土木在线论坛 \ 装修设计 \ 公装设计 \ 城市更新:魔幻意象的室内设计——上海杨浦滨江制皂厂空间改造
发布于:2022-04-28 14:19:28 来自:装修设计/公装设计 [复制转发]
上海·杨浦滨江制皂厂空间改造
蘑菇云设计工作室
▲  历史上的杨树浦工业区 ? Virtual Shanghai
皂主题空间叙事线的设定
上海杨浦滨江是指杨浦区从西面的秦皇岛路至黎平路、绵延 5.5 公里沿黄浦江的滨江带。杨浦滨江是在世界范围内工业遗存最大、也是保护较好的区域之一。上海制皂厂创建于 1923 年,坐落于杨浦区临近江边的杨树浦路。此次改造项目位于于原上海制皂厂生产辅助区,南临黄浦江,由陆域景观与水域码头组成。
陆域部分的西侧原为生产区与辅助区,设计以原始墙基为线索,砌筑红砖矮墙,还原历史空间格局,形成半开半合的庭院;同时通过浮起的钢栈道连通各处,达到移步换景的效果。东侧部分由原生产车间中压水解楼及污水净化池(调节池、格栅池、生物转盘池、气浮池、次氯酸钠池、观测楼)组成。
Shanghai Yangpu Riverside development stretches 5.5 kilometers long from Qinhuangdao Road to Liping Road at the west of Yangpu District. It is one of the largest and most well-preserved industrial heritage worldwide. Founded in 1923, Shanghai Soap Factory is located on Yangshupu Road near the Huangpu River. This renovation project is set on the production auxiliary area of the former Soap Factory, south-facing to the Huangpu River, with an adjacent landscape and water wharf. The west side of the project site was originally the production area and the auxiliary area. The design takes the original wall foundation as a clue and builds a low red brick wall to restore the historical space pattern and form a semi-open courtyard. At the same time, it is connected by a floating steel plank road to achieving the changing sceneries while you walk in the project site. The last part consists of the hydrolysis building and the sewage purification pool. According to previous urban planning, the original pools of the Shanghai Soap Factory were classified to be demolished, thanks to # Atelier Z #, the architect in charge tried their best to preserve the original structures and installed a newly landscaped roof that redefines the way how these pools are being reused. After the renovation, the original industrial relics were given a new look that combines retro and sci-fi that is unique and recognizable.
▲  吹泡泡的小女孩雕塑 ? 夏至
▲  白七咖啡的半户外下沉空间 ? 夏至
▲  生长中的植物,会逐渐“野生化” 白七咖啡的半户外空间 ? 夏至
根据早期的相关城市规划,上海制皂厂的原有水池归入被拆除行列,负责建筑改造与景观设计的#致正建筑工作室#极力保留了这些构筑物,通过增加水池之间管道和上人景观屋面重新确定了这些水池的再利用的方式。建筑改造之后呈现的空间骨骼有力,工业和科幻感对撞,路径设定完整并具电影场景感,是空间条件极具独特性和辨识度的工业遗存空间。
室内设计团队#蘑菇云设计工作室#围绕这个核心特质,注入以制皂主题为核心体验内容的叙事线,结合新媒体手法,完整呈现了制皂主题的魔幻意象室内空间,穿越皂厂历史和当下的时间场景,成为杨浦滨江岸线深受欢迎的公众活动空间。最终完成的室内改造空间被命名为“皂梦空间”,是策划,建筑,景观,室内,照明,展陈等共同协作完成的完整体验路径,制皂流程转化为富辨识度的物理空间,生动串联了咖啡,展示,餐饮,艺术事件,制皂实验室等一系列创意公共活动内容场景。
The interior design team #Supercloud Studio# focused on ‘Soap’ as the main theme of the design, introduced a narrative of soap making as the journey that visitors are going to experience, and combined new media forms to the interior space to present a chanting theme of soap making, traversing the history and the present of the soap factory and made this project a popular public space along the Yangpu Riverside. The renovated interior space is named " Soap. Dream. Space", a collaborative work that results from planning, architecture, landscape, interior, lighting, and exhibition design. The soap-making process is transformed into physical spaces with public arts, displays, as well as coffee, dining in the once soap-making production space, and even taking part in the production in a laboratory.
