土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 经典立面国外多层住宅
经典立面国外多层住宅
发布于:2022-01-27 10:04:27 来自:建筑设计/居住建筑设计 [复制转发]
城市规划和建筑
该项目位于洛桑北部Boveresses区的中心地带。该区由 1970 年代的几个标志性住宅区组成。该项目旨在在这种背景下以强烈的身份进行整合。结果是一种城市形态,通过提出一个带有红点的铰接体量,占据了周围城市主义的明确方向。在不寻求模仿的情况下,该建筑与其环境建立了紧密的联系。
Urban planning and architecture. The project is located in the heart of the Boveresses district in the north of Lausanne. This distric t is composed of several emblematic housing complexes from the 1970s. The project aims at an integration in this context with a strong identity. The result is an urban morphology that takes up the clear orientation of the surrounding urbanism by proposing an articulated volume with redents. Without seeking mimicry, the building creates a strong link with its environment.
该项目有两个参考层:一楼下层朝南,是学校和课外活动场所,也是通往住宅的主要通道,而一楼上层的入口朝北,与一个长满树木的公园和一个操场相连。这些入口通向两个宽敞的分配核心。在花园板块下是一个半层经营的停车场。在设施附近有一个天棚,为建筑的居民以及附近的居民提供了进入停车场的通道。
Two reference levels define the project: the lower first floor level, facing south, hosts the school and after-school programs as well as the main accesses to the dwellings, while the upper first floor entrances, facing north, are connected to a park covered with trees and a playground. The entrances lead to two generous distribution cores. Under the garden slab is a parking lot operating in half levels. A canopy near the amenities provides access to the parking lot for the residents of the building as well as the neighbourhood.
正交平面由相距3.6m的南北轴线刚性系统和更灵活的东西墙系统组成。两个系统的交集产生了一个由分布在 enfilade 的房间组成的平面图。这一计划原则通过大型落地门提供了许多对住宅的横向视图。这个系统在立面上被许多凹槽所反映,这些凹槽为公寓提供了不同的方向和大量的自然光。
The orthogonal plan is composed of a rigid system of north-south axes 3.6m apart and a more flexible system of east-west walls. The intersection of the two systems generates a plan composed of rooms distributed in enfilade. This plan principle offers many cross-views into the dwellings through the large floor-to-ceiling doors. This system is reflected in the facade by numerous recesses that provide the apartments with varied orientations and a significant amount of natural light.
与城市设计一样,预制混凝土外墙的处理寻求与相邻建筑的联系,并赋予其非时间性的存在。
Like the urban design, the treatment of the prefabricated concrete facades seeks a link with the adjacent buildings and gives it an intemporal presence.
景观项目的特点是其组成部分的有机和流动的几何形状。它的设计与建筑结构的笛卡尔刚性形成鲜明对比。在较低的一楼,就学校项目而言,矿物成分确保了广场和庭院的占用。相比之下,在一楼的上层,植物成分占主导地位。拥有游乐场的绿树成荫的公园成为整个社区的参考场所。白桦树和松树为该项目营造了一种宁静祥和的氛围。
Landscape. The landscape project is characterized by the organic and fluid geometry of its components. Its design contrasts with the cartesian rigidity of the built architecture. On the lower first floor, in relation to the school programs, the mineral component ensures the appropriation of the square and the courtyard. On the upper first floor, by contrast, the vegetal component prevails. The tree-lined park hosting the playground becomes a place of reference for the entire neighbourhood. The birch and pine trees give the project a calm and restful atmosphere.
卫星照片
区位图
平面图
立面图
户型图
建筑师:Fruehauf, Henry & Viladoms
地点:10913平方米
年份:2021
居住建筑设计
28.74 万条内容 · 423 人订阅
伦敦网红“天空泳池”面临关闭!140万加热费,富豪住户都给不起了?
本文授权转载自:建道筑格ArchiDogs(ID: ArchiDogs_AD) 你想过在半空中游泳吗? 四周无遮无挡 头顶是天空 身下是大地 这样的天空游泳池 世界上还真有一个! 悬挂于两栋大楼之间 透明、轻盈、自由自在 先是效果图火出圈 建成后又收割了一波流量
