土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 书一自习室,上海多么工作室Atelierd’More
发布于:2021-05-07 11:54:07 来自:建筑设计/公共建筑设计 [复制转发]
  感谢 多么工作室Atelier d’More 的分享
△ 室外航拍
多么工作室受委托为书一自习室设计其在上海的首家店,希望在城市中设立一处柔软的栖息地供奋斗的人们充电。项目位于上海青浦宝龙广场写字楼十层的西北角,由西北两侧的落地玻璃窗和东南两侧的白墙围合而成。初次勘察场地时,正遇黄昏时刻,阳光穿过建筑整面的落地窗,   肆意地霸占了整个场地,窗外则是被夕阳渲染殷红的青浦城市天际线。
Atelier d ’ More was commissioned to design  a self-study room for Bosuer as  its first store  opening  in Shanghai, hoping to create a soft habitat in the city where struggling people can recharge. The project is located in the northwest corner of the 10th floor of Baolong Plaza office building in Qingpu, Shanghai. It is enclosed by floor-to-ceiling glass windows on the northwest and white walls on the southeast sides. It was dusk when the design team encountered the site for the first time, the sunlight penetrated through the windows of the building, shinning over the whole site, and the view of Qingpu skyline reddened by the setting sun was just outside the window.
△ 吧台与储物柜
自习室的特性决定了其在隔音上会有较高的要求,我们希望营造一个安静的自习空间,同时提供一个休闲空间供用户放松休息,如何排布这些功能体块,使各个空间互不干扰又相互连通是我们在平面布局阶段重点考虑的问题。
△ 插画动图 gif?atelier d'more
△ 平面图 plan?atelier d'more
我们根据隔音等级将空间划分为活跃区、相对安静区和静音区,因此空间的动线设计和排序围绕隔音要求形成了三个层次,由休闲区进入到开放自习区,再到沉浸式自习区,通过逐层的缓冲,噪音递减,物理环境上和用户心理上都得到了有效降噪。
The characteristics of the study room determine that it will have higher requirements in sound insulation. We hope to create a quiet study space, and provide a leisure space for users to relax as well. Our key concern in the stage of plane layout is how to arrange these functional blocks, so that each space does not interfere with each other while connection can be found in between.
△ 动态轴测图 axonometric gif?atelier d'more
△ 开放自习区概览
△ 童心园小木屋
△ 俯瞰沉浸自习区
入口形象设计上,我们试图创造出一个走廊尽端的视觉焦点,给这个原本枯燥冷漠的写字楼带来一抹暖暖的柔软。蜿蜒起伏的吊顶隐藏着错综复杂的管线,以整洁柔软的形象示人。原始建筑内的混凝土楼板穿梭在云朵般的吊顶之间,仿佛这里是一个从钢筋混凝土城市里生长出来的温柔乌托邦。
In the design of the entrance image, we intend to create a visual focus point at the end of the corridor, bringing a touch of warmth and softness to the office building. The gently undulating ceiling, conceals intricate pipes, which shows  an  image of neat and soft. The concrete floor slabs of the original building weave through the cloud-like ceiling, as if it were a gentle utopia that grew out of a reinforced concrete city.
△ 储物柜和换鞋区
△ 换鞋区入口
△ 从入口区域看吧台
在开放式自习区,我们设计了不同类型的自习座位来满足不同的需求。沿北侧落地玻璃窗是一个个独立的景观位,每个座位之间以透光的布帘相隔,帘子排成一列,形成书页的形式,以 “布书”隐喻“不输”。
In the open study area, we designed different types of seats to meet different needs. Along the floor-to-ceiling glass windows at the north side are the independent seats with a good view. Each seat is separated by a translucent curtain. The curtains are arranged in a row to form the form of pages, which "cloth book" is a homonym for "not losing".
△ 从开放自习区看鸟巢
△ 面前是大海,身后是森林
在与景观位相邻的单排自习座上方,悬挂着 4 个可升降的装置,用户可以通过桌面上的开关控制升降。当装置降至桌面,它在视线上阻隔了有人经过时的干扰,帮助用户更专注于自己的桌面。
Above the single row of self-study seats adjacent to the window seats, there are four lifting devices. The users can control the lifting through the switch on the desktop. When the device is lowered to the desktop, it blocks the interference when someone passes by and helps users focus     more on their desktop.