▲  皂厂空间爆炸图,叙事性的流程体验设定
▲  建筑设计改造之后的现场状况 ? 徐迅君
制皂流程转化为空间体验
在自然中采集的制皂原料,经历一系列的工艺流程后,成为一块皂,使用后又归于大地和河流中。我们尝试用空间形式表达这个线性叙事流程。我们选择了一系列制皂工艺流程的动词,命名了一系列的连续行进空间:注入---混合---萃取---呈现---回归---泡沫,被动式的观看路径反过来激起了观者对场景内容的好奇心和关注度。
五个长短不一2.4米直径的钢制圆筒,联接不同的分镜头空间,每个空间各具鲜明的主题预设场景。圆管除了承载关键的转场功能,也被植入动态可变视觉装置,成为流程的关节空间。
Turn the soap-making process into a spatial experience. The raw materials were collected from nature, after going through a series of procedures, become a bar of soap, and returned to nature after use. We try to express this flow in a spatial form. We chose the significant procedures from the soap-making process, and named the interior spaces after them: injecting – mixing – extracting – presenting – returning – foaming. It stimulates the curiosity of the visitors who walk through the interior spaces which are connected by five steel pipes with diameters of 2.4 meters and a variety of lengths, and each space has its own distinct theme. Additionally, the circular tubes are also key visual elements, with some of them embedded with interactive lighting devices that turn them into key transitioning spaces between the scenes.
▲  管内和管外的庭院交界处 ? 田方方
▲  夜晚场景,进入时的探秘感受 ? 夏至
▲  ? 田方方
▲  可变视觉的设置为空间带来了随时切换情绪及场景的可能性 ? 夏至
第一幕:植觉和注入
恣意蔓生的丛林,隐秘的开关,被水流冲入不可知的前方
皂字拆开,为“白七”,白七咖啡从江边的半户外下沉空间开始,这也是“皂梦空间”的起点。设想中是枝蔓丛生的野生树林环境,被选出的皂荚植物和原料(植觉),被处理后进入输送管道和生产车间中(注入)。
Act 1: Awakening and Infusion ------ Sprawling vegetation washed into an unknown space through a hidden entry. The Chinese character ‘Zao’ as soap disassembled, makes "Bai" and "Qi". Baiqi Café begins from the semi-outdoor sunken space by the river, which is also the starting point of "Soap Dream Space". A natural environment with overgrown vegetation. Raw materials are sent into the pipeline for production, this marks the beginning of our journey - the Injection.
▲隐秘的开关联动,“注入”之前的场景?夏至2
▲管道设置为交互地面屏视觉场景,进入时的动态画面感?夏至3
▲  在暗空间回望“注入”的入口管道 ? 夏至
▲  管道连接了暗空间(混合)和白七咖啡(萃取) ? 田方方
▲  ? 夏至
第二幕:混合和萃取
一些天然物质配方提纯的过程,被再次凝视
制作手工皂的过程往往会带来充满惊喜的时刻———透明澄清的油在碱液的作用下慢慢变得粘稠,伴随着颜色的丰富变化,入模后的等待,脱模,变成一块剔透美丽的透明皂。白七咖啡的空间配方,试图还原这一多少带着魔法体验的提纯过程。
“混合”是一个混沌的暗空间,是原皂厂的搅拌池。日本著名艺术家川添善行设计的大型艺术品《一年/一万年》陈设于此。融入泡沫元素的艺术品,形似钟乳石,是2019年上海城市空间艺术季永久性展品之一 。
Act 2: Mixing and Extracting ----- A process of purification. The process of soap making is full of surprises - clear oil is slowly mixed with chemicals and became viscous, its color changed with different ingredients, then put into the mold, solidifies, turns into a beautiful bar of soap. The spatial formula of Baiqi Coffee attempts to restore this purification process with a somewhat magical experience.
▲  白七咖啡(萃取)内部 ? 田方方
▲  透明亚克力卡座 ? 夏至
第三幕:皂荚岛
一块放大的自然切片,皂荚树长成的岛
白七咖啡馆连接的另一处,是相对独立的皂荚岛展区。各种不同年代出产的肥皂,包裹在一个个肥皂泡型的透明展示球内,“长”在高大的绿色植物丛中。
Act 3: Acacia Island ----- Island of acacia trees, a slice of nature. The other side Baiqi Cafe is the Acacia Island exhibition area. Soaps produced in different eras are placed in translucent soap bubble-shaped display shelves "grown" among the green plants.
▲  白七咖啡(萃取)的吧台酒架 ? 田方方
▲  ? 图漫
第四幕:花食
在巨大花瓣的光影中,带入花食的世界
盛开花朵的样貌,在现实世界中有一种散落、变化、消逝中的美。花也是香皂中常用的原材料,转瞬即逝的花期和香气以皂的形式固存下来,传递着瞬间自身所感受到的情感。蜂花檀香皂是上海制皂厂最受喜欢的经典品牌之一,首创于 1928 年,以天然檀香木为基调,隐隐散逸着茉莉花香和柑橘果香。
花食餐厅的概念,来自花瓣在绽放时刻中的姿态,巨大抽象的花瓣包裹、交叠、穿插在两层高的空间中,围合出独特的光影和氛围。
Act 4: Dine in the Flowers ----- Dine with the light and shadow of petals. The beauty of flowers is transient. It blooms, scatters, and disappears. Flowers are also used as raw materials in soaps. The fleeting flowering period and aroma are preserved in the form of soap, conveying the transient beauty into something we can hold on to. Bee Flower sandalwood scented soap is one of the most popular classics by the Shanghai Soap Factory. It was first created in 1928, based on natural sandalwood, with a touch of jasmine and citrus notes. The concept of the dine-in flower restaurant comes from the blooming petals. Enlarged abstract petals wrap and overlapping in the double-height space, creating unique light, shadow, and atmosphere.
