wide blades, demonstrating thinness in the treatment of the facade.
它们的外观随着太阳的方向而变化,伴随着三层玻璃幕墙,在白天反映环境,在晚上露出木地板。
Their aspect is changing according to the orientation of the sun, accompanied by the triple glazed curtain wall which     reflects the context during the day and reveals the wooden floors in the evening.
区位图
平面图
立面图
剖面图
轴测分析图
细部节点
建筑师:Atelier 56S
地点:法国
面积:1700平方米
年份:2022
结构新鲜事
2942 条内容 · 87 人订阅
新一代住宅曝光!! 230-540㎡、错层设计、每户3-4个空中庭院......
这是一个非常特殊的项目,在业内关注度非常高。 远远望去,有点 像 蘑菇 、 像云 、 像花朵 ,也有一点 像迎客松 ,甚至 像碗 一样,设计师说这是一株株 “灵芝树” ...... 有一种自由生长的感觉、向上的力量,置身其中,仿佛置身本初的自然。 郑州建业君邻大院·松苑 效果示意图 真的很难想象这竟然是一个住宅项目——郑州建业君邻大院·松苑
