土木在线论坛 \ 电气工程 \ 电气工程原创版块 \ swichcraft音频连接器
swichcraft音频连接器
发布于:2022-05-07 10:11:07 来自:电气工程/电气工程原创版块 [复制转发]
?蓬生电子代理销售swichcraft音频连接器,主要产品系列如下KEYBOARD SWITCHES IBS Miniature Switches Series 98000R Keyboard Switch PushbuttonsPCL722AUniswitch?SWITCHES Series US- Non-Illuminated and Series LUS- Illuminated "Adjusto-Clip" MountingBox Switch?SWITCHES Series BXRButton-Switch?SWITCHES Series 903, 913, 923 and 933Tini-Switch?SWITCHES Series 950 and 960Littel-Switch?SWITCHES Series 100, 100S, 200, 200S and Lamp AdapterHi-D Switch?PC MOUNT SWITCHES Series H-100, H100PC, H-200 and H-200PC"DA-Switch" SWITCHES Series DAFF?SWITCH AND NF?SWITCH Series 1000 and 4000Cord-Switch?CORD SWITCHES Series E900, ED900 and EP900Cordette?CORD SWITCHES Series 921Push-Lite?SWITCHES AND INDICATORS Series PL9000-PL?Indicators, Pushbutton/Indicator Screens, Optional Mounting Barriers, Color Filter Snap-Inserts, Light DividerSLIDE SWITCHESGENERAL PURPOSE SLIDE SWITCHES Series 46200E, 46200R - 2 Position Series 46300R - 3Position Series 47200E, 47200R - 2 Position Series 49300 - 3 Position Series 50200 - 2 PositionMINIATURE SLIDE SWITCHES Series 56200, C56200 - 2 Position Series 56300, C56300 - 3 Position Series C63200 - 2 Position, 4 PoleSIDE/SLIDE?MINIATURE SLIDE SWITCHES Series 62200 - 2 PositionEUROPEAN LINE VOLTAGE SELECTOR SWITCHES Series EPS1, EPS3, EPS4 - 2 PositionLEVER SWITCHES Lever-Lite III Series 84000 Lev-R Switch Series 3000, 13000 Lev-R Switch Series 12000 Telever Switch Series 6000, 16000 LT Switch Series 41000 Knobs Lev-R Switch Series 28000 Feather-Lever Switches Series 29000STACK SWITCHES .375" and .25" Stack Switches,Miniature .188" Stack Switches, and Telephone Relay Type Switches微信图片_20220507092514.jpg微信图片_20220507092525.jpg微信图片_20220507092531.jpg微信图片_20220507092537.jpg微信图片_20220507092543.jpg
接地电阻柜是如何运作的?
有的变频器开关电源,会造成一定的干扰,电源线及电机线就是干扰器的天线,地线接地不良则干扰信号,也可通过接在外壳的地线发出去。接地电阻柜厂家介绍线路越长则干扰范围就越大,大功率电阻柜不仅干扰周围的电子设备,也可干扰变频器本身。 有的变频器在防止干扰信号辐射及输入下了一定的工夫,变频器不会经常误动作,一些偷工减料的变频器,则有时因干扰问题令你头痛,如果你的控制系在使用变频器的同时,还有一些靠模拟信号、脉冲信号通讯的电子设备,如电脑,人机界面、感应器等,在选购变频器及布线时就要很小心。
