土木在线论坛 \ 园林景观 \ 景观规划设计 \ 空间赋能城市美好生活 【莫斯科河堤公园】
发布于:2022-05-23 14:41:23 来自:园林景观/景观规划设计 [复制转发]
Basis工作室六年以来一直致力于Vavshhinskaya Poyma河堤项目,在项目的开始阶段,工作室举行了公开听证会,并与当地居民积极合作。Basis 工作室也因此从居民那里得到了很多积极的反馈意见,这些要归功于居民们对项目高质量的参与和实施。建筑师设法在居民和开发商之间找到了共同点,并积极引导设计过程。
Basis studio has been working on the Pavshhinskaya Poyma embankment project for the past six years and is continually working on it. In the initial stage of the project, the studio held public hearings and worked actively with the residents of the area. Basis studio has received a lot of positive feedback from users of the public space thanks to civic engagement and the high quality of the implemented project. The architects managed to find common ground between residents and real estate developers and channel the situation in a positive direction.
Pavshinskaya Poyma河堤的设计和功能是由环境决定的。它是两个大型集群之间的“缓冲区”:密集的住宅开发项目,以及位于河对岸的大型购物中心和展览馆。该地区被附近的居民用作社区花园空间,被克拉斯诺戈尔斯克的居民用作市区。这些具有不同利益的群体的需求必须细化,同时创造出一个所有群体都可以使用的公共空间。
functions of the embankment in Pavshinskaya Poyma are determined by the context. It is a 'buffer zone' between two large 'clusters': the dense residential development without courtyards and the large shopping and exhibition complex located on the opposite side of the river. The area is used by the residents of the neighbourhood as a community space and by the residents of Krasnogorsk as a downtown area. These groups with different interests had to be separated while creating universal elements that all groups could use if they wished.
例如,阶梯采用符合人体工程学的形状靠背设计,具有不同的倾斜度,人们可以像使用躺椅上一样舒适地坐卧。附近居民可以在这里使用笔记本电脑工作、享受日光浴或做瑜伽,而那些来散步的人则可以坐在这里,聆听晚上的音乐会,与人群互动或在水边放松。
The amphitheatre, for example, is designed with ergonomically shaped backrests with different inclinations making it comfortable to both sit on and lay back as on a lounge chair. Residents from nearby can work on their laptops, sunbathe or do yoga, while those who come for a walk can listen to an evening concert, meet friends or just relax by the water.
海滨长廊设有宽窄不同的几个区域。广阔的区域具有许多特色功能空间:带有长凳和老柳树的绿色空间、种着小树的太阳椅、水边野餐区、阶梯等。较窄的区域负责交通系统,涵盖步行区,跑道和照明系统。
The promenade is designed with a variety of wide and narrow zones. The wider areas have different functions: a green space with benches and old willow trees, sun loungers with new trees, picnic areas by the water, an amphitheatre. The narrower areas are transit, with only a pedestrian zone, a running track and illumination.
Basis工作室负责人Ivan Ohapkin称:“我们希望营造出一种穿过长长的走廊,豁然开朗,进入新房间的感受。除了视觉多样性之外,这样的交通区域还可以避免地方过度饱和,并使关键景点不那么拥挤。如果没有区分不同的区域,两个城市化“集群”之间的长廊将变得人满为患,不再舒适。我们通过建造一条上下分隔的长廊来分隔行人流量,该长廊穿过宽阔的道路,易于进入。
Ivan Ohapkin, head of the Basis studio: 'We created this feeling of entering a new room through a corridor. In addition to visual diversity, such transit areas make it possible to avoid oversaturating the place and to make the key attraction points less crowded. Without the different zones, the promenade between the two urbanised 'clusters' would become overcrowded with people and functions, making it an uncomfortable place to be in. We have separated the pedestrian flows by making an upper and lower promenade, which is easy to access with an extensive pathway system."
▽夜景
设计强调了空间的自然感觉:保护了原有的健康树木,种植了新的防潮枫树和柳树,它们将很快能够提供阴凉,同时营造出充满活力的氛围。设计使公园更亲水,可供人们在水边野餐或坐在河边休息。
The design emphasises the natural feel of the space: healthy trees have been preserved and new moisture-loving maples and willows have been planted, which will soon provide shade meanwhile creating a lively atmosphere. It's easy to access the water, where you can have a picnic or just sit by the river.
铺装图案的灵感来自河流的自然渐变感,从水边较暗的色调轻轻地变为岸边较浅的色调。路面图案中的涟漪与水中的涟漪相呼应。挡土墙使用带有几何图案的拱形混凝土,强调光影的作用。
The paving pattern is inspired by the natural gradient of the river, changing gently from darker tones by the water to lighter ones by the shore. The ripples in the pavement pattern echo the ripples in the water. The retaining walls use arch concrete with a geometric pattern, emphasising the play of light and shadow.
▽铺装图案
下方的新河堤大大方便了高层建筑的庭院(安静区)进入公共空间点。该地区的建筑物之间有强风。考虑到这一点,工作室设计了带秋千的蜂巢形凉棚,其主要功能是减少风力,提供遮挡阳光和雨水的庇护所。合理的景观设计非常重要,团队在庭院周围种植了大量的金字塔形杨树,以保护它免受风和噪音的影响。设计师还定制了具有复杂参数的长凳、低舞台区域和铺装,以契合场地的设计理念。
The new lower embankment makes it easy to access any point of public space from the courtyards of the high-rise buildings (the 'quiet zone'). The quiet zone was the first to be designed; this area has strong winds between buildings. With this in mind, the studio designed beehive-shaped pergolas with swings, whose main function is to diminish the winds and provide shelter from sun and rain. It was important to accurately design the landscape: a large number of pyramidal poplar trees have been planted around the perimeter of the courtyard to protect it from wind and noise. The studio also designed bespoke complex parametric benches, low stage areas and paving to suit the design concept for this area.
▽平面图
▽轴侧图
▽景观节点
景观规划设计
25.18 万条内容 · 282 人订阅
中式庭院,圆
月圆人团圆 是每一个人的渴求 然而总是有那么些原因 让你与你在意的人分割两地 于是明月寄相思 月是故乡明
