土木在线论坛 \ 暖通空调 \ 制冷技术 \ 约克工业制冷设备控制系统配件明细640C0024G01
发布于:2022-01-25 16:13:25 来自:暖通空调/制冷技术 [复制转发]
640C0057G01 Analog Board #1 (Replaces existing 32 channel board #1 only - no hardware)
640C0057G02 Analog Board #2 (Replaces existing 32 channel board #2 only – no hardware)
640C0057G11 Analog Board #1 (Field Upgrade Kit – Includes 32 ch. board #1, connectors & hardware.)
640C0057G12 Analog Board #2 (Field Upgrade Kit – Includes 32 ch. board #2, connectors & hardware.)
639A0206H10 5 Amp circuit breaker
639A0206H10 10 Amp circuit breaker
639A0206H15 15 Amp circuit breaker
Connectors
649A1027G14 2-Pole connector (P8 – Analog Board)
649A1027G11 Connector kit for Input Ch. 1-16 (Analog Board)
649A1027G21 Connector kit for Input Ch. 17-24, and Output Ch. 1-8 (Analog Board)
649A1027G31 Connector for Power/Communications for Analog Board
333Q0001418 Filter, Line
333Q0001191 Hour meter
639A0185H10 2-Pos. Selector Switch (Control Power)
639A0185H30 Latch, 3 Across (Attaches contact block to switch mechanism)
639A0185H31 Normally Open Contact Block (for Control Power Switch)
639B0120H51 Socket, Guarded, DPDT
639B0114H51 Socket, Guarded, 3PDT
639B0114H98 Spring Clip Hold Down
639B0120H01 Relay, Control 24VDC, DPDT
639B0120H11 Relay, Control 120VAC, DPDT
639B0120H21 Relay, Control 240VAC, DPDT
639B0114H02 Relay, Control 24VDC, 3PDT
639B0114H12 Relay, Control 120VAC, 3PDT
639B0114H22 Relay, Control 240VAC, 3PDT
639A0243H02 Surge suppresser
333Q0001172 Output Module, 24 VDC
111Q0281061 Output Module, 24-280 VAC
333Q0001171 Input Module, 24 VDC
333Q0000116 Input Module, 120 VAC
333Q0000789 Input Module, 230 VAC
333Q0001326 Fuse, 5 amp, 250 V
640C0024G01 Digital Board #1 (Replaces existing board only - no hardware)
640C0024G02 Digital Board #2 (Replaces existing board only - no hardware)
649D5948G01 Digital Board #2 (Field Upgrade Kit– adds a second digital board)
639D0199H01 15” Color Display (Indoor)
639D0199H11 15” Color Display (Outdoor)
649D6101G01 Field Replacement Touchscreen glass w/overlay of Frick logo (Keypad has been eliminated)
Fans
649A0906G13 Internal Circulation Fan, Field Install, 24 VDC
649A0906G11 Internal Circulation Fan, Field Install, 115 VAC
649A0906G12 Internal Circulation Fan, Field Install, 220 VAC
649A1104Gxx Quantum? HD Program Flash Card (Version 10.xx, the xx indicates program revision)
649A1063G99 Quantum? HD Setpoint Saver (USB Drive)
Harnesses
639D0204H01 DC power-I/O Comms harness
639D0203H01 AC harness for Digital board # 1
639D0203H02 AC harness for Digital board # 2
639B0118H01 Display Harness
639B0126H01 LED Inverter Harness
639D0191H03 Harness Kit, Q5 to Interface Board Interconnect
Miscellaneous
333Q0001786 Battery, 3V (located on Q5 board)
639C0143H01 Q5 mounting plate (hardware not included)
640M0007G16 200 W, 115 VAC
640M0007G18 400 W, 115 VAC
640M0007G27 200 W, 220 VAC
640M0007G21 400 W, 220 VAC
639B0115H01 DC power supply – 5 VDC
639B0115H02 DC power supply – 12 VDC
639B0115H03 DC power supply – 24 VDC
649C1158G01 Q5 (Advantech Q5) (Does not include interconnect harness kit)
639B0116H01 Interface Board (Does not include interconnect harness kit)
REMANUFACTURED PARTS
640C0024S01 Digital I/O Board
640C0057S01 Analog I/O Board (32 Channel)
640C0057G11 Analog Board #1 (Field Upgrade Kit – Includes 32 channel board #1, connectors & hardware.)
640C0057G12 Analog Board #2 (Field Upgrade Kit – Includes 32 channel board #2, connectors & hardware.)
639A0206H20 20 Amp circuit breaker
Connectors
649B0903H01 2-Pole connector (P8 – Analog Board)
333Q0001258 6-Pole connector (P1 through P6 – Digital Board, P4A through P10B – Analog Board)
333Q0001234 8-Pole connector (P11A and P11B – Analog Board)
649B0903H02 9-Pole connector (P2 – Analog Board)
制冷技术
14.68 万条内容 · 886 人订阅
求助二氧化碳制冷循环
二氧化碳跨临界制冷循环设计时的注意事项.求普及
