土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 三维度立面:国外多层住宅
三维度立面:国外多层住宅
发布于:2021-12-27 14:25:27 来自:建筑设计/居住建筑设计 [复制转发]
这座建筑最引人注目的特点是立面的三维度,通过切割混凝土的几何裂口创造出来,好像每一次撕裂都有一个身体的反应——一种水泡。这种几何效果创造了起伏和运动的错觉,并适应了面向公园的立面,开口更大,突起效应更小。
The building's most striking feature is the facade's three-dimensionality, created through geometric rips that cut the concret e, like if there is a body's reaction in each tear – a kind of blister. This geometric effect creates the illusion of undulation and movement and is adapted to the facade facing the park, where the openings are much larger, and the protrusion effect is smaller.
这种设计更好地利用了公园的景观,同时保持了建筑的概念一致性。极简主义框架的金色铝的光泽丰富了开口的几何形状。同样,种植者的植被和颜色使白色色调的干燥立面显得更加生动。
This design makes better use of the park's views while maintaining the building's conceptual consistency. The openings' geometry is enriched by the shine of the golden aluminum of the minimalist frames. Likewise, the planters' vegetation and colors jazz up the white-toned dry facade.
可持续性和能源效率是 Essenza 的两个核心特征。使用太阳能电池板加热水以进行集中积聚,然后分配给每个住宅单独积聚,这是一种比即时生产更有效的系统。未使用的能源不会浪费并加热五楼的游泳池。还值得一提的是通风系统——可将能耗降低三分之二——以及安装冷凝锅炉,从而节省能源并减少向大气中排放的二氧化碳。
Sustainability and energy efficiency are two core characteristics of Essenza. The water is heated using solar panels for centralized accumulation, which is then distributed for individual accumulation by each dwelling, being a more efficient system than the instant production one. Unused energy is not wasted and heats the fifth-floor pools. It’s also worth mentioning the ventilation systems – that lead to a two-third reduction in energy consumption – and the installation of condensing boilers, which allow energy savings and reduction in CO2 emissions to the atmosphere.
Essenza 旨在提供体验,将技术与精选的豪华饰面相结合,为其住户提供舒适度和功能性。在这种情况下,我们重点介绍了家庭自动化系统、循环空间、卧室和客厅中使用的地板辐射采暖,以及整个浴室使用的卡拉拉大理石。大理石块由 Ventura + Partners 直接在卡拉拉挑选,从意大利运来,然后在葡萄牙切割、处理和充分准备。
Essenza was designed to be experienced, combining technology with a selection of luxury finishes to provide maximum comfort and functionality to its residents. In this context, we highlight the home automation system, the radiant floor heating used in the circulation spaces, bedrooms, and living rooms, and also the carrara marble used throughout the bathrooms. The marble blocks were selected by Ventura + Partners directly in Carrara, having been brought from Italy and then cut, treated, and fully prepared in Portugal.
审美和谐是生活质量的基础,是建筑的基石之一。在立面上,这种平衡以金色花箱的形式出现,与混凝土形成鲜明对比,为建筑提供了活泼自然的特征。
Fundamental to quality of life, aesthetic harmony is one of the building’s cornerstones. On the fa?ades, this balance appears in the form of golden flower boxes, which contrast with the concrete, providing the construction with a lively and natural character.
住宅建筑为其周围的语言提供了连续性,同时也从建筑和建设的角度促进了区域的增值。通过利用与公园的紧密联系,Essenza 在建筑与自然的结合中促进了其空间的扩展。
The residential building gives continuity to its surroundings language, while also contributing to the area valorization from an architectural and constructive point of view. By taking advantage of the close connection to the park, Essenza promotes the extension of its spaces in a marriage between architecture and nature.
区位图
平面图
立面图
剖面图
细部构造
模块外墙
建筑师:Ventura + Partners
地点:葡萄牙
面积:11740平方米
年份:2020
  • 科肯kealno
    科肯kealno 沙发
    谢谢楼主分享,长见识了。
    2021-12-31 11:30:31
居住建筑设计
28.74 万条内容 · 423 人订阅
韩国顶流男星豪宅曝光!迷宫一样的设计,“家徒四壁”的装修,我看呆了...
自己喜欢的 就是好风格 有人喜欢热闹,就有人喜欢清冷;有人喜欢凌乱,就有人喜欢整洁。今天这套房子,就集结了“神奇、宽敞、整洁、冷淡”等等关键词。 我可以拍着胸脯跟大家保证,这绝对是能排上 “奇妙结构TOP3” 的一套房子。 总之,看的让我惊呼 “太神奇又太爽了吧”!
