土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 145米高大厦:模块化观景阳台立面,一种微妙的方式
发布于:2022-03-28 17:17:28 来自:建筑结构/混凝土结构 [复制转发]
森肯伯格区
Cyrus Moser Architects
森肯贝格区位于法兰克福的博肯海姆区和韦斯滕德区之间。该地区位于原 "AfE-Area "的新街区 "Kulturcampus "的南边。同时,它也连接着相邻社区。2016年,Cyrus Moser被邀请参加新开发项目的国际竞赛并获胜。
The Senckenberg Quarter is located between the Frankfurt districts of Bockenheim and Westend. The area marks the southern end of the new quarter “Kulturcampus” at the former “AfE -Area”. At the same time, it serves as a joint between the adjacent neighborhoods. In the year 2016, Cyrus Moser was invited to participate in the international competition for the new development and won.
▲ 区位图
惊人的立体感和简约的优雅,结合高质量的城市发展,说服了颁奖的组织者。该街区向附近的居民区开放,这种开放的内部城市街区提供了将该地区纳入城市结构和网络的机会。
The "combination of striking cubature and simple elegance, in conjunction with the quality of high urban development", convinced the awarding organizers. The quarter opens up to the neighborhoods nearby, this opening of the inner-city block offers the chance to integrate the area into the urban structure and network.
▲ 体量生成
由于邻近小区的现有步行路线正在使用,它们将通向小区中心的一个中心方向点。在这个中心外,所有的建筑都有代表性的入口和大厅。公共空间是人们聚会和打发时间的地方。 四个元素组合成一个整体:混合式高层建筑、办公楼、另一栋办公楼和一所幼儿园。
As the existing walking routes of the adjacent quarters are being picked up, they lead to a central point of orientation in the heart of the quarter. Out of this center, all buildings open up with representative entrances and lobbies.  Public space is created where people meet and enjoy spending time. Four elements come together to form an ensemble: Hybrid high-rise, office tower, another office building, and a Kindergarten.
西140号。高达145米的ONE FORTY WEST大厦。凭借其生动的外墙,它为法兰克福的天际线增添了一个醒目的剪影。在内部,它将城市的垂直方向--住宅、酒店和美食都放在一个平面里。大厅和餐厅位于底层,2-23层为酒店。15楼的空中酒吧及其壮观的露台向公众开放。从第24层到第40层,在84米的高度上,是公寓的位置。
One Forty West. The 145-metre-high ONE FORTY WEST tower. With its lively fa?ade, it adds an eye-catching silhouette to the Frankfurt skyline. Inside, it takes the city vertically- residential, hotel, and gastronomy all under one roof. Lobbies and a restaurant are located on the ground floor and a hotel on floors 2-23. The Skybar with its spectacular terrace on the 15th floor is open to the public. From the 24th - 40th floors and at a height of 84 meters the apartments are situated.
▲ 手绘图
阳台围绕着大厦伸展,形成一个三公里长的向上延伸的带状。由于其交错安排, 几乎每个公寓都有不同的平面图。 每一个都是复杂的家具,并提供独特的景观落地窗。
阳台由C形模块建成,长度为8.40米,与下一个模块的距离为4.20米。突出的阳台为大厦增加了一个独特的、可识别的特征,并邀请人们生活在一个垂直的社区。
Balconies stretch around the tower in a three-kilometer-long upward-striving band. Due to their staggered arrangement, almost every apartment has a different floor plan. Each is sophisticatedly furnished and offers unique views with floor-to-ceiling windows. The balconies are built from c-shaped modules with a length of 8,40m and a distance of 4,20m to the next module. The prominent balconies are adding a distinctive and recognizable character to the tower and invite the people to live in a vertical neighborhood.
▲  公寓平面
▲ 模块外墙
在高层大厦的底部,定制的混凝土外墙在街道上提供了一个独特的面孔和一定的规模。住在大厦的居民通过一个单独的入口进入大厦。
At the base of the highrise tower a bespoke concrete- fa?ade provides a unique face and a certain scale at street level. Residents living in the tower are entering the tower via a separate entrance.
▲ 阳台效果
森肯贝格大厦。  从视觉上看,该大厦被分为两个部分。通过凹槽,底座、柄部和顶部的划分以一种微妙的方式变得清晰。几层楼被组合成节奏不同的单元。这一原则使我们有可能对每个故事的特殊性作出反应。
在一个梯形的基座上,在Robert-Mayer-Strasse的方向,创造了一个绿色的阳台平台,可以看到法兰克福的天际线,高度约23米。入口大厅有两层玻璃,十分透明和开放。
Senckenberg Tower.  Visually, the tower is divided into two sections. Through the recesses, the division into base, shank, and top becomes clear in a subtle way. Several stories are combined into units that vary in rhythm. This principle makes it possible to respond to the particularities of each story. On a trapezoid-shaped base, in the direction of Robert-Mayer-Strasse, a green roof terrace with a view of the Frankfurt skyline is created at a height of about 23 meters. The entrance hall is glazed over two floors and radiates transparency and openness.
