土木在线论坛 \ 园林景观 \ 园林景观效果图 \ 一个永远都有新意,能被发掘的公园——南通中央公園
发布于:2022-03-04 16:08:04 来自:园林景观/园林景观效果图 [复制转发]
南通中央公园是一个位于南通中心商务区的城市更兴项目。基于新的城市发展和对公共空间的新需求,原有的中轴公园于2018年征集重新设计。一宇设计荣幸获选为设计单位。这个新的公园于2020年改建完成并于2021年重新开放。
The Axis Park is an urban rejuvenation project located in the heart of CBD in Nantong city. Due to the new city development and new needs for public space, the previous park calls for redesign in 2018. YIYU is honored to be selected for the renovation task. The new park is constructed in 2020 and reopens again in 2021.
先前的公园包含一个中轴步道,一个大型的线性喷泉,中轴两侧装饰性的雕塑。在改造之前,此公园因为缺乏有效作为城市活动的空间,加上不易维护及高营运成本的景观设施,使得公园使用率低落: 中心的线性喷泉因为营运成本关闭多年, 两侧的绿带因为初期过密的种植和缺乏长周期的维护,公园变成了一个杂乱、阴暗、潜存危安风险的城市死角。
The previous park composed of an axis walkway, a large-scale linear fountain, two green belts, and multiple decorative statues along the axis. Before the renovation, the park was underused due to the lack of functional spaces for urban activities. The park also suffered from ill maintenance owing to previous high-cost design for operation. The center linear waterscape was shut down for years due to the insufficient budget to operate. The green belts was poor maintened due to overly dense plantation. The park fell into a messy and shady status where potential safety risks could reside in the city.
此外,原本的公园设计由于偏重于表面的装饰和宏伟性,而非对人的功能与参与,极少的座位及活动空间,使用者很难在公园里停留。公园变成一个仅仅是”看”的公园,而不是一个能停留、交流互动的场所。
The old park also had an imbalanced condition where the original design focused on decoration and grandiose, rather than functionality and engagement. Visitors could hardly stay due to a lack of sitting area and activity space. The park became a park only to look at, but not a park to stay and interact.
一宇利用这个机会探索公园的可能性,及研究城市地标景观的新潜力。在研究中我们发现,此场地周围人口密集,随着周边商场、办公大楼和酒店的分布,此公园极具成为CBD区域完美的中心开放空间潜力,多样的城市活动也都可能在这片土地发生。
YIYU uses this opportunity to explore the possibility of functions for the new park, and study potential identity for the new urban landscape. In the research, we discover that the surrounding of the site is highly populated. With shopping malls, office towers, and hotels in the vicinity, the location of the park could be the perfect central open space for the CBD, and a variety of urban activities can happen at the site.
公园的规划基于对中心商业区、周边邻里、及访客缜密的功能研究。整体架构包含可作各类弹性活动的大草坪、市集及邻里花园、游戏场、及银发族乐活空间。两个连接地下商业街的下沉广场,以鲜明的红色玻璃扶手改造,来引导上下层人流及入口意象。
The layout of the park is based on careful studies of functionality for the CBD, neighborhoods, and visitors. The structure includes flexible lawns for events and markets, community gardens, a playground, and leisure areas for the elders. Two sunken parks connecting to the underground commercial street are renovated with identical red glass railings.
利用这个机会,我们提出了”人为风景,活动为地标 ” 的概念。公園成為城市之窗,活动之廊,人与社交参与成为项目的基石。
With the opportunity, our proposal is to seek a park as a window to showcase urban lives, a gallery to curate activities. People and social engagement become the keystone of the project – “ People as the scenery, and activities as the landmark”.
我们的设计提案,以具功能性及清晰性的空间,来替换闲置与装饰的元素。如原本失去功能的中心水景,化身为多功能的开放草坪。两侧的装饰性雕塑,以互动可坐可玩的坐椅置换。
Our design step is to replace the non-operational elements with clear and functional spaces. Such as removing the center linear waterscape with multi-functional open lawn, and replacing the decorative statues with interactive benches for sitting and playing.
新公园包含四个主要区域:一个中心活动草坪、一个艺术地形演艺公园、步道两侧可互动座椅区、以及一个儿童游戏场。公园的结构创造出一个没有明确边界的开放式平面架构,区域与区域之间的视野和活动得以联通及延展。例如地形公园可以连接到孩子们奔跑跳跃的游戏场,作为游戏的延伸。活动草坪和艺术地形可以结合举办大型音乐节,而两侧的座椅则在此时可以转变成为看活动的大型观众席。
The new park includes four areas: A central event lawn, a landform performance park, two interactive sitting areas, and a playground. The structure of the park is to create an open plan without clear boundaries between areas. Views are open to each other and activities are connected between each other. The plan also provides the possibility for the extension of activities. The playground where kids run can connect to the landform park as an extension of the play. The open lawn where the music festival is held can be integrated with the sitting area as the audience’s bench.
