△ 实践大楼 ?Iwan Baan
The Royal College of Art campus in Battersea delivers a formula for education, research, and entrepreneurship that explores the creative possibilities at the intersection of science, the arts, and design. It is a flexible architectural solution that adapts to the constantly changing programmes of teaching and research at this 185-year-old institution, with the aim to unite and strengthen the culture of design innovation and entrepreneurialism at the Royal College of Art (RCA).
场地位于巴特西创意区现有RCA巴特西大楼南侧的城市街区。项目提供了1.55万平方米的工坊、工作室与研究空间;底层的工坊与制造设施共同组成沿豪伊街的4层实践大楼,沿着公园门路则设有一栋8层高的研究大楼。豪伊街将成为进出巴特西校区的主要通道。
The site occupies the urban block to the south of the existing RCA Battersea buildings within the Battersea Creative Quarter. The project delivers 15,500 sqm of workshop, studio and research space; it is composed of a ground floor base of workshops and manufacturing facilities supporting a low-rise 4-storey Studio Building along Howie Street, and a taller 8-storey Research Building prominently located along Parkgate Road. Howie Street will become the main thoroughfare for the combined RCA Battersea Campus.
工坊与工作室的砖砌纹理和大型北向天窗,为巴特西桥路带来独特且融合的视觉形象。研究大楼的金属翅片则为校园带来独特的天际线景致。
The textured brickwork and large, north facing clerestory lights of the workshop and studio building present a unique yet contextual profile to Battersea Bridge Road; the metal fins of the Research Building offer a distinct skyline identity for the campus.
连接性与灵活性
工坊是RCA活动的核心。工坊空间被设计成一系列相互连接的体量,上部的工作室空间横跨悬空于工坊之上,将工作室与研究空间的入口包含其中。
The workshop is the nucleus of RCA activities. Workshop spaces are arranged as a series of interconnected volumes, over which the upper studio spaces span and overhang, and incorporate the entrances to the studio and research spaces.
临街层的体量被设计成为一条通道,与豪伊街现有的RCA校园建筑相连,也打通了穿过场地的视野,与此同时,大扇的开窗也提供了与工作室间的视景连接。上部悬空的体量为工作室层,为临街层带来有遮蔽的通道及座位区,也在上部带来了阳台与露台空间。
The street level arrangement of volumes forms a passageway that connects the existing RCA buildings along Howie Street and allows for views through the site and large picture windows provide visual connections to the workshops. The overhanging volume of the studio levels above provide covered walkways and sheltered seating areas at street level, as well as balconies and terraces above.
△ 实践大楼外观 ?Iwan Baan
早先封闭的拉德斯托克街的一部分被纳入底层;工作室层横跨于该空间之上,形成了一个双层高度的“机库”——一个用于制作和展示大型作品的灵活区域,其空间也足以举办RCA的集会和活动。这里还可以面向公众开放,形成从豪伊街到校园主要接待区的另一条通道。
A portion of the previously closed-off Radstock Street is incorporated into the ground floor; upper studio floors span across this space to create a double-height “Hangar” – a flexible zone for the production and display of large-scale work that is also spacious enough to host RCA assemblies and events. This space can also be opened to the public, creating another thoroughfare from Howie Street to the main reception area of campus.
工作室层的地面为三阶梯段式设计,每一阶都包括了约2000平方米的高品质工作空间。这些空间内也设置了灵活的基础设施,可以适应RCA的一系列功能所需。除了为室内工作室提供自然采光和新鲜空气外,混凝土楼板还向外挑出形成外部走廊,既有遮阳与自然通风之效用,也能为在楼内工作的人们提供与户外的直接联系。
The studio floors provide a series of three terraced floorplates, each comprising approximately 2000 sqm of high-quality workspace. These spaces contain a flexible infrastructure that can be adapted to a range of RCA programmes. In addition to the essential qualities of natural light and air supplying the indoor studios, the concrete floorplates extend to form cantilevering external galleries, providing shade and natural ventilation, and an immediate connection to the outdoors for those working within.