▲ 建筑关系
森肯伯格大厦的立面设计面向西140号,而不与混合大厦竞争。该元素立面由回收的报废铝建造,节省了近2600吨的二氧化碳排放。
The Senckenberg Tower fa?ade design is oriented towards ONE FORTY WEST without competing with the hybrid tower. The element fa?ade was built of recycled end-of-life aluminum and saved almost 2600 tons of CO2 emissions.
▲ 绿色通道
城市内部街区边缘的开放提供了将该地块融入城市网络的机会。利用邻近地区现有的人行道,创造了一个特殊的中心,作为该区的一个定位点。所有的建筑都可以从这个中心进入,有代表性的主要入口。激活屋顶区域,创造绿色空间,以获得更好的空气、温度、声学和生活质量,是高层建筑规划的核心任务,第六层的屋顶露台是员工的一个亮点。
The opening of the inner-city block edge offers the opportunity to integrate the site into the urban network. Picking up on the existing walkways of the neighboring districts creates an identity-forming center that serves as a point of orientation within the quarter. All buildings can be accessed from this center with representative main entrances. The activation of roof areas to create green spaces for the benefit of better air, temperature, acoustics, and quality of life is a central task in the planning of high-rise buildings, the roof terrace at the sixth level is a highlight for the employees.
21西区。21西区办公室作为新森肯贝格区的单独建筑组成部分,塑造了罗伯特-迈尔大街/森肯贝格大街上的城市角落。在这一点上,办公大楼对整体结构有着巨大的影响。
21 West. The 21West Office shapes the urban corner on the Robert-Mayer-Strasse/ Senckenberganlage as the solitary building component of the new Senckenberg Quarter. At this point, the office building has an enormous impact on the overall structure.
光线充沛,六层楼高的接龙式建筑使租户能够发挥其个性化的使用空间。大厦设计成灵活的办公室,无论是单独办公、组合办公还是开放式办公,甚至是三种概念的结合,一切皆有可能,空间最多可容纳380个工作岗位。
为了符合选择性绿色建筑的理念,顶层有一个屋顶露台,面向Senckenberganlage和法兰克福天际线。一个两层楼高的下凹区域界定了宽敞的大厅的入口。西南面的底层有一个餐厅,它面向新的社区广场。
Flooded with light, the six-story solitaire building enables tenants to use their individual use of space. The building is designed to be a flexible office, whether individual, combined or open-plan offices or even a combination of all three concepts, everything is possible with space for up to 380 workplaces.  In keeping with the idea of selectively green buildings, there is a roof terrace on the top floor that faces the Senckenberganlage and the Frankfurt skyline. A two-story undercut area defines the entrance to the spacious lobby. A restaurant is housed on the southwestern ground floor, which faces the new neighborhood plaza.
项目图纸
区位图
平面图
立面生成
建筑师:Cyrus Moser Architects
地点:德国
面积:110890平方米
年份:2021
  • czcivilczcivil
    外形很吸引人,能让人一眼就记住
    2022-03-29 10:40:29
  • 放水发电
    放水发电 板凳
    这是一个很不错的学习参考资料, 但是表述的还是过于简单,未提供相应参数及技术要求等, 建议上传一些附件技术资料(如CAD外形尺寸图和对应的型号规格及技术参数等,以方便设计人员选用), 不过这里还是要谢谢楼主能发布和分享出来给大家学习和参考使用! 同时希望大家参与补充/提供相应资料图纸等
    2022-03-29 07:25:29
140.17 万条内容 · 2232 人订阅
独特的平面布局,阁楼式的住宅建筑
Anton-Schall-Gasse的住房是位于维也纳Floridsdorf区边缘的社会住房,这是一个城市融于乡村的地方。该项目将经济适用房注入到一个灵巧的、引人注目的雕塑解决方案中,以满足一个特殊的场地。 北面的地块面向Marchfeld运河周围的林间牧场,这是一条建于20世纪后期的农业灌溉水道。南面是Ernst-Theumer-Hof--一个非常迷人的,20世纪80年代的住宅区,其中心是一个长长的绿色公共空间。ASG的两个不同大小的街区为Theumer-Hof形成了一个醒目的顶点,同时它们为公园般的牧场划定了一个强有力的、令人惊叹的衔接边缘。
