土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 螺旋式公共空间——深圳仁恒罗湖综合体
螺旋式公共空间——深圳仁恒罗湖综合体
发布于:2021-12-09 09:38:09 来自:建筑设计/公共建筑设计 [复制转发]
深圳仁恒罗湖综合体
螺旋式公共空间实现功能完美平衡
Aedas新作
由Aedas执行董事柳景康设计的仁恒罗湖综合体发展项目位于深圳罗湖热闹繁华的街区。 这一耸立的高端商业大厦之中,容纳了336间优质单元以及下沉式商业,并设有丰富的公共空间,以独特的建筑轮廓打造出罗湖新地标。
Situated in the lively region of Luohu, Shenzhen, Yanlord Luohu Mixed-Use Development stands tall as a high-end commercial tower. Providing generous public space accompanied by 336 quality units and underground retail—the development is poised to become Luohu’s newest landmark.
独特的建筑轮廓
The unique architectural outline
“我们希望通过设计回应并融入周边的城市肌理,并为使用者营造出最大的景观视野。由于地块南侧与东侧存在已建成建筑,我们调整了塔楼布局方向,尽可能为使用者提供全景视野。” Aedas执行董事柳景康(Cary Lau)如是说。
塔楼高198米,旋转塔楼朝向后,设计结合地块环境,将更具商业价值的大型单元设置于无敌视野的高层,中型单元设置于120米以下的区域,可通过转角窗尽享无遮挡的视野景观,小型单元的景观视野亦得到了改善提升。
 “As a key part of the design strategy, our objective is to connect and respond to the urban surroundings, to ensure maximum views. Since there were existing building on the south and east sides, the tower was rotated through methodological calculations, lending a panoramic view from the inside,” explained Aedas Executive Director Cary Lau . Based on the site condition, big units with more commercial value were located on upper floors and areas with unobstructed views. Medium units were located below 120m with unobstructed views through corner windows. After the rotation, the semi-obstructed views for small units were also greatly improved.
视野示意图
The field of view
设计的一大亮点是底部横跨三层、总面积约6,600平方米的螺旋布局公共空间 ,其中阳光充足的中庭将成为社区的活动空间、社交中心以及文化中心。
此外,四层及五层还设有包含游泳池、体育设施以及私人花园的多元化功能房,为访客提供丰富的休闲体验。
The integrated development is the quintessence of placemaking, highlighted by the 6,600 sqm spiral-shaped public space spanning across the first three floors. There is a light-filled atrium as event space, a community center, and cultural facilities. A diverse functional room equipped with a swimming pool and sports facilities are also provided on the fourth and fifth floor, surrounded by a private garden.
总平面图
The MLP
螺旋布局公共空间
The spiral-shaped public space
设计将地下空间打造成为下沉式步行街,包含了巨大的商业空间以及时尚品牌,并在西北方入口处设有举办活动的露天剧场。
Beneath the floors is a sunken pedestrian street where there is a vast retail space filled with fashionable brands, and an amphitheatre serving as an engaging event space, located on the northwest entrance.
下沉式步行街
The sunken pedestrian street
在环保层面,设计均采用低挥发性建筑材料,以改善空气质量,并以带有低辐射涂层的中空玻璃板,降低眩光,减少太阳辐射。
此外,设计以横向的线条打造出极富动感的立面,并在光照充足的西侧,利用格栅形成遮阳效果。
With an environmentally-friendly goal in mind, construction materials used were low-emitting to improve indoor air quality; the insulated glass panels with low-E coating also help to control glare, and reduce solar gain. Furthermore, the facade is lined with horizontal features to create a dynamic surface, while the cantilever spandrel design on the west side provides shading.
横向立面线条
Horizontal facade lines
极富动感的立面
The dynamic surface
“我们希望基于地标性建筑轮廓,通过全方位且多元化的公共空间,充分挖掘并激活片区潜力,提升社区居民空间体验,增强与城市间的互动关系。”
“The design fully explores community’s assets and potential, deploying a multi-faceted approach to public space planning, to achieve the ideal of placemaking. Our hope is to create a landmark architecture that promotes people’s well-being as well as strengthen urban relations.”
施工照片
Construction photos
入口景观
Entrance landscape
项目图纸
位置: 中国深圳
设计建筑师: Aedas
业主: 仁恒置地集团
建筑面积: 60,000平方米
竣工年份: 2021年
主要设计人: 柳景康(Cary Lau),执行董事
Design Architect: Aedas
Client: Yanlord Land
Gross Floor Area: 60,000 sq m
Completion Year: 2021
Design Directors: Cary Lau, Executive Director
  • lijiawei411
    lijiawei411 沙发
    2021-12-09 16:13:09
公共建筑设计
51.18 万条内容 · 448 人订阅
解读岭南建筑前世今生
岭南建筑究竟是何模样? 我们先从 古老的画作 窥探它的奥秘 「 外销画 」   ▲ T.Allow笔下的广州集市 清朝年间 一种取材中国风景的 西洋画 在广州十三行畅销
