土木在线论坛 \ 建筑结构 \ 砖混结构 \ 独特花纹:砖石立面---赫尔佐格&德梅隆
发布于:2022-06-16 09:10:16 来自:建筑结构/砖混结构 [复制转发]
位于巴特西的皇家艺术学院校园提供了一个教育、研究和创业的公式,探索科学、艺术和设计交汇处的创造性可能性。这是一个灵活的建筑解决方案,可以适应这个有185年历史的机构不断变化的教学和研究计划,目的是团结和加强皇家艺术学院(RCA)的设计创新和创业文化。
The Royal College of Art campus in Battersea delivers a formula for education, research, and entrepreneurship that explores the creative possibilities at the intersection of science, the arts, and design. It is a flexible architectural solution that adapts to the constantly changing programmes of teaching and research at this 185-year-old institution, with the aim to unite and strengthen the culture of design innovation and entrepreneurialism at the Royal College of Art (RCA).
该场地位于巴特西创意区现有的RCA巴特西建筑南部的城市街区。该项目提供15,500平方米的车间、工作室和研究空间;它由一层的车间和生产设施组成,支持沿着豪伊街的低层4层工作室大楼,以及一个更高的位于Parkgate路的8层研究大楼。豪伊街将成为合并后的RCA巴特西校区的主干道。
The site occupies the urban block to the south of the existing RCA Battersea buildings within the Battersea Creative Quarter. The project delivers 15,500 sqm of workshop, studio, and research space; it is composed of a ground floor base of workshops and manufacturing facilities supporting a low-rise 4-storey Studio Building along Howie Street, and a taller 8-storey Research Building prominently located along Parkgate Road. Howie Street will become the main thoroughfare for the combined RCA Battersea Campus.
车间和工作室建筑的纹理砖和大型北向夹层灯为巴特西桥路呈现出独特而有背景的轮廓;研究大楼的金属鳍为园区提供了一个独特的天际线标识。
The textured brickwork and large, north-facing clerestory lights of the workshop and studio building present a unique yet contextual profile to Battersea Bridge Road; the metal fins of the Research Building offer a distinct skyline identity for the campus.
连接性和灵活性。工作室是RCA活动的核心。车间空间被安排成一系列相互连接的体量,上面的工作室空间横跨和悬空,并包含了工作室和研究空间的入口。街道层面的体量安排形成了一条通道,连接了沿豪伊街的现有RCA建筑,并允许通过场地的视野,大型的图片窗提供了与工作室的视觉连接。上面的工作室层的悬垂体量在街道层提供了有盖的人行道和遮蔽的座位区,以及上面的阳台和露台。
Connectivity and flexibility. The workshop is the nucleus of RCA activities. Workshop spaces are arranged as a series of interconnected volumes, over which the upper studio spaces span and overhang, and incorporate the entrances to the studio and research spaces. The street level arrangement of volumes forms a passageway that connects the existing RCA buildings along Howie Street and allows for views through the site and large picture windows provide visual connections to the workshops. The overhanging volume of the studio levels above provide covered walkways and sheltered seating areas at street level, as well as balconies and terraces above.
以前封闭的拉德斯托克街的一部分被纳入底层;上层工作室的楼层横跨这个空间,形成一个双层高度的 "机库"--一个用于制作和展示大型作品的灵活区域,其空间也足以举办RCA的集会和活动。这个空间也可以向公众开放,形成从豪威街到校园主要接待区的另一条通道。
A portion of the previously closed-off Radstock Street is incorporated into the ground floor; upper studio floors span across this space to create a double-height “Hangar” – a flexible zone for the production and display of large-scale work that is also spacious enough to host RCA assemblies and events. This space can also be opened to the public, creating another thoroughfare from Howie Street to the main reception area of campus.
工作室的地板提供了一系列的三个阶梯地板,每个包含约2000平方米的高质量的工作空间。这些空间包含一个灵活的基础设施,可以适应一系列RCA项目。除了为室内工作室提供自然光和空气的基本特性外,混凝土楼板延伸形成悬臂式外部画廊,提供阴凉和自然通风,并为内部工作人员直接连接到室外。
The studio floors provide a series of three terraced floorplates, each comprising approximately 2000 sqm of high-quality workspace. These spaces contain a flexible infrastructure that can be adapted to a range of RCA programmes. In addition to the essential qualities of natural light and air supplying the indoor studios, the concrete floorplates extend to form cantilevering external galleries, providing shade and natural ventilation, and an immediate connection to the outdoors for those working within.
