土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 6.4米面宽,100米高的摩天大楼,“铅笔”酒店的设计方案
发布于:2021-07-13 09:41:13 来自:建筑设计/公共建筑设计 [复制转发]
澳大利亚建筑公司Durbach Block Jaggers公布了悉尼铅笔塔酒店的设计方案。作为英国最薄的摩天大楼,该项目将将在皮特街410号升起,高宽比为16:1。
173间酒店客房,每层6间套房,100米高的塔楼将建在市中心,临街只有6.4米宽。
Australian architecture firm Durbach Block Jaggers has unveiled a design for the Pencil Tower Hotel in Sydney. Designed to be the country's thinnest skyscraper, the project would rise at 410 Pitt Street with a height-to-width ratio of 16:1. With 173 hotel rooms with six suites on each floor, the 100-metre-high tower would be built in the downtown area with street frontage only 6.4 meters wide.
根据团队介绍,“铅笔”塔将在一个低规模的平台上上升,使用拱形砖的造型,参照其传统邻居的精致和细节。
三层的体量包括大堂、咖啡厅和休息室,通过大型锁眼窗口可以看到,而一个共享使用的封闭式庭院花园可以俯瞰街道。
According to the team, the ‘pencil’ tower would rise on a low scale podium referencing the delicacy and detail of its heritage neighbors using the language of arching brickwork. A three story volume includes levels of lobby, cafe and lounge, visible through a large scale keyhole window, while a walled courtyard garden for shared use overlooks the street.
该塔的设计通过对基础、轴和柱头的连续抽象来模拟柱子的压缩和延伸。这座首都被表达为一个飞行阳台和贝壳曲线的屋顶日光浴平台,游泳池和“浴室”水疗中心。
The tower was designed to simulate the compression and extension of a column through a continuous abstraction of its elements: base, shaft and capital. The capital is expressed as a flying balcony and shell curves of a rooftop sundeck, pool and “hammam” spa.
设计师继续解释说,外墙将从压缩的水平屏蔽开始,在顶部慢慢转化为夸张的垂直。水平线开始时很宽,与外框平齐,慢慢变薄和后退的高度塔。
The designers go on to explain that the facade would begin with compressed horizontal screening, slowly transforming into exaggerated verticals at the top. Horizontals begin wide and flush with the outside frame, slowly thinning and receding at the height of the tower.
“每个水平高度是板面的高度,扶手和门头的高度。每一层都有紧凑的酒店房间,从街道、后庭或内部空间收集光线。空隙被铺上瓷砖,将光线和颜色反射到房间里。”与此同时,匙孔窗户将为无缝的瓷砖表面提供一个有框架的小景。
"Each horizontal is at the height of the slab, handrail and door head height. Each floor houses compact hotel rooms, gathering light from the street, rear court or internal shapely voids. The voids are tiled to reflect light and colour into the rooms." At the same time, key hole windows would provide a framed vignette of the seamless tiled surface.
建筑师:Durbach Block Jaggers
地点:澳大利亚
公共建筑设计
51.18 万条内容 · 448 人订阅
屋檐下的图书森林
这是一个在日本长崎的日托所项目。一个最近令人担忧的问题是,过多的看屏幕的时间会对孩子的语言能力产生负面影响。另一方面,大声朗读以及儿童与成年人之间的互动交流,可以使他们的行为问题和给父母的压力减轻。在这样的背景下,我们的想法是利用“屋檐下的图书森林”,自然地赋予孩子阅读和朗读的能力,并培养他们丰富的思维方式。
