土木在线论坛 \ 水利工程 \ 防汛抗旱 \ 半干旱区水循环与水生态安全关键技术
半干旱区水循环与水生态安全关键技术
发布于:2021-08-09 16:01:09 来自:水利工程/防汛抗旱 [复制转发]
编者按
2020年中国水利水电科学研究院英文年报已经发布,现以双语的形式连续推出2020年度中国水利水电科学研究院科技创新代表性成果,以及荣获院科技进步奖的部分成果,与国内外专家学者分享。
IWHR 2020 Annual Report has been released. Starting from today, we will present in succession the 2020 IWHR Innovation Project and the representative projects of 2020 IWHR Science and Technology Award in the form of bilingual extracts, for the reference of experts at home and abroad.
半干旱区水循环与水生态安全关键技术
Key Technologies for Water Cycle and Ecological Security in Semi-arid Regions
主要完成人 : 陈敏建、赵勇、闫龙、张生、李同昇、董克宝、汪勇、周飞、邓伟、刘艳红、靳晓辉、马静、李洪志、杨贵羽、胡雅杰
Main Participants: CHEN Minjian, ZHAO Yong, YAN Long, ZHANG Sheng, LI Tongsheng, DONG Kebao, WANG Yong, ZHOU Fei, DEN Wei, LIU Yanhong, JIN Xiaohui, MA Jing, LI Hongzhi, YANG Guiyu, HU Yajie
研究背景
Background
本项目针对半干旱区农牧交错带由水土资源开发造成的重大水资源与生态问题,开展理论与应用基础研究。半干旱区草原自然生态系统,在大规模的土地开垦和地下水灌溉条件下,草原生态空间不断萎缩、地下水位持续下降,对农牧区的生存与发展形成了重大威胁。
This project aims to carry out the oretical and applied basic research on the major water resources and ecological problems caused by the development of water and land resources in the agro-pastoral ecotone of semi-arid regions. Under the condition of large-scale agriculture irrigation and groundwater extraction, grassland ecological space continues to shrink and groundwater level continues to decline in semi-grid regions, which poses a major threat to the survival and development of agricultural and pastoral areas.
针对上述一系列问题,在水利部公益性行业科研专项支持下,本项目针对年降雨量200-400mm、水面蒸发量大于1000mm、干旱指数在3-7之间的半干旱区开展了长期的滚动跟踪研究,为具有半干旱区特色的水文水资源与生态安全理论技术,前瞻性、基础性、原创性突出。
In response to the above series of problems, with the support of the nonprofit research projects of the Ministry of Water Resources, this project has carried out a long-term rolling tracking study on semi-arid regions with annual rainfall of 200-400mm, water surface evaporation greater than 1,000mm and drought index between 3 and 7. It is a forward-looking and basic theoretical technology of hydrology, water resources and ecological security specifically targeted at semi-arid regions with remarkable creativeness.
研究成果
Ac hievements
揭示了灌溉对半干旱区地下水形成的影响机理。定量揭示了微滴灌导致灌溉回归水的消失以及降水入渗补给变化过程,分析了二者共同使得地下水采补平衡水位上升的影响,分析研究了微滴灌对半干旱区垂向水文循环产生的影响。
Having discovered the influence mechanism of irrigation on groundwater formation in semi-arid regions, quantitatively revealed the disappearance of irrigation return flow and the change process of precipitation recharging groundwater caused by micro-drip irrigation, analyzed the influence of the combination of these two approaches for water table balanced groundwater exploitation and replenishment, and studied the impacts of micro-drip irrigation on the vertical hydrological cycle in semi-arid regions.
形成了基于草原自然属性的半干旱区农牧交错带生态格局评价分析方法。建立农牧交错带区域生态结构评价方法,提出半干旱区草原农牧交错带生态景观合理结构比例。
Having formed an evaluation and analysis method for ecological pattern of agro-pastoral ecotone in semi-arid regions based on grassland natural attributes, established an evaluation method for regional ecological structure of agro-pastoral ecotone, and proposed the reasonable proportion of ecological landscape structure of grassland agro-pastoral ecotone in semi-arid region.
提出了半干旱区农牧交错带地下水控制水位的差别式管理。在半干旱区全面研究具有物理机制和实验实证为基础的临界地下水位(包括降水入渗补给的地下水临界埋深,和地下水补给植被的临界埋深);提出以地下水临界埋深为控制性指标的管控红线;建立地下水动力学模型,研究提出地下水水井布设的原理和管控准则。
Having put forward the differentiated management of groundwater control levels in the agro-pastoral ecotone in semi-arid region, proposed the so called “red line” based on  the comprehensive study on the threshold groundwater table (including the threshold groundwater table of precipitation recharging groundwater and groundwater supplying vegetation) with physical mechanism and experimental evidence in semi-arid regions; established the model of groundwater dynamics and developed the principle and control criteria of groundwater well layout.
提出了基于生态安全的半干旱区循环经济发展模式。建立半干旱区经济社会发展方式循环经济产业链的水生态安全分析工具,形成基础性与实用性相结合的创新技术方法。
Having proposed the development pattern of circular economy in semi-arid regions based on ecological security, created the ecological security analysis tool for the industrial chain of circular economy in the economic and social development pattern of semi-arid regions and established an innovative technical method with fundamentality and practicability.
应用
Application
研究成果在内蒙古东部开展了及时推广应用,效果显著,为草原生态保护和地下水合理利用发挥了巨大作用。项目成果在内蒙古各盟市和松辽流域得到迅速推广应用。
The research results have been applied and rolled out in Eastern Inner Mongolia in a timely manner bearing significant results, which have played a huge role in the ecological protection of grassland and rational utilization of groundwater. The project results have been rapidly promoted and applied in other areas in Inner Mongolia and Songliao River Basin.
成果也为水利部强化内蒙古西辽河流域水资源管理工作提供了技术支撑;为华北平原典型区域地下水超采综合治理提供了参考依据。成果还推广到其它省区,如陕西省施行地下水分区域差别管理。
These achievements have technically supported the Ministry of Water Resources to strengthen the management of water resources in the West Liaohe River Basin of Inner Mongolia; and served as reference for the comprehensive treatment of groundwater over exploitation in typical areas of North China Plain. The achievements have also been extended to other provinces,such as Shaanxi Province, where differentiated regional management of groundwater is implemented.
图1 灌区与牧区地下水管理水位分析计算原理
Fig. 1 Controlling Groundwater Level Calculation Principles in Irrigated and Pastoral Areas
图2 半干旱区农牧交错带循环经济发展模式分析
Fig. 2 Analysis of Circular Economy Development Pattern in Agro-pastoral Ecotone in Semi-arid Region
图3 提出了西辽河平原生态格局调整建议
Fig. 3 Suggestions for Ecological Pattern Adjustment in the West Liaohe Plain
防汛抗旱
9036 条内容 · 76 人订阅
这个水利工程,扛起平原地区的排涝担当!
一场台风“烟花” 给嘉兴带来连续降雨, 从7月23日到28日, 雨水……一直一直下。 嘉兴市杭嘉湖南排工程 全力开启排涝模式, 已累计外排水量5.06亿立方米。