研究楼在底层工作室之上,由7个560平方米的楼板组成一个立方体。与工作室楼层的原则相同,每个空间都是一个灵活的研究单位,配备了临时的实验室空间。创新RCA,新兴的研究生商业孵化器,位于5和6层。第7层有一个活动空间和露台,可以看到北部和RCA校园的其他地方。
The Research Building is organised above the ground floor workshops as a cubic stack of seven 560 sqm floorplates. Sharing the principles of the studio floors, each space is a flexible research unit equipped with provisional laboratory space. Innovation RCA, the burgeoning post-graduate business incubator, is located on levels 5 & 6. Level 7 contains an event space and terrace with views towards the North and to the rest of the RCA campus.
坚固的物质性。 为了支持其作为一个高效和灵活的集装箱,能够适应不同的工作模式,巴特西园区的材料是简单而坚固的。内部空间由混凝土平板组合而成,支撑在8米长的混凝土填充钢管的网格上,并有一个暴露的、可适应的服务安排。
Robust materiality. To support its role as an efficient and flexible container that can adapt to different modes of working, the materiality of the Battersea campus is simple and robust. The interiors are formed from a combination of concrete flat slabs supported on an 8 m grid of concrete filled steel tubes, with an exposed and adaptable services arrangement.
底层立面由简单的弗拉芒邦德砖构成,在一些区域打孔,用开放的花纹砖块为车间和可操作玻璃板后面的雕塑工作室提供通风。在工作室的上层,底层砖的图案被翻转过来,通过独特的纹理暴露出头砖的切割端和制造的痕迹。
The ground floor fac?ade is formed from a simple stock brick in a textured Flemish bond, perforated in areas with open patterned brickwork to provide ventilation to the workshop and sculpture studio behind operable glass panels. On the upper studio storeys, the ground floor brick pattern is turned inside-out, exposing the cut ends of the header bricks and marks of manufacture through a distinctive texture.
研究大楼从砖石语言出发,采用蜿蜒的白色鳍的垂直组合,在立面上进行了校准,以调节太阳能增益和眩光,并促进内部工作空间的自然通风。
The Research Building departs from the masonry language with a vertical composition of sinuous white fins, calibrated across the fac?ade to moderate solar gain and glare, and facilitate natural ventilation to the workspaces within.
环境适应力。该建筑获得了BREEAM优秀评级。其高效的形式是在一个灵活的外壳内提供正确的日光控制、隔热和自然通风,结合耐用、低维护的材料和适应性强的服务组织。
Environmental resilience. The building has achieved a BREEAM Excellent rating. Its efficient form is derived to deliver the correct levels of daylight control, insulation, and natural ventilation within a flexible envelope, combined with durable, low maintenance materials and adaptable services organisation.
裸露的混凝土上层建筑具有高含量的水泥替代物,其质量为被动的内部提供了额外的热援助。此外,在工作室建筑的屋顶上有一个广泛的太阳能阵列,以减轻整体的能源负荷,设置在 "蓝色 "和 "棕色 "屋顶的组合中,以帮助满足可持续的排水要求,并促进更大的生物多样性。
The exposed concrete superstructure has a high content of cement replacement, and its mass provides additional thermal assistance to the passive interior. In addition, there is an extensive solar array located on the roof of the studio building to ease overall energy loads, set within a combination of ‘blue’ and ‘brown’ roofs to assist with sustainable drainage requirements and promote greater biodiversity.
平面图
剖面图
建筑师:赫尔佐格 & 德梅隆( Herzog & de Meuron )
地点:英国
面积:16841平方米
年份:2021
砖混结构
10.12 万条内容 · 458 人订阅
建筑营新作:光的漏斗,北京偏锋画廊改造
主展厅  ?  金伟琦 偏锋画廊于 2009 年入驻北京 798 艺术区,是中国最早推动抽象艺术研究与发展的重要艺术机构之一。在长足发展的十余年之后,画廊主理人决定邀请建筑营对其空间进行重新改造设计,以进一步完善使用功能,应对未来的发展需求。 临街立面  ?  金伟琦 798 艺术区是由上个世纪 50 年代建成的电子工厂转变而来的当代艺术空间聚集区,该区域中标志性的混凝土拱窗结构是代表性的建筑元素之一。
