土木在线论坛 \ 电气工程 \ 工业自动化 \ 10073C安捷伦500MHZ示波器探头
发布于:2022-05-02 18:24:02 来自:电气工程/工业自动化 [复制转发]
Agilent 10073C示波器探头
10073C安捷伦500MHZ示波器探头 JIANG
Bandwidth: 500 MHz System risetime (calculated): <700 ps Attenuation Ratio: 10:1 Input resistance: 2.2 MΩ (when terminated into 1 MOhm)
The Agilent 10073C passive probe is our most rugged 500 MHz probe. With a 10:1 attenuation ratio and high 2.2 M ohm input impedance, it is ideal as a general purpose, high bandwidth passive probe for the Agilent 300 MHz - 1 GHz 6000 series, 7000, 8000 and 9000 Series oscilloscopes. The probe identification feature automatically configures the oscilloscope for the probe attenuation.
The following accessories are included: retractable hook tip; orange, white, blue and green identification tags; ground bayonet, IC probing tip, adjustment tool and an alligator clip ground lead.
· Bandwidth: 500 MHz
· System risetime (calculated): <700 ps
· Attenuation Ratio: 10:1
· Input resistance: 2.2 MΩ (when terminated into 1 MOhm)
· Input capacitance: ~12 pF
· Maximum input (dc peak ac): 500 V CAT I (mains isolated) 300 V CAT II (post receptacle mains)
· Compensation range: 6 - 15 pF
全部回复(3 )
  • 放水发电
    放水发电 沙发
    这是一个很不错的学习参考资料, 但是表述的还是过于简单,未提供相应参数及技术要求等, 建议上传一些附件技术资料(如CAD外形尺寸图和对应的型号规格及技术参数等,以方便设计人员选用), 不过这里还是要谢谢楼主能发布和分享出来给大家学习和参考使用! 同时希望大家参与补充/提供相应资料图纸等
    2022-05-03 06:57:03
  • 放水发电
    放水发电 板凳
    2022-05-03 06:57:03
工业自动化
17.93 万条内容 · 389 人订阅
N2890A无源探头Keysight
KeysightN2890A无源探头 AgilentN2890A 无源探头,10:1,500 MHz,1.3 米 蒋 KeysightN2890A  主要特性与技术指标 * 带宽:直流 ~ 500MHz * 上升时间:700 ps(10%-90%) * 衰减率:10:1 * 输入电阻:10 M?(端接 1M?) * 输入电容:~11 pF * 输入:300 V RMS(或 >400Vpk)CAT I 和 CAT II
