土木在线论坛 \ 人才招聘 \ 企业招聘 \ Metal Roofing Inspectors-珠海枫叶建设管理有限公司
发布于:2021-07-06 14:21:06 来自:人才招聘/企业招聘 [复制转发]
Minimum Qualification and Experience:
i. Higher Certificate I Higher Diploma in Building / Structural Engineering or other related disciplines with at least 8 years' experience or Degree holder with at least 4 years' relevant experience.
ii. The relevant experience in metal roofing, must have been gained within the previous 4 years and have experience in large scale Hong Kong projects or similar international projects.
iii. Proficient in Microsoft Office applications.
iv. Be fluent in spoken and written English and Chinese. Be fluent in spoken Putonghua.
Particular Inspection Duties:
i. Record in & out materials with traceability system.
ii. Check materials and mill certificates.
iii. Check aluminium cladding and assembly dimensions.
iv. Check aluminium cladding aesthetic appearance.
v. Check aluminium cladding flatness and roller wave distortion.
vi. Inspect structural sealant caulking process.
vii. Inspect pre-treatment and chromate coating.
viii. Inspect PVF2 or powder coating process.
ix. Check dry film thickness, gloss level, adhesion and hardness of coatings.
x. Inspect sealant compatibility test and adhesion test.
xi. Check colour and gloss uniformity.
xii. Inspect factory internal QC testings, such as dry adhesion test, solvent test, structural sealant test, chemical resistance test, boiling water adhesion test, acetic acid salt spray test, impact test, snap test, gasket hardness test, alum stud bend and re bend test etc.
xiii. Inspect seam joint test and flood test, holiday test, spray test, skylight test, etc. as per Particular Technical Specification.
xiv. Inspect final assembled products if fabricated as the Approved drawings.
xv. Check panel numbering system of the final products.
xvi. Check panels packing and protection of the final assembled products.
xvii. Inspect performance mock up fabrication, set up and testing.
工作地点:广东珠三角周边
请发英文简历到: sophia.huang@pmiint.com
We are an International Construction Project Management and QA/QC consultancy firm that offers Expatriate Managers with highly qualified local Supervision teams to oversee manufacturing, fabrication, procurement and supply chain management. Find out more on:
www.pmiint.com
企业招聘
12.91 万条内容 · 384 人订阅
北京地区 建筑给排水设计岗招聘(2021年6月)
我司是做管道直饮水工程的,是项目的投资、开发、建设、运营方,因业务开展需要,现急招募给排水专业人士:公司地址在海淀区西北三环附近,岗位薪资范围10K-20K,朝九晚六周六日双休,五险一金,免费午餐;有意者请电联:13661152789  胡先生欢迎自荐、推荐;岗位描述:岗位职责:1.负责民用建筑的的给排水施工图设计及管理工作;2.负责对接目标小区设计单位,获取小区建筑图纸,对接沟通图纸技术要点等,绘制管网图;
