土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 双层表皮立面:大学校园建筑
双层表皮立面:大学校园建筑
发布于:2022-04-26 15:51:26 来自:建筑结构/混凝土结构 [复制转发]
新URCA 总部包含所有中央服务和兰斯香槟阿登大学校长办公室,以前分散,新的 URCA 总部结合了功能效率、灵活性和工作舒适度。
Housing all the central services and the offices of the Presidency of the University of Reims Champagne Ardenne, previo usly dispersed, the new URCA headquarters combines functional efficiency, flexibility, and working comfort.
作为 URCA 为更新和振兴其设施而发起的 Campus 3.0 计划的领导者,这座建筑通过强烈而充满活力的建筑信号体现了它所代表的机构,在一个六分之一的居民是学生的城市。最后,这个致力于教育的主要公共机构的总部位于一个敏感的社区,是向所有人开放的追求卓越冲动的强烈象征。
At the head of the Campus 3.0 program initiated by URCA to renew and revitalize its facilities, the building embodies the institution it represents through a strong and dynamic architectural signal, in a city where one in six inhabitants is a student. Finally, the location of the headquarters of this major public institution dedicated to education in a sensitive neighborhood is a strong symbol of the impulse for excellence open to all.
大学的新总部位于兰斯历史中心西南部的 Croix-Rouge 区,构成了该地区城市更新的结构纽带。这个异质的区域相当稀疏,主要由大型集体住宅区和活动建筑组成,与赛马场接壤。该项目位于两条街道的拐角处,与现有和未来的运营相结合,成为该行业转型的重要杠杆。
Located in the Croix-Rouge district, in the southwest of the historic center of Reims, the new headquarters of the University constitutes a structuring link in the urban renewal of this part of the city. This heterogeneous sector, which is rather sparse, is mainly composed of large collective housing complexes and activity buildings, bordering a racecourse. The project is inserted at the corner of two streets, weaving a continuity with the existing and future operations, becoming an essential lever for the transformation of this sector.
该场地分为建筑体量和一个自由空间,建筑体量由围绕植被岛弯曲折叠的图形组成,而自由空间专门用于通过玩斜坡而展开的花园。在一楼,矿物基地被大厅打断,大厅自然地融入建筑物的角落。
The site is divided between the volume of the building, composed as a figure folded in inflection around an island of vegetation, and a free space devoted to a garden that unfolds by playing with the slope. On the ground floor, the mineral base on which the rest of the level is interrupted by the hall which naturally fits into the corner of the building.
大面积的玻璃,清楚地标志着进入总部的通道。它的处理方式从主立面略微向后退,安装了一个缓坡,使其远离街道。一楼的公共区域(大厅、会议室、餐厅)朝南,朝向花园,并通向宽敞、阳光充足的露台。在上层,四个办公楼层在基地上方旋转。它们完全模块化,旨在根据需求和部门之间的协同作用完全灵活和可扩展。
Largely glazed, it clearly marks the access to the headquarters. Its treatment, slightly set back from the main facade, and the installation of a gentle ramp set it at a distance from the street. The common areas grouped together on the ground floor (hall, boardroom, restaurant) face south, towards the garden, and open onto generous, sunny terraces. On the upper levels, the four office floors pivot above the base. Entirely modular, they are designed to be totally flexible and scalable according to needs and synergies between departments.
尽管该图案是单一的,但对围护结构的差异化处理,其立面根据其方向而有所不同,响应了程序的特殊性。在包围整个建筑的相对光滑的外墙和南部的外墙之间实现了对比和互补的结合,在其上添加了金属遮阳板,形成了双层太阳能保护系统。
Although the figure is unitary, the differentiated treatment of the envelope, whose facades differ according to their orientation, responds to the specificities of the program. A combination of contrasts and complementarity is implemented between the relatively smooth fa?ades enveloping the entire building and the southern ones, to which metal sun breakers have been added to form a double-skin solar protection system.
它们经过精心设计和定向,可调节每个空间的光线以适应不同的活动。在南立面弯曲的角度,罗缎打断了双层表皮的节奏,为室外露台让路。各个楼层都可以使用,它们为居住者提供了额外的交换和休息空间。
Carefully designed and oriented, they modulate the light in each space to adapt to the different activities. At the angle of the flexion of the south fa?ade, a faille interrupts the rhythm of the double skin to make way for outdoor terraces. Accessible on all levels, they offer additional spaces for exchange and breaks to the occupants.
平面图
建筑师:Ameller Dubois
地点:法国
面积:4300平方米
年份:2021
140.17 万条内容 · 2232 人订阅
漂浮的房子, 避风塘宜居
我们希望建筑呼应村落肌理,村落的自由源于建筑跟随场地的肌理变化,建筑可能因为一条河,一棵树,也可能因为一个好的景观面而旋转角度。我们将二层以上住宿空间拆分成三栋独立的小尺度建筑,最好的景观转向水面,通过对采光,通风,景观角度等乡村因素的分析,重新建立起来新的秩序,这种秩序是村落布局最直白的表达。 那朵云在逃,逃离了城市,裙边飘飘到了乡村。在距离苏州半个小时左右车程的地方,位于锦溪镇的最南端,有个经典江南水乡式的小村庄,尚明甸。河道穿梭于村落之间,将村落划分为若干片。
