土木在线论坛 \ 建筑结构 \ 钢结构工程 \ 住宅公寓:错落有致的阳台外立面
住宅公寓:错落有致的阳台外立面
发布于:2022-06-10 09:54:10 来自:建筑结构/钢结构工程 [复制转发]
总部位于纽约的建筑工作室ODA透露了Ombelle的设计,这是佛罗里达州劳德代尔堡的两座住宅塔楼。这两座43层的建筑将容纳1100个租赁单元,包括配套设施和零售空间。在建筑的底部,一个城市广场连接着周边地区和弗兰格村。Ombelle综合体是ODA在劳德代尔堡的第二个大型住宅项目。第一个是库什纳大厦,位于同一地区。
New York-based architecture studio ODA has revealed the design of Ombelle, a duo of residential towers in Fort Lauderdale, Florida. The two 43-story buildings will accommodate 1,100 rental units, completed with amenities and retail spaces. At the base of the building, an urban plaza connects the development to its neighboring area and Flanger Village. The Ombelle complex is ODA's second large-scale residential project in Fort Lauderdale. The first one, the Kushner tower, is located in the same district.
两座塔楼的形状,随着它们的上升而相互远离,优化了公寓的视野和自然光的获取。阳台的外壳在深度、长度和排列上各不相同,形成了外立面的振动。错落有致的室外阳台和花园确定了塔楼的形象,并给每个公寓一个特殊的视觉身份。
The shape of the two towers, stepping away from each other as they rise, optimizes views and access to natural light for the apartments. The outer shell of terraces varying in depth, length, and arrangement creates a vibration of the fa?ade. The staggered outdoor balconies and gardens define the image of the towers and give each apartment a particular visual identity.
双层高的柱廊标志着建筑的周边,将其与城市广场连接起来。这创造了室外和室内空间之间更令人愉快的过渡。作为对活跃社区的回应,一层提供了11000平方英尺的商业空间,用于零售和餐厅,可以进入露天座位区。
A double-height colonnade marks the perimeter of the building, connecting it to the urban plaza. This creates a more enjoyable transition between outdoor and indoor spaces. As a response to the active neighborhood, the ground floor offers 11,000 square feet of commercial spaces for retail and restaurants with access to open-air seating areas.
轴测分析图
建筑师:ODA
地点:美国
钢结构工程
46.53 万条内容 · 1223 人订阅
国内最大单边悬挑结构,微信总部大楼钢结构施工迎来关键节点
在美丽的珠江河畔 中建二局承建的   腾讯广州总部大楼   项目 未来的   微信总部大楼 迎来关键节点—— 项目外挑达28m、重达750t的 屋顶悬挑安装完成 这也标志着承载项目花园、山丘、村庄