艺术地景公园
梦般充满藝術及互動性的城市地景。
未來的活動與人,將成為這麼城市的新地標。
漩涡状的艺术地形给周围刚硬的中心商业区,带来了流动和柔软的对比。
The swirl landforms give a dynamic and soft contrast to the surrounding CBD.
新的公园带入了一种清晰性。型式表明其功能,型态暗示其参与性。
The new park brings clarity to the place by introducing forms that inform functions, shapes that signify engagement.
设计运用了现状树的优势,在树下结合座椅及休憩区。步道所选用的浅色石材用以捕捉树影,在景观中带入一丝诗意。
The design utilizes the existing trees by incorporating seating and leisure areas under the trees. Light color pavers that catch the shadow from the tree give a sense of liveness in the landscape.
充满玩心和互动性的座椅,给予了使用者自由去发挥创意使用空间,保留的大树提供了最佳的绿荫和美丽的树梢剪影。
Playful and interactive benches provide freedom for users to use the space freely. The preserved old trees provide perfect shade with a beautiful silhouette from the canopy.
另一个策略,是通过迁移场地现有的树木,来削减两侧过度密集的绿化带。随着密度的调整,原本密不透风的公园重新向街道开放,公园景色一览无遗,原本对城市死角的隐患也随之消失。
Another step is to reduce the overly dense green belt by relocating existing trees. With the adjustment of density, the park becomes open again to the streets, and dangerous corners are eliminated from the city.
新的中央公园将原有公园变身为一个充满艺术性、互动性、及多功能弹性的城市开放空间。
The new Axis park transforms the park into an artistic, interactive, and adaptable open space.
艺术地形上的小花平台,提供了一个观景台,亦作为周末小型音乐表演艺术家的舞台。
The petal shape platforms on the landforms are perfect viewing spots in the park, as well as performance stages for musicians on the weekend.
公园的设计同时倡导低成本建造和低维护的策略。利用挖方和填方的平衡雕塑地形,以此减少外运土方成本及耗能。原本维护成本昂贵的线性水景被易维护的多功能开放草坪取代,作为提供举办艺术活动、音乐会和周末市集的场地。公园为城市实现了更大化的效益,及长远低维护成本的永续设计。
The park also utilizes low-cost design for construction and maintenance. The landform park balances the cut and fills to create a topography design without additional soils from outside. The expensive linear waterscape is replaced with an open lawn which is easy to maintain yet multi-functional for art events, music festivals, and weekend markets.
具备满足用户的功能,及创造对造访者的乐趣,新的轴线公园在绿色及启发的场所的设计之中,提供了一个人们能休憩及创造乐趣的地方。一个永远都有新意能被发掘的公园,这些源源不绝的新意将来自于人,来自于城市生活方式带来的活力。
Useful to the users and fun to the visitors, with green and inspirational places designed, the new Axis park provides a new place for people to rest and have fun. A park where something new can always be found by the people. And a park with endless energy can be discovered from urban lives.
项目名称:南通中央公園
设计方:一宇设计
公司网站:www.yiyudes.com
联系邮箱:info@yiyudes.com
项目设计 & 完成年份:2019/2021
主创及设计团队:林逸峯 / 黄申飞 , 田益正, 吳令恬, 沈雪, 黃婉真, 孫晶
项目地址:南通市桃園路
景观面积:24000平方米
摄影版权:一宇设计
客户:中南集團
Project name:AXIS Park
Design:YIYU design
Website:www.yiyudes.com
Contact e-mail:info@yiyudes.com
Design year & Completion Year:2019/2021
Leader designer & Team:Yifeng Lin / Christaphor Huang, Yizheng Tian, Lingtien Wu, Snow Shen, Wendy Huang, Jing Sun
Project location:Taoyuan Road, Nantong
landscape area :24000sqm
Photo credits:YIYU design
  • 和平卫士
    和平卫士 沙发
    这样的城市公园的确非常不错,值得人去观赏
    2022-03-05 08:04:05
  • littlieee
    littlieee 板凳
    个人觉得这个公园观赏性较大,参与性较小,南通的原生态植物群落比较丰富,可以达到单位面积乔木加灌木加草本,其中乔灌比例中灌木比例不小,群落丰富,大草坪一般渤海流域气候比较适合,南通的植物层次可以更丰富,中国园林的一步一景性更丰富游园体验,商业区中的公园,人们的参与与引导娱乐的空间比例也很重要
    2022-03-04 18:12:04
园林景观效果图
24.65 万条内容 · 163 人订阅
用花做篱笆,用心安个家
?   用花做篱笆,诗意为墙   静守流年,嗅一院子的芬芳   把简单的日子   过成一首美好的诗
