土木在线论坛 \ 建筑结构 \ 结构资料库 \ 带铝肋先张预应力复材筋混凝土梁的长期刚度
发布于:2022-03-30 09:23:30 来自:建筑结构/结构资料库 [复制转发]
《工业建筑》(2021 年第 51 卷第 10 期) 发表题目为“ 带铝肋先张预应力复材筋混凝土梁的长期刚度” 的文章,作者 : 孙瑜、王强、童翊轩、朱虹
摘要
长期黏结性能退化会导致复材筋与混凝土之间的不可控滑移问题,附加铝肋是提高黏结性能的有效方式。为研究铝肋对抑制预应力复材筋混凝土梁长期刚度退化的作用,设计制作了6个试件,依次开展了短期和长期加载试验。通过对比梁端部无铝肋的试件,综合研究了铝肋对长期挠度、复材筋滑移和裂缝发展的影响规律。结果表明:附加铝肋能够显著抑制构件长期挠度的发展,使预应力复材筋混凝土梁保持良好的长期性能;设置了短铝肋(SA)和长铝肋(LA)的试件,相较于无铝肋试件,最大滑移分别减少了81.3%和86.7%,筋材滑移得到有效抑制;无铝肋试件近固定端裂缝宽度增加了323.53%,远大于有铝肋试件,附加铝肋对剪跨区混凝土裂缝发展的抑制效果明显。
关键词: 先张法预应力; 复材筋; 铝合金附加肋; 长期刚度
Abstract
Degradation of long-term bonding performance will cause uncontrollable slippage between FRP bars and concrete. The additional Al-ribs are effective ways to improve bonding performance. In order to study the effect of Al- ribs on restraining the long-term stiffness degradation of prestressed concrete beams reinforced with FRP bars, 6 specimens were designed and fabricated, and short-term and long-term loading tests were carried out in sequence. By comparing the specimens without Al-ribs at the beam ends, the influence of Al-ribs on long-term deflection, slippage of FRP bars and development of crack width was comprehensively studied. The results showed that the additional Al-ribs could significantly inhibit the development of long-term deflection of the members, so that the prestressed concrete beams reinforced with FRP bars maintained good long-term performance. The maximum slippage of the specimens with short Al-ribs(SA) and long Al-ribs(LA) was reduced by 81.3% and 86.7%, respectively, and the slippage of the ribs was significantly suppressed, The crack width near the fixed end of the specimens without Al-ribs was increased by 323.53%, which was much larger than that of the specimens with Al-ribs. The additional Al-ribs had a significant effect on restraining the development of concrete cracks in the shear span area.
Key words : pre-tensioned prestress; FRP bar; additional Al-rib; long-term stiffness
滑动查看部分数据图表
全文下载:
带铝肋先张预应力复材筋混凝土梁的长期刚度.pdf
结构资料库
41.29 万条内容 · 427 人订阅
12j1建筑图集
12j1建筑图集