The Research Building is organised above the ground floor workshops as a cubic stack of seven 560 sqm floorplates. Sharing the principles of the studio floors, each space is a flexible research unit equipped with provisional laboratory space. Innovation RCA, the burgeoning post-graduate business incubator, is located on levels 5 & 6. Level 7 contains an event space and terrace with views towards the North and to the rest of the RCA campus.
粗 野 材质
为了使其成为一个高效且灵活的容器,适应不同的工作模式,巴特西校区选择的材料也是简单且坚固的。室内由混凝土板组合而成,铺设在8米长的灌有混凝土的钢管网格上,可调整的服务设施也直接展露在空间中。
To support its role as an efficient and flexible container that can adapt to different modes of working, the materiality of the Battersea campus is simple and robust. The interiors are formed from a combination of concrete flat slabs supported on an 8 m grid of concrete filled steel tubes, with an exposed and adaptable services arrangement.
底层的立面由简单的弗拉芒邦德砖构成,部分区域采用了镂空砌法,为可移动玻璃屏风后的工坊和雕塑工作室提供自然通风。在工作室层的上部,底层的砖砌图案被反转过来,以独特的纹理展示砖块的加工痕迹。
The ground floor fa?ade is formed from a simple stock brick in a textured Flemish bond, perforated in areas with open patterned brickwork to provide ventilation to the workshop and sculpture studio behind operable glass panels. On the upper studio storeys, the ground floor brick pattern is turned inside-out, exposing the cut ends of the header bricks and marks of manufacture through a distinctive texture.
研究大楼没有采用同样的砖砌设计,而是将弯曲的白色翅片垂直组合,通过在整个外立面上进行校准,以减缓太阳辐射与眩光,同时促进内部的自然通风。
The Research Building departs from the masonry language with a vertical composition of sinuous white fins, calibrated across the fa?ade to moderate solar gain and glare, and facilitate natural ventilation to the workspaces within.
环境适应力
建筑已经达到BREEAM的优秀评级。其高效的形式结合耐用的低维护材料及适应性强的服务组织,旨在于灵活的围护结构内提供精确的日照控制、热绝缘与自然通风特性。
The building has achieved a BREEAM Excellent rating. Its efficient form is derived to deliver the correct levels of daylight control, insulation, and natural ventilation within a flexible envelope, combined with durable, low maintenance materials and adaptable services organisation.
裸露在外的混凝土结构中加入了高含量的水泥替代物,在被动式设计的基础上,为内部空间提供额外的热增益。此外在实践大楼的屋顶上还有一个大型太阳能电池板,设置于“蓝色”与“棕色”的屋顶之间,可减轻整体能源负荷,帮助建筑满足可持续的排水需求,并促进更广泛的生物多样性。
The exposed concrete superstructure has a high content of cement replacement, and its mass provides additional thermal assistance to the passive interior. In addition, there is an extensive solar array located on the roof of the studio building to ease overall energy loads, set within a combination of ‘blue’ and ‘brown’ roofs to assist with sustainable drainage requirements and promote greater biodiversity.
完整项目信息
免费1人已点赞
砖混结构
返回版块10.12 万条内容 · 458 人订阅
江苏园博园珍宝博物馆折叠的屋面 ? 侯博文 折叠的立面 ? 侯博文 江苏园博园珍宝博物馆(以下简称珍宝馆)位于江苏园博园园区最北侧,功能为传统和民间艺术及工艺品展示,建筑占地面积 15000 平方米,总建筑面积约 15500 平方米。 珍宝馆位于园博园边缘的地块有着极具冲突的周边环境——北侧紧邻京沪高铁线,不断有高铁穿梭而过; 南侧隔河相望为 VOCO 园博村酒店,是静谧宜人的小尺度村落感公寓式酒店。
