土木在线论坛 \ 暖通空调 \ 通风排烟 \ 请问各位大佬,同一个防烟分区,梁底高度不同,挡烟
请问各位大佬,同一个防烟分区,梁底高度不同,挡烟垂壁如何设置?是否需要安装完成后的挡烟垂壁底标高相同?
全部回答(4 )
  • 壮士一去
    一般按最不利情况考虑吧,底标高不一致的话储烟仓厚度实际上就是较高的那侧挡烟垂壁决定了,所以肯定得一致吧,个人看法仅供参考
    2021-03-07 22:58:07 来自 PC 评论 举报
  • wx_1615779577532
    错开分布咯dribbble.com/bjzjz/collections/4545880,dribbble.com/bjzjz/collections/4545884,dribbble.com/bjzjz/collections/4545885,dribbble.com/bjzjz/collections/4545890,dribbble.com/bjzjz/collections/4545893,dribbble.com/bjzjz/collections/4545896,dribbble.com/bjzjz/collections/4545897,dribbble.com/bjzjz/collections/4545899,dribbble.com/bjzjz/collections/4545901,dribbble.com/bjzjz/collections/4545905,dribbble.com/bjzjz/collections/4545909,dribbble.com/bjzjz/collections/4545911,dribbble.com/bjzjz/collections/4545913,dribbble.com/bjzjz/collections/4545915,dribbble.com/bjzjz/collections/4545917,dribbble.com/bjzjz/collections/4545919,dribbble.com/bjzjz/collections/4545921,dribbble.com/bjzjz/collections/4545923,,dribbble.com/shzjz/collections/4545936,dribbble.com/shzjz/collections/4545940,dribbble.com/shzjz/collections/4545944,dribbble.com/shzjz/collections/4545947,dribbble.com/shzjz/collections/4545950,dribbble.com/shzjz/collections/4545953,dribbble.com/shzjz/collections/4545957,dribbble.com/shzjz/collections/4545959,dribbble.com/shzjz/collections/4545962,dribbble.com/shzjz/collections/4545966,dribbble.com/shzjz/collections/4545970,dribbble.com/shzjz/collections/4545972,dribbble.com/shzjz/collections/4545975,dribbble.com/shzjz/collections/4545978,dribbble.com/shzjz/collections/4545979,dribbble.com/shzjz/collections/4545980,dribbble.com/shzjz/collections/4545982,dribbble.com/shzjz/collections/4545983,,dribbble.com/gzzjz/collections/4545992,dribbble.com/gzzjz/collections/4545994,dribbble.com/gzzjz/collections/4545997,dribbble.com/gzzjz/collections/4546000,dribbble.com/gzzjz/collections/4546002,dribbble.com/gzzjz/collections/4546005,dribbble.com/gzzjz/collections/4546006,dribbble.com/gzzjz/collections/4546009,dribbble.com/gzzjz/collections/4546012,dribbble.com/gzzjz/collections/4546014,dribbble.com/gzzjz/collections/4546018,dribbble.com/gzzjz/collections/4546020,dribbble.com/gzzjz/collections/4546022,dribbble.com/gzzjz/collections/4546025,dribbble.com/gzzjz/collections/4546027,dribbble.com/gzzjz/collections/4546030,dribbble.com/gzzjz/collections/4546032,dribbble.com/gzzjz/collections/4546035,,dribbble.com/szzjz/collections/4546044,dribbble.com/szzjz/collections/4546046,dribbble.com/szzjz/collections/4546049,dribbble.com/szzjz/collections/4546052,dribbble.com/szzjz/collections/4546054,dribbble.com/szzjz/collections/4546055,dribbble.com/szzjz/collections/4546057,dribbble.com/szzjz/collections/4546058,dribbble.com/szzjz/collections/4546059,dribbble.com/szzjz/collections/4546060,dribbble.com/szzjz/collections/4546062,dribbble.com/szzjz/collections/4546065,dribbble.com/szzjz/collections/4546069,dribbble.com/szzjz/collections/4546071,dribbble.com/szzjz/collections/4546073,dribbble.com/szzjz/collections/4546075,dribbble.com/szzjz/collections/4546077,dribbble.com/szzjz/collections/4546078,
    2021-03-19 09:42:19 来自 PC 评论 举报
通风排烟
13.92 万条内容 · 633 人订阅
