土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 经典立面“阶梯式”建筑
经典立面“阶梯式”建筑
发布于:2021-06-25 10:02:25 来自:建筑设计/公共建筑设计 [复制转发]
建筑公司Urban Agency分享了他们在加拿大温哥华森林开发的新细节。该项目从该地区的森林地区获得灵感,包括木材、竹子和绿色植物,为城市形成一个可持续的街区。
作为一系列阶梯式露台,该项目被设计成一个“有生命的天篷”,树木和树叶沿着建筑围护结构生长。
Architecture firm Urban Agency has shared new details of their Vancouver Forest development in Canada. Taking inspiration from the forest regions of the area, the project includes timber, bamboo and greenery to form a sustainable block for the city. As a series of stepped terraces, the project was designed as a 'living canopy' with trees and foliage growing along the building envelope.
正如团队解释的那样,温哥华森林项目包括私人公寓和社区空间。建筑的前三层是两个独立的单元,而从第四层开始,它们被融合在一起。
由此产生的室外通道通过建筑的核心向公共领域开放,并提供平行街道之间的连接。在结构上,该设计包括一个竹制CLT框架。
As the team explains, the Vancouver Forest project includes both private apartments and a community space. The development is expressed as two separate units for the first three floors, while from the fourth floor, they are then fused together. The resulting outdoor passage through the building’s core opens to the public realm and offers connectivity between parallel streets. Structurally, the design comprises a bamboo CLT frame.
继续场地连接,社区空间位于较低的三层,更紧密地融入城市肌理。上面的楼层是私人公寓。随着建筑的上升,这些层次在南端一系列阶梯式露台中逐渐后退。
这使公寓沐浴在阳光下。在形式上,每层楼的角落都是弯曲的,以软化建筑的外观。沿着立面,结构设想为有树叶、树木和植物,以及生长在露台上的绿色植物。
Continuing the site connections, the community spaces are located on the lower three levels which are more tightly knit into the urban fabric.The levels above are dedicated to private apartments. As the building ascends, these levels gradually recede in a series of stepped terraces from the south end. This exposes the apartments to sunlight. Formally, the corners of each floor are curved to soften the building’s appearance. Along the facade, the structure is envisaged with foliage, trees and plants, as well as greenery growing on the terraces.
用地面积
设计构思
建筑师:Urban Agency
地点:加拿大
面积:33150平方英尺
公共建筑设计
51.18 万条内容 · 448 人订阅
275米!纽约曼哈顿的全新超高层设计,形如“竹子”
 以下文章来源于:设计时讯城市的伟大之处在于它们所拥有的特别的建筑作品。即使它们的饮食、音乐或者整体的生活方式都很棒,缺少建筑会使它们变得弱化而难以在脑海中留下印象。自纽约世贸双子塔被毁后,近二十年来,一批造型别致、耗资巨大的超高层项目,无不期望成为世界第一大城市的封面级建筑。由SHoP建筑事务与开发商之一JDS公司合作完成的曼哈顿下东区全新超高层,正是其中之一。
