土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 急求!结构钢筋非标低于正常标准,应如何处理?
基础及柱钢筋用了非标的低于正常国标的直径,现应采取什么样的补救措施?加固?如何处理?十分感谢!
全部回答(3 )
  • panjianmin
    頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂████████████████頂頂頂頂
    頂頂頂頂頂頂頂頂頂頂████頂頂██████████頂頂頂頂頂頂頂頂頂
    頂頂頂頂頂頂████████頂頂██頂頂頂████頂頂頂頂頂頂頂頂頂頂
    頂█████████████頂頂頂頂頂頂頂███頂頂頂頂頂頂頂頂頂頂頂
    頂███████████頂頂頂頂頂頂頂頂█████████頂頂頂頂頂頂
    頂頂█████████頂頂頂頂頂頂頂頂████████████頂頂頂頂
    頂頂頂█頂頂頂████頂頂頂頂頂頂████頂頂頂頂頂█████頂頂頂頂
    頂頂頂頂頂頂頂頂███頂頂頂頂頂頂██頂頂頂█頂頂頂頂███頂頂頂頂頂
    頂頂頂頂頂頂頂頂███頂頂頂頂頂███頂頂頂██頂頂頂███頂頂頂頂頂
    頂頂頂頂頂頂頂頂███頂頂頂頂頂███頂頂███頂頂頂███頂頂頂頂頂
    頂頂頂頂頂頂頂頂███頂頂頂頂頂██頂頂頂██頂頂頂頂███頂頂頂頂頂
    頂頂頂████████頂頂頂頂頂頂█頂頂██頂頂頂頂████頂頂頂頂頂
    頂頂頂頂███████頂頂頂頂頂頂頂頂頂██頂頂█頂頂頂██頂頂頂頂頂
    頂頂頂頂頂頂█████頂頂頂頂頂頂頂頂███頂頂████頂頂頂頂頂頂頂
    頂頂頂頂頂頂頂頂███頂頂頂頂頂頂頂████頂頂頂██████頂頂頂頂
    頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂█████頂頂頂頂頂██████頂頂頂
    頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂████頂頂頂頂頂頂頂頂█████頂頂頂
    頂頂頂頂頂頂頂頂頂頂頂頂頂█████頂頂頂頂頂頂頂頂頂頂████頂頂頂
    頂頂頂頂頂頂頂頂頂頂頂頂██頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂██頂頂頂頂
    頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂
    2008-03-31 20:42:31 来自 PC 评论 举报
  • mrky010
    首先这是施工技术问题,只要你的设计文件没问题,可以不用担心,其次,按照目前的钢筋直径代入计算文件复核,如果满足要求就更不用担心了,施工单位也解放啦,要不满足就加固,施工单位自费处理
    2008-03-31 17:02:31 来自 PC 评论 举报
140.17 万条内容 · 2232 人订阅
