土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 极简现代:“架空式”办公建筑
极简现代:“架空式”办公建筑
发布于:2022-03-17 14:33:17 来自:建筑设计/公共建筑设计 [复制转发]
Choice 总部办公室位于清迈Amphoe Mueang 。该地区被文化宝藏所环绕,尤其是当地的泰国建筑元素,如隆考(水稻收获屋)、清迈城墙(如Suan dok门)或泰国传统露台。这些元素分别应用于现代建筑和自然界的建筑。架构只是简单的规划和功能;钢筋混凝土结构,四层高。关键是以庭院为中心,为建筑带来自然阳光。
The Choice Headquarters office is located at Amphoe Mueang, Chiang Mai. The area is surrounded with a treasure of culture, especially local Thai architecture elements, such as Long-kao(rice harvest house), Wall of Chiang Mai(such as Suan dok gate), or Thai traditional terrace. These elements are divisibly applied to modern architecture and architecture in nature. The architecture is simply planning and functions; reinforce concrete structure with four floor height. The key is courtyard centered which brings natural sunlight to architecture.
入口大厅抬高以进行自然通风。1楼广场与2楼开放空间的过渡区域,由GRAND STAIR。它适用于将办公室中的人们联系起来以营造良好氛围的多用途空间,例如办公室的活动、休闲区、会议或研讨会。空间规划以风流和遮阳为导向,CORE区位于西侧,为临时功能区。长期使用的办公和会议区域分别位于北、南和东。
The entrance hall is lifted for natural ventilation. The transition area between 1st floor plaza and 2nd floor opening space by GRAND STAIR. It works for multi-purposed spaces that link the people in the office for a good vibe such as the office’s activity, relaxing area, meeting, or seminar. The space planning is oriented towards wind flow and sun shading, the CORE area is placed to the West side which is a temporary functional area. Office and meeting areas which are long periods of use are located to the North, South, and East consecutively.
建筑的跨度是柱状的,创造了一个开放的区域,很少有柱状排列,在未来可以灵活地改变功能。主楼梯的设计是为了欢迎用户进入这个空间,有意让人们锻炼和节约能源,并将所有人聚集在办公室。工作空间的设计有两种变化;75%的正式办公空间和25%的非正式空间。灵活应对空间使用,创造一个良好的氛围,为生活中的人们带来创造力,并与技术变化的生活方式相联系。
The building span is COLUMNESS, creating a wide-opened area with less frequent column arrangement, which is flexible for changing function in the future. Main staircase is designed to welcome users to the space which intentionally allows people to exercise and save energy, and to gather everyone in the office. The design of working space has two variations ;  75% formal office space and 25% informal space. To flexibly respond to space usage, create a good atmosphere that puts the advance to creativity for people who are living, and relate to lifestyle with technology changing.
乡土砖是当地的材料,成本合理,容易找到,是主要的材料。天然原料的整合;木材和原混凝土之间的现有材料,如铝玻璃窗,反映了泰国当地材料和当代材料的魅力。在“乡土砖”部分适用于建筑的外部和内部部分;
VERNACULAR BRICK is local material, which is proper cost and easy to find, being the main material. The integration of raw natural material; wood and raw concrete between current material such as glazing windows with aluminium, reflecting harmonize the fascination of Thai local material and contemporary material.  In the part of “VERNACULAR BRICK” applies to the exterior and interior part of the architecture;
立面设计,乡土砖被设计成防热百叶。镂空砖沿建筑立面区域排列。一楼的大楼梯,采用模式化的铺设,创造了材料的连续性,这对建筑来说是很轻的,也增加了建筑的退台率。入口大厅的墙面是当地的黑砖和瓷砖,以反映走廊上的LANNA。
Facade design, vernacular brick is designed to be a heat protecting louver. The hollowed-brick is aligned along the building facade area. GRAND STAIR at the 1st floor, is pattern laying to create the continuity of materials which is lightweight for building and increase building surrenders. The entrance hall wall is vernacular black brick with ceramic tile to reflect LANNA along the corridor.
除了建筑元素的独特性,可持续建筑是必须的,是建筑的标准设计思维,CHOICE办公楼正在获得泰国绿色建筑协会(TGBI)的白金树认证。
Apart from Architecture element uniqueness, sustainable building is a must and being a standard design thinking of building, the CHOICE office building is in the progress of PLATINUM TREE CERTIFICATION from Thai Green Building Institute (TGBI).
区位图
平面图
剖面图
外墙细部
爆炸分析图
建筑师:Plan Associates
地点:泰国
面积:5300平方米
年份:2021
  • 放水发电
    放水发电 沙发
    这是一个很不错的学习参考资料, 但是表述的还是过于简单,未提供相应参数及技术要求等, 建议上传一些附件技术资料(如CAD外形尺寸图和对应的型号规格及技术参数等,以方便设计人员选用), 不过这里还是要谢谢楼主能发布和分享出来给大家学习和参考使用! 同时希望大家参与补充/提供相应资料图纸等
    2022-03-18 07:50:18
公共建筑设计
51.18 万条内容 · 448 人订阅
长沙佳兆业环球广场项目
长沙佳兆业环球广场项目
