土木在线论坛 \ 建筑结构 \ MIDAS \ 求助!求大哥看下钢桁架斜拉桥的模型哪里错了。。。
刚建完模型,然后只是加了个自重算了下看能不能行,结果真出错了。。求各位大哥帮忙看下咋改啊
MULTI-FRONTAL SOLVER
AVAILABLE MEMORY =   11.1 GBYTES
ENTRY PHASE FOR RENUMBERING
ENTRY NUMBERING_EQN
ENTRY FORM_STIFF_MASS_LOAD
THE INDIVIDUAL ELEMENT STIFFNESS AND LOAD MATRICES WILL NOW BE FORMED.
  ELEMENT NO. :  14900  OF   14900
ENTRY SOLUTION PHASE
ENTRY LOAD_BLOCK
TOTAL NUMBER OF VALID DOFS IN MODEL :   62839
ENTRY STATIC ANALYSIS
  MULTI-FRONTAL SOLUTION HAS BEEN PERFORMED 20 % .
WARNING : NODE NO.   3598  RZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      5089
WARNING : NODE NO.  25057  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.     61126
WARNING : NODE NO.    470  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1279
WARNING : NODE NO.    469  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1276
WARNING : NODE NO.  25059  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.     61132
WARNING : NODE NO.    476  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1297
WARNING : NODE NO.    472  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1285
WARNING : NODE NO.  24591  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.     59593
WARNING : NODE NO.  25058  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.     61129
WARNING : NODE NO.    480  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1309
WARNING : NODE NO.    492  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1351
WARNING : NODE NO.  25056  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.     61123
WARNING : NODE NO.    497  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1366
WARNING : NODE NO.    461  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1255
WARNING : NODE NO.  25308  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.     61879
WARNING : NODE NO.    494  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1357
WARNING : NODE NO.  25309  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.     61882
WARNING : NODE NO.  25310  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.     61885
WARNING : NODE NO.    464  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1261
WARNING : NODE NO.  24596  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.     59608
WARNING : NODE NO.    496  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1363
WARNING : NODE NO.    462  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1258
WARNING : NODE NO.  24595  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.     59605
WARNING : NODE NO.    491  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1348
WARNING : NODE NO.    495  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1360
WARNING : NODE NO.    468  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1273
WARNING : NODE NO.    471  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1282
WARNING : NODE NO.  24594  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.     59602
WARNING : NODE NO.    484  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1327
WARNING : NODE NO.    489  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1342
WARNING : NODE NO.    485  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1330
WARNING : NODE NO.    486  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1333
WARNING : NODE NO.    465  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1264
WARNING : NODE NO.    483  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1324
WARNING : NODE NO.  25562  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.     62641
WARNING : NODE NO.    467  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1270
WARNING : NODE NO.    437  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1174
WARNING : NODE NO.  25563  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.     62644
WARNING : NODE NO.  25312  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.     61891
WARNING : NODE NO.  25311  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.     61888
WARNING : NODE NO.    474  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1291
WARNING : NODE NO.    475  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1294
WARNING : NODE NO.  25565  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.     62650
WARNING : NODE NO.    450  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1213
WARNING : NODE NO.    446  DZ  DOF MAY BE SINGULAR.
WARNING : EQUATION NO.      1201
WARNING : NODE NO.  24590  DZ  DOF MAY BE SINGULAR.WARNING : EQUATION NO.      5550
WARNING : NODE NO.   3675  RZ  DOF MAY BE SINGULAR.
  MULTI-FRONTAL SOLUTION HAS BEEN COMPLETED.
  DISPLACEMENT/FORCE/STRESS OUTPUT.
  ELEM. :  14900 OF   14900
-----------------------------------------S O L U T I O N   T E R M I N A T E D
YOUR MIDAS JOB IS SUCCESSFULLY COMPLETED.......E:\毕业设计\模型\无标题
TOTAL SOLUTION TIME..:    12.17 [SEC]
  65588 WARNING MESSAGES ARE FOUND.
        PLEASE CHECK YOUR WARNING MESSAGE FILE  :E:\毕业设计\模型\无标题.OUT
求求了!!!!
全部回答(0 )
MIDAS
5.84 万条内容 · 317 人订阅
