土木在线论坛 \ 建筑结构 \ 钢结构工程 \ 博物馆设计:多面的圆形布局
博物馆设计:多面的圆形布局
发布于:2022-03-30 13:34:30 来自:建筑结构/钢结构工程 [复制转发]
位于即将成为空港城市的金浦机场的国立航空博物馆,是国土交通部为了提高韩国航空产业的地位而推进的多元文化空间。为了创造一个新的博物馆,将成为教育、展览和代表航空工业体验的大厅,三个表达科学、自由、美丽和冒险的理念在设计中得到了体现。
The National Aviation Museum, located in Gimpo Airport which is preparing to become an airport city, is a multi-cultural space promoted by the Ministry of Land, Infrastructure, and Transport to raise the status of the Korean aviation industry. In order to create a new museum that will become the hall of education, exhibitions, and experiences representing the aviation industry, three ideas that express science, freedom, beauty, and adventure were reflected in the design.
首先,以飞机涡轮为主题的“Air Turbine”是一个将机械美学与科学技术相结合的标志性标志,是航空工业的标志性建筑。
第二,“航展”是一个展示韩国航空历史全景的航空画廊,旨在实现一个自由、动感的飞行新范例展示空间。
第三,“空中步道”,一个通过不同高度的平面的三维展览步道,在建筑结构的灯光下创造出更加动态的体验。
First, “Air Turbine”, the motif of which has been adapted from an airplane turbine, is a symbolic icon in which mechanical aesthetics and science technology are integrated as a landmark of the aviation industry. Second, “Air Show”, an aviation gallery, where the history of Korean aviation unfolds like a panorama, is presented in order to realize an exhibition space of a new paradigm that gives a sense of freedom and dynamics of flying. Third, “Air Walk’, a three-dimensional exhibition walkway that flows through the planes of various heights is created for a more dynamic experience in the shining lights of the architectural structure.
该场地规划为多面的圆形布局,位于机场和支持综合体之间的中心位置,包括南部环城公路、配套综合体和主要入口道路(Haneul-gil)在内的各个方向都是正面的。对于永久展览空间,创造了一个三层楼的空隙,以形成一个综合空间,允许通过透明的立面进行户外展览。
The site is planned in a multi-faceted circular layout with frontality in all directions including the southern beltway, supporting complex, and the main entrance road(Haneul-gil), located in the central position between the airport and support complex. For the permanent exhibition space, a three-floor void is created to make an integrated space where outdoor exhibitions are allowed through the transparent fa?ade.
两个不同的建筑,一个被定制为展览空间的圆形展厅,让航空在天空中自由翱翔,一个长方形的管理大楼针对存储、工作和设施等功能进行了优化,与周围环境相得益彰。环保翼型空气涡轮机内部由螺旋展厅组成,以航空廊道为起点,引导参观者在天花板上的平面和动态空间中自然行走。
Two different buildings, a circular exhibition hall that is customized as an exhibition space to have aviation freely flying in the sky, and a rectangular management building optimized for functions such as storage, work, and facilities, are met in harmony with the surrounding environment. The interior of the eco-friendly wing-shaped air turbine is composed of spiral exhibition space as a starting point of the aviation gallery and guides the visitors to walk naturally through the planes on the ceiling and the dynamic space.
区位图
平面图
立面图
剖面图
建筑师:Haeahn Architecture
地点:韩国
面积:18593平方米
年份:2020
钢结构工程
46.53 万条内容 · 1223 人订阅
重庆首个地面TOD:奥雅纳公布化龙桥站-重庆陆海国际中心TOD设计
△ 项目整体效果图  ?Vanke 2022年初,重庆轨道交通9号线一期工程正式开通运营。9号线的开通串联起重庆沙坪坝区、渝中区、江北区和渝北区,接驳三峡广场、化龙桥、观音桥等重要商圈,将有力推动重庆中心城区的经济发展。 在原开发商主导的项目前期规划阶段,奥雅纳团队成功说服重庆市轨道交通集团、当地设计院和项目开发商,将重庆陆海国际中心项目和拟建的化龙桥站,合并成为大型综合TOD,打造重庆首个地面TOD项目。此举所释放的商业价值,远远超过了其最初出任工程师的角色范畴。
