土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 小体量狭窄地块:精品酒店立面
小体量狭窄地块:精品酒店立面
发布于:2022-05-13 14:20:13 来自:建筑结构/混凝土结构 [复制转发]
这家精品酒店位于克拉科夫的卡齐米尔兹的Warszauer街10号,这里曾是犹太区,也是克拉科夫最具吸引力的旅游区之一。酒店建筑位于一个狭窄的临街地块上,位于旧的4层公寓和17世纪的Kupa犹太教堂之间,但与现有的市中心相得益彰。
The boutique Warszauer Hotel has been opened at 10 Warszauera Street in Krakow's Kazimierz, the former Jewish district and one of Krakow’s most attractive tourist districts. The hotel building is located on a narrow frontage plot between an old 4-story tenement house and the 17th-century Kupa Synagogue, but complementing the existing downtown development.
该设施的位置在这样一个享有盛誉的地方,要求建筑师特别注意建筑物的环境。在附近,除其他外,还有旧犹太公墓,也被称为 Remuh 公墓,作为 Kazimierz 或 Szeroka 街的中心的 Plac Nowy 与旧犹太教堂,这是犹太宗教最重要的纪念碑之一欧洲的建筑。这座五层楼的建筑与现有的开发项目无缝融合;它的高度与邻近的唐楼对齐,从而补充了街道的视角。
The location of the facility in such a prestigious place required architects to pay special attention to the context of the building. In the immediate vicinity, there are, among others, the Old Jewish Cemetery, also known as the Remuh Cemetery, Plac Nowy serving as the center of Kazimierz or Szeroka Street with the Old Synagogue, which is one of the most important monuments of Jewish religious architecture in Europe. The five-story building blends seamlessly into the existing developments; its height is aligned with the neighboring tenement house, thus complementing the perspective of the street.
这是一个非常狭窄的地块,面积只有141平方米,位于一栋公寓楼和犹太教堂之间,很大程度上决定了建筑的投影形状。投资者要求建筑师为一个面积仅600平方米的豪华精品酒店设计广泛的设施。它通过其卓越的建筑、功能和内部舒适,从该地区的其他酒店设施中脱颖而出。
A very narrow plot of land with an area of only 141 m2, located between a tenement house and the Synagogue, largely determined the shape of the building's projection. Investors asked the architects to design extensive facilities for a luxury boutique hotel on an area of just 600 m2. It was to stand out from other hospitality facilities in the area through its remarkable architecture, functionality, and interior comfort.
建筑主体由两部分组成。前面的有山墙屋顶,后面的有平屋顶。后部的形状是根据邻近建筑的自然光要求和遵守消防规定的需要而确定的。尽管后面的露台形式和高度不同,但整个设计是一致的,内部的所有分区都是不可察觉的。
The body of the building consists of two parts. The front one with a gable roof and the lower rear construction with a flat roof. The shape of the rear part was defined by the requirements for natural light in the neighboring buildings and the need to comply with fire regulations. Despite the difference in height and the terrace form of the rear, the whole design is consistent, and inside all divisions are imperceptible.
建筑的主立面和入口位于Warszauera街的一侧,它与邻近的出租房屋轻轻地分开。它具有极简主义和纯粹的形式,不干扰周围建筑的历史特征。从主立面,它通向一个带有接待区、社交设施和技术室的大厅。
The main facade and entrance of the building are via the side of Warszauera Street, and it gently stands apart from the neighboring tenement houses. It has a minimalist and pure form that does not disturb the historical character of the surrounding buildings. From the main facade, it leads to a hall with a reception area, social facilities, and technical rooms.
在一层,也有一个公共餐厅,为酒店客户和邻近的房间。酒店房间都有私人浴室,位于 1到 4层,可以通过楼梯直接进入。顶层包括两层公寓和一个公共观景平台。
On the ground floor, there is also a communal dining room for hotel clients and adjacent rooms next to it. The hotel rooms all have private bathrooms, are located on floors 1 to 4, and are accessible directly via a staircase. The top floor consists of two-level apartments and a public viewing terrace.
现代白色字形上的阴影与大尺寸窗户的反射相结合,创造了酒店外观在白天和季节中不断变化的外观。明亮的正面立面从对比鲜明的黑暗底层清晰地脱颖而出。隐藏的入口门无缝地流入高窗玻璃的角落。塑造正面立面的风格模仿了历史建筑中使用的分区和节奏,但以现代的方式。
The play of shadows on contemporary white glyphs combined with the reflections in large-format windows creates a constantly changing appearance of the hotel exterior throughout the days and seasons. The bright front elevation stands out clearly from the contrasting dark ground floor. The hidden entrance door flows seamlessly into the corner of the high window panes. The style of shaping the front elevation imitates the divisions and rhythms used in historic buildings, but in a contemporary manner.
前立面覆盖着由可丽耐制成的均匀的三维结构,并用大窗户切割,让自然光进入室内,并直接与周围的街道和建筑物相连。由于使用了杜邦? 可丽耐? 材料,在塑造前立面时可以实现充分的创意自由,这是一种先进的丙烯酸矿物材料,整个横截面颜色均匀。它也是一种无孔、光滑、抗紫外线的材料。
The front elevation is covered with a homogeneous, three-dimensional structure made of Corian, cut with large windows allowing natural light to the interior and directly connecting with the surrounding streets and buildings. Full creative freedom in shaping the front fa?ade was possible thanks to the use of DuPont ? Corian? material, which is an advanced acrylic mineral material with uniform color throughout the cross-section. It is also a non-porous, smooth, and UV-resistant material.
使用的材料是波兰用于建筑物外部装饰的创新解决方案。建筑立面造型的建筑方法是对历史建筑的当代补充,可能成为设计这类建筑的一种新方式。
The material used is an innovative solution in Poland for the external finishing of buildings. The architectural method of shaping the facade of the building is a contemporary complement to the historical buildings, which may become a new way of designing these types of buildings.
区位图
平面图
剖面图
建筑师:INDO Architekci
地点:波兰
面积:141平方米
年份:2021
140.17 万条内容 · 2232 人订阅
瑞典创新应用:木构集成外墙在装配式混凝土结构项目的应用
[摘  要]  通过瑞典Bjerking总包公司某装配式建筑项目考察,了解混合结构的应用案例,展示现场施工状况,分析混凝土双面叠合剪力墙结构和木构集成外墙组合应用的特点、优势及适应性。 [关键词]  瑞典项目;装配式建筑;木构集成外墙;组合结构; 工业化生产;装配化施工;建筑工业化;双面叠合墙;叠合楼板  0 引言
