土木在线论坛 \ 电气工程 \ 电气资料库 \ 安科瑞霍尔传感器在印度尼西亚的应用
安科瑞霍尔传感器在印度尼西亚的应用
发布于:2021-08-06 22:08:06 来自:电气工程/电气资料库 [复制转发]
1. 摘要 Abstract:
??本文介绍了霍尔传感器在印度尼西亚的应用。霍尔电流传感器主要用于隔离和转换交流、直流、脉冲等复杂信号。根据霍尔效应理论对电流信号进行信号控制转换后,可直接被AD、DSP、PLC、二次仪表等设备获取。霍尔电流传感器广泛适用于电流监测、电池应用、逆变器、太阳能发电等领域的采集和反馈管理、直流柜、直流电机驱动、电镀、焊接、变频器、UPS伺服控制系统。具有响应快、测量范围广、精度高、过载能力强、线性度好、抗干扰性能好等特点。
??This article introduces the application of the Hall Sensor used in Indonesia. Hall current sensors are mainly used to isolate and convert AC, DC, pulse and other complex signals. After signal control of current signals are converted according to the Hall Effect Theory, they can be directly acquired by AD, DSP, PLC, secondary instruments and other devices. Hall current sensors are widely applicable for acquisition and feedback in the current monitoring, battery application, inverter, solar power management, direct current cabinet, DC motor drive, electroplating, welding, frequency converter, UPS servo control systems. They feature the quick response, wide range of measurement, high precision, strong overload capacity, good linearity and excellent anti-interference performance.
??2. 项目概述 Project overview:
??做交通信号灯系统的印尼公司,需要使用直流霍尔传感器将直流电流传输到4-20mA模拟信号输出。客户在选择开孔尺寸、输入比、输出比和工作电源后,选择了AHKC-EKAA作为他们的最佳选择。
??The company in Indonesia who make the traffic light system and need to use DC hall sensor to transmitter the DC current to 4-20mA analog signal output. After they choose the hole size, input ratio, output ratio and working power supply, the customer chosen the AHKC-EKAA as their best choice.
??3. 分类Classification
??霍尔传感器按原理分为三类:开环霍尔电流传感器、闭环霍尔电流传感器、霍尔电压传感器。
??Hall sensors are divided into three categories according to the principle: open loop Hall current sensor, closed loop Hall current sensor, Hall voltage sensor.
??4. 应用Application
??光伏Photovoltaic
??UPS
??太阳能,风能Solar and wind energy
??电焊机Electric welding machine
??电机系统Motor servo system
??整流器Rectifier
??5. 主要功能Main Functions
??6. 产品选型Product Selection
??7. 现场安装图Photos on site
??参考文献Bibliography
??1. Solutions for Hall Sensor 2021.4
??2. Acrel Hall Transformer
电气资料库
70.19 万条内容 · 799 人订阅
安科瑞医用隔离电源系统在广东省某医院项目中的应用
摘要: 介绍该三级甲等医院采用安科瑞隔离电源系统七件套,使用落地式配电柜安装方式,从而实现将TN系统转化为IT系统,以及系统绝缘情况监测。 ??关键词:医用隔离电源系统;IT系统;绝缘情况监测;三级甲等综合医院。 ??0:概述 ??该院始建于1946年,占地5.1万平方米,建筑面积达10万多平方米,是一所集医疗、预防、科研、教学、康复为一体的综合三级甲等医院。医院先后获得省卫生厅授予的“百家文明医院”、全国“巾帼文明岗”等荣誉。