▲  从白七咖啡通过管道望向皂荚岛 ? 夏至
第五幕:制皂实验室
在空游泳池中,亲手制皂
制皂的程序,是提炼又提炼的过程,繁复、琐碎、专注,一如所有心爱之物之铸造。从橙色钢梯盘旋而上,皂梦空间的屋顶空间,一个亲手体验制皂的实验室,一个淡绿的空泳池,一段亲手制皂的时光。
Act 5: Soap Lab ----- Handmade soap in an empty swimming pool. The process of making soap is a process of refining and refining, delicate, trivial, and requires a lot of focus. Circling up from the orange steel ladder, the roof space of Soap Dream Space, a laboratory for a hands-on experience of soap making, is a light green empty swimming pool.
▲  不同年代感的香皂,内置在透明的泡沫球里 ? 夏至
▲  顶部木结构上方是Etfe膜结构 ? 夏至
▲  照明装置“回归” ? 夏至
“皂梦空间”,穿越一个个时空隧道,链接每一个关联空间,最终见证了皂梦的诞生。
In this project one travels through the tunnels of time and spaces, spaces of Yangpu's industrial past, linked to the present, witnessing a story of industrialization.
▲  ? 田方方
▲  抽象的巨大花瓣的形态 ? 田方方
▲  ? 夏至
▲  地面里嵌入大颗的绿色天然石块,隐现的路径和引导 ? 夏至
▲  花瓣的包裹和放空 ? 田方方
▲  ? 夏至
▲  ? 夏至
▲  ? 夏至
▲  ? 夏至
▲  在空游泳池里亲手制皂 ? 夏至
▲  ? 夏至
▲  ? 夏至
从橙色钢梯拾级而上的期待感 ? 夏至
建筑设计改造之后的现场状况 ? 徐迅君
▲从展厅望向皂荚岛的管道,植入了照明装置“回归” – 麓米照明设计的螺旋形灯带和点射状灯点以相反行进方向交叠在一起,制造出时空的虚幻无垠感?夏至
▲花瓣的交叠和围合?夏至
▲超现实的内卷空间?田方方
▲  一层平面图
▲  二层平面图
▲ 白七咖啡(萃取)内部空间爆炸图?蘑菇云设计工作室
▲ 花食空间爆炸图?蘑菇云设计工作室
▲ 皂荚岛(呈现)空间爆炸图?蘑菇云设计工作室
设计公司:蘑菇云设计工作室
类型:室内,工业遗存空间改造,咖啡,展示,线下体验空间,餐饮
地点:上海杨浦滨江平定路1号
业主:上海杨树浦文化创意产业有限公司、上海古好文化发展有限公司
面积:1450 平方米
项目年份:2020 年 9 月
室内设计(蘑菇云设计工作室):徐迅君,杨育青,韩晓煜,崔强松,庞磊,孙文浩,张旭东,季杰,齐诗园,祁飞,俞浩
照明设计(Lumia Lab照明):庞磊
装置设计:庞磊、徐迅君
建筑设计:致正建筑工作室、CONCOM-集良建筑
景观设计:致正建筑工作室、诺恳景观、CONCOM-集良建筑
展览设计:上海现代国际展览有限公司
项目策划(古好文化):席小卷
工程承建团队:上海维方建筑装饰工程有限公司、上海恒盈建设发展有限公司
材料:  水泥漆、无机水磨石、玻璃砖、渐变夹膜玻璃耐候钢板
摄影师:夏至、田方方
公装设计
8.03 万条内容 · 210 人订阅
办公室装修之协调色彩
办公室装修是在满足功能要求的前提下,使各种室内物体??的形、色、光、质等组合得到协调,成为一个非常和谐统一的整体。和谐还可以分为环境及造型的和谐、材料质感的和谐、色调的和谐、风格样式的和谐等等。 和谐能使人们在视觉上,心理上获得宁静、平和的满足。不同办公室装修颜色能引起人视觉上不同的色彩感觉。色调是构成装修造型艺术设计的重要因素之一。在室内装修中,可选用各类色调构成,色调有很多种,一般可归纳为“同一色调、同类色调、邻近色调、对比色调”等,在使用时可根据环境不同灵活运用。简洁是办公室装修中特别值得提倡的手法之一,也是近年来十分流行的趋势。