△ 可升降装置
开放式自习区中心位置的二层小屋,为双人学习包间。我们在一层选择了透光的材质做围合从而增加空间的层次感,同时保持视觉的通透感。在二层则以木板围合,给与内部更多安全感。
The two-story cabins in the center of the open study area are designed to be double study rooms. We chose a translucent material as the enclosure of the first floor  o f the cabins to increase the hierarchy of the space, while maintaining the visual translucency. And the second floor is enclosed with wood panels to give more security.
△ 从休闲区进入自习室区的门洞
△ 沉浸自习区局部
△ 沉浸区的单人格子间
△ 沉浸区的上下层单人学习间
△ 沉浸区的上下层双人间
偶尔开个小差,也是休息的方式之一,在有限的空间内增加一处休息之地, “鸟巢”应运而生。考虑到建筑层高优势,我们创造了一个立体可攀爬空间,利用爬梯从洞口进入,既可以躺着休息,也可以通过侧壁上的小洞看到窗外的风景。
Mind wandering can be one of the ways to get rest. The “Bird's Nest” was created to add a resting place within a limited space. Taking advantage of the height of the building, we created a climbing space, which is accessed from the opening by a ladder, where you can either lie down and rest, or look out the window through a small hole in the side wall.
△ 沉浸自习区双人间入口
△ 小屋内部
△ 小屋内部
窗前的波浪台阶仿佛延绵的沙丘,而整墙的书架是等待探索的森林。沿着西侧落地窗的空间留给了休闲区,不仅仅是因为这里有最美的风景,最温暖的夕阳,也是因为考虑到西晒的因素,这里并不适合设置自习座位,所以短时间逗留的休闲区是最好的选择。休闲区与自习区之间隔墙上的小圆洞,是我们留给自习区的小彩蛋,到特定的时间夕阳会穿过洞口照入自习区,两个相隔的空间在此时共同分享自然赐予的美好瞬间。
The wavy steps in front of the window are like rolling sand dunes, while the whole wall of bookshelves is like a forest waiting to be explored. The space along the windows on the west side is set for the leisure area, not only because it has the most beautiful scenery and the warmest sunset, but also considering the heat of the setting sun, it is not suitable for setting up seats for self-study, so the leisure area for short stay is the best choice. The small round hole on the partition wall between the leisure area and the self-study area is a little surprise designed for the self-study area. At a certain time, the setting sun will pass through the hole and shine into the self-study area, and the two separated spaces will share the beautiful moments of nature.
△ 比拉沙丘概览
△ 比拉沙丘局部
我们相信一个好的场所是可以与人产生互动,让人有兴趣去探索和体验的。大到空间的造型,小到挂衣钩的设计,都有我们对于未来探索的思考在其中。空间中的几何元素,好似纪念碑谷般,每一个台阶、每一个门洞都在呼唤你前进。
We believe that a good place is one that people can interact with, which people are interested to explore and experience. From the large space to the small objects, there are reflections on our future exploration. The geometric elements in the space are like Monument Valley, where every step and every door is calling you forward.
△ 开放自习区局部
△ 休闲区
△ 从公共区观看夕阳下的城市天际线
△ 聚碳酸酯板书架细部
项目信息
项目名称: 书一自习室,上海
设计建筑事务所:多么工作室
主创建筑师: 王维,盛乐
完成年份:2021年
建筑面积:180㎡
项目地址:中国上海摄影: YR.Bao
业主:书一自习室
Project: Bosuer Study Room, Shanghai
Design:Atelier d’More
Chief Architects: Wei Wang,Le Sheng
Completion date:2021
Area:180㎡
ChinaPhotography: YR.Bao  client: Bosuer Study Room
  • lijiawei411
    lijiawei411 沙发
    2021-05-10 17:16:10
公共建筑设计
51.18 万条内容 · 448 人订阅
旅游 民宿客栈建筑设计:西班牙橄榄园乡村酒店案例
项目建筑面积1006㎡,是以一间现存的传统农舍(Cortijo)为基础建成的酒店,修复这样的一栋坐落在橄榄树种植园内、年代久远的老房子,并使其重新投入使用,是一件非常有挑战性的任务。 酒店的公共区域和半数客房都被安排在了农舍建筑内,再搭配上充满年代感的建筑材料和尺度,使这座酒店拥有了无法复制的独特形象 酒店另一边,建筑师刻意运用当代的手法,使用截然不同的材料和更加纤细的尺度设计了另外十间客房。室外的露台被设计成了集散住客并带有游泳池、spa、和其他休闲设施的广场。
