土木在线论坛 \ 装修设计 \ 公装设计 \ 在海底的度假酒店(特大卧室、起居区、浴室和步入式衣橱,样样俱全)
发布于:2022-05-11 09:54:11 来自:装修设计/公装设计 [复制转发]
马尔代夫康拉德酒店的 Muraka 海底住宅是一个两层结构,由海平面以上的空间和设计用于在海面下睡觉的海底套房组成。海底套房设有特大号卧室、起居区、浴室和步入式衣橱。海底卧室地板位于海平面以下 5 米(16.4 英尺)处,可一览无余地欣赏周围海洋环境,并享有印度洋错综复杂的海洋生物奇观的全景。
The Muraka at Conrad Maldives, the undersea residence is a two-level structure consisting of space above the sea level and an undersea suite designed for sleeping under the ocean's surface. The undersea suite features a king-size bedroom, living area, bathroom, and walk-in closet. The undersea bedroom floor level sits five meters (16.4 feet) below sea level, providing uninterrupted views of the surrounding marine environment, which boasts panoramic views of the wonders of the Indian Ocean's intricate marine life.
超过一半的墙壁和天花板表面覆盖着7英寸厚的透明亚克力,以视觉上连接外部和套房。水下空间跨度为100平方米,可通过螺旋楼梯和水上起居室的电梯进入。为了尽量减少沉重的钢和混凝土的不可避免的外观,大部分室内空间用皮革装饰,地板上覆盖着地毯,这样,声音的回响也被最小化。
More than half of the wall and ceiling surface is covered with 7” thick clear acrylic to visually connect the outside and the suite. The underwater spaces span 100 square meters and are accessed through the spiral staircase and an elevator from an overwater living room. In order to minimize the inevitable appearance of heavy steel and concrete, the majority of the interior spaces are upholstered with leather, and the floor is covered with carpet, with which, sound reverberation is also minimized.
室内设计和饰面的许多细节都受到飞机豪华客舱的启发。内部的每个部分都经过仔细测量、调制、模拟和安装。尽管这是该地区唯一的水下卧室,但自动隐私屏幕已集成到所有窗户中,并通过平板电脑和照明系统进行控制,类似于豪华飞机客舱中的照明系统。
The interior design and much detailing of finishes were inspired by airplane luxury cabins. Every part of the interior was carefully measured, modulated, mocked up, and installed. Despite the fact that this is the only underwater bedroom in the region, automated privacy screens are integrated into all windows and controlled with a tablet in conjunction with a lighting system, similar to ones in luxury airplane cabins.
马尔代夫以其原始的海滩和大海而闻名。海洋的景色令人叹为观止,但这只是马尔代夫美景的一半。另一半存在于水下。即使不潜入海中,也值得向游客展示的水下生态系统。创造安全的地方,人们可以平静地观察海洋生物,这将有助于引起人们对海洋正在发生的事情的关注,认识到变化,并获得灵感。
The Maldives is known for its pristine beach and sea. The views of the ocean are breathtaking, but that’s only half of the Mal divian beauty. The other half exists underwater. There is an underwater ecosystem that is worth showing to the visitors without diving in the sea. Creating safe places where people can calmly observe marine life would help draw attention to what is happening to the sea, recognize the changes, and get inspired.
平面图
剖面图
建筑师:Yuji Yamazaki Architecture
地点:马尔代夫
面积:800平方英尺
年份:2018
公装设计
8.03 万条内容 · 210 人订阅
19个民宿设计的创意,看完我心又飞了!
民宿设计 Hosel Design 民宿设计,不论是重建或扩建、运用设计的加法或减法、还是采用在地材料, 不仅能使荒废破旧的乡下老宅焕然一新,也能重塑一方水土。 01 石与木完美结合 坂茂设计的这家日本民宿  Art Biotop Suite Villa,是它是一个分支式的住宿设施,位于栃木县那須郡。 木结构为主体的客房沿着溪流排布,带有大开口的滑动门让内部将与露台相连。从而形成室内和室外空间的连续,设计师利用施工现场挖掘的石块砌筑外墙,充分发挥在地性。
