When the Tianmu Mountains rush from south to north to Taihu Lake, the steep ridges and ravines of that time have slowly submerged into the vast lakeside plain at this moment. People built cities between the lake and the mountains and created the wealthiest and most romantic area in China, Jiangnan. The Southwest Elementary School is located between the mountain and the city. Taking advantage of the beauty of the landscape, it begins a construction journey of “patrolling the eaves of the wind and the moon, reclusion in landscape”.
The long axis of the site forms an angle of 45 degrees with the north-south direction. In order to ensure the southern lighting of the classrooms, the main teaching units building is arranged in the north-south direction. On the north-south axis, the dining hall, classrooms, and cultural and sports center are arranged successively. Due to the twisting of the axis, interesting changes have taken place in the building with the bisected main teaching unit naturally turning along the site boundary, forming a relatively enclosed courtyard. The courtyard entrance enclosed by the short wings happens to face the city and the mountain view, respectively. We magnified the short wing incidentally and cut obliquely on the shape. Due to the intervention of external force, the entrance of the courtyard contracts in the plane and expands in the vertical, presenting a dynamic symmetrical balance. With the change of the viewers' footsteps, the courtyard shows a movement in different dimensions, and the building is reshaped following this movement. At one end facing the city and mountain views, the roof of the building is cut into an enlarged slope, which is arranged by a series of staggered steps and naturally becomes a stand facing the outside. Plants also spread from the ground to the roof, becoming two streams of green light across the site. The daylighting glass windows scattered in the meantime are like gems in the green field, shining brightly during the day and night. At this time, architecture no longer follows the introverted self-order, but abandons its barriers, merges into the city, and becomes the founder of the unique regional context.
The shape of the building secretly echoes the shape of the surrounding mountains. The courtyard between the two teaching buildings also looks like a mountain valley. The terrace, with a natural retreat from low to high, like a mountain that stretches upwards, becomes the prominent place for students’ activities between classes, and at the same time, outlines the broader shape of the sky. The magnificent sky and rosy clouds can be seen between the mountains and rivers, and this scene also performs over the courtyard from time to time, against the gray buildings, becoming a natural miracle in every ordinary day. The horizontally stretched long lines are cut powerfully in the smooth movement process, forming a firm turn on the gallery's outer wall. It comes from the brush and ink descriptions of mountains and rocks in traditional Chinese painting and reflects the power of mountains and cities in every passing light and cloud.
There are still bridges across the courtyard, which not only solves the problem of traffic connection but also enables the walking in the “canyon” to have suspended crossing and a central stay so that you can experience the dimensional change of space between seeing and being seen. There are an “island” and trees in the middle of the bridge. On a sunny day, sit and watch the clouds rise, and the light moves at any time. In the city, the mountain scenery appears.
免费1人已点赞
公共建筑设计
返回版块51.18 万条内容 · 448 人订阅
幼儿园更新扩建,全新的整体形象幼儿园靠近多瑙河,周围环绕着社会主义预制房屋计划的十层公寓楼。在保留现有的 1980 年代预制的两层幼儿园建筑的同时,这种现代化和扩建赋予了幼儿园全新的整体身份。房间向原来的庭院扩展,前面增加了一个有盖的木制户外游乐场。建筑物在新屋顶的轮廓下打开,以弥补预制板块的封闭和刚性环境。 The kindergarten is located close to the river Danube, surrounded by a ten-story block of flats from the socialist prefabricated housing program. While preserving the existing prefabricated two-story kindergarten building from the 1980s, this modernization and expansion have given the kindergarten a new and integral identity. The rooms were expanded towards the original courtyard, and a covered, wooden outdoor playground was added in the front. The building opens up under the new roof’s outline to compensate for the shut and rigid environment of the prefabricated panel blocks.
只看楼主 我来说两句抢地板首先非常感谢楼主的无私分享!我们正好在规划设计一个类似形状地块的设计!这回可以有了思路了!希望楼主今后提供更好的资料。
来自 土木在线APP
