Designed to support the next generation of student engineers, the building aims to break down boundaries between engineering disciplines, enable greater collaboration, and make Engineering more inclusive by attracting students from a wider cross-section of society. Set over three floors and 8,500m2, the building features teaching studios, simulation suites, laboratories, and specialist workshops accommodating a wide range of subjects.
The brief recognised the value of ‘Social Learning’ spaces outside of traditional teaching to encourage collaboration. A significant design constraint was the spatial and servicing requirements of over 20 different labs and workshops – AHR’s response was to stack the accommodation based on practical requirements: heavy workshops and ‘maker’ space on the ground floor; specialist laboratories on the first floor; and lighter labs and offices on the top floor.
Services follow a ‘ring main’ around the atrium edge feeding off to perimeter rooms, all intended to provide maximum building lifespan. The project was delivered on a live site and to an ambitious timescale, opening to students exactly three years after design work commenced, with the final eight months during the peak of the first wave of Covid-19. While occupancy was limited during the first year, the spaciousness and natural ventilation strategy has enabled staff and students to make use of the building throughout the pandemic.
The University has targeted carbon neutral by 2030. The brief included BREEAM Excellent, with a focus on operational energy and a DEC B operational energy rating. The building is designed for long-term adaptability with an efficient structural grid. Corten steel cladding requires no maintenance and windows were selected that would exceed 60-year lifespan. The 1000m2 atrium roof is glu-lam and CLT which has offset 125t of carbon. This highly serviced building performs extremely well against the RIBA 2025 climate targets and through robust design strategies will provide very long life with minimum barriers to adaptation and change.
免费1人已点赞
公共建筑设计
返回版块51.18 万条内容 · 448 人订阅
受自然启发的光之塔与瓷砖墙来自:设计快讯(ID:arch-headlines) 本文已获得授权 光之塔是一座 40 米高的塔,它支撑和封闭了英国曼彻斯特市中心一个新的低碳能源中心的烟道。 仿生结构建立在长达十年的创新和研究基础之上,贝壳花边结构由Tonkin Liu开创,并与奥雅纳的工程师合作开发。
