土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 黄河召主题酒店
黄河召主题酒店
发布于:2022-04-13 10:23:13 来自:建筑结构/混凝土结构 [复制转发]
项目为2010年底由内蒙古砒砂岩旅游开发有限责任公司组织的投标中选方案,在中标后的设计深化过程中由于种种原因遗憾终止。该方案曾于2011年4月正式发布。
准格尔旗黄河召主题酒店总建筑面积68204平方米,其中地上44560平方米,地下23644平方米。
 “站在基地上我们看到的是一望无际的沙漠与生机盎然的黄河湿地的强烈对比关系”
项目主创何威于基地调研时感受到位于对比强烈的环境下建筑应与环境交相辉映,互相强化,如同大漠中耸立的金字塔一样,建筑体量应是及其几何化,能够在空旷视野中成为打破地平线而又能与地貌融合为一的形态。建筑概念由此而生—— 一块砾石从大地中破土而出,经日夜风吹雨打而风化后立于基地之上。
由于场地处于沙漠、湿地、黄河三种不同自然景观的交界处,我们在设计时所面临的最大挑战是:如何协调建筑与环境的关系。
Yellow River Hotel of Jungar Banner, Mongolia by Sunlay Design is a symbol of the unique environment within which it is located. Situated between an endless desert and a lush river the architects used this contradiction to develop a distinct geometric form that is an icon of a rock emerging from the sand and weathered by the elements. The building mass is both above and below ground and posed many challenges in dealing with the relationship between the architecture and the environment.
设计师主要从下面几个方面来入手解决这一问题。
The desig ner used the following methods to address the site context and the architectural intervention:
标识性+融合+强化+视线+触感
标识性  Landma rk:
使用简洁并富有力量感的建筑形式,使其区别于自然的肌理,从而确立建筑在场地中的标识性。
Using simple and geometric massing that stands distinct from nature to create a dominate symbol on the site.
融合  Blending:
建筑的主要材料采用当地特有的石材,由于其色调和质感与沙漠十分接近,使得建筑宛如矗立在沙漠中的巨石。
Taking local stone as main material. This building represents a similar color tone and texture with the desert, which allows the architecture to blend and resemble the a rock in the sand.
强化  Strengthening:
建筑与自然环境的关系是相互强化各自的性格特征。
The building strengthens the habitability of the desert while articulating the characteristics of the site.
视线   Sight:
建筑位置及朝向经过视线分析,不构成景观遮挡。东向酒店房间完全朝向黄河景观,将最好的视点展现给使用者。
The building allows the Yellow River to remain visible on the site and reinforces views of it through the east elevation.
触感    Tactile impression:
通过不同体量的空间组合和不同材料的使用来感知空间的多样性并使人产生丰富的建筑体验。
The experience of the building is enhanced through the use of a combination of different spaces, materials and scales.
▼功能分析图
在建筑远眺黄河及黄河滩湿地的基地环境条件下,主题酒店的设计试图达到观景最优的标准,内部的大厅与外部景观是相连接的,使景观内外呼应,酒店最佳观景面上外壳透明且低能耗,形体层叠而上如宝石般引人注目。被提升到建筑最高点的行政酒廊是高端的集会场所,在这里俯瞰湿地沙漠景观的交汇,并可远眺黄河远去。给人创造了一个振奋人心的场所。会议中心,会展中心,宴会厅依坡而建,与景观自然结合的同时满足功能的需求。
This building stands on the spot where one can overlook the Yellow River and the wetland faraway, and optimizes the view from within the architecture. An interior landscape runs through the building in order to connect the exterior with interior. The cladding on the east part of the building provides full transparency, and thus the best views of the river. VIP rooms located along the eastern elevation are stacked together like crystal, where the rock has been eroded. A large dining hall is placed here, where visitors can overlook the intersection between the wetland and the desert, with the Yellow River flowing in the distance. A conference center and exhibition center are built along the landscape, thereby introducing a natural element into the building.
▼剖透视图
▼ 标准层透视
▼首层透视
▼地下层透视
▼场景设计图
项目信息
地点:内蒙古,准格尔旗小滩子景区
设计时间:2011年
设计单位:SUNLAY 三磊
主持设计:张华、何威
设计团队:刘维炜、傅昌瑞、stefanie helga paul、李杰、陈娜、王国峰
建筑性质:酒店
建筑面积:68204 平方米
业主:内蒙古砒砂岩旅游开发有限责任公司
140.17 万条内容 · 2232 人订阅
弯矩调幅时要求的配箍率下限为什么是0.3ft/fyv ?
