土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 简约现代多层办公大楼
简约现代多层办公大楼
发布于:2021-04-26 10:07:26 来自:建筑设计/公共建筑设计 [复制转发]
多年来,这座旧体育场的记分牌在雾气蒙蒙的维尔纽斯市中心上空闪闪发光,告诉人们正在发生的不寻常事件,吸引着无数市民——“1:0”或者“进球!”记分牌的黑色像素状结构是城市轮廓的一个组成部分,在城市记忆中扮演着重要的角色。
The scoreboard of the old stadium shone above the misty Vilnius city center for many years, informing about unusual events happening and attracting crowds of citizens, - “1:0” or maybe “GOAL!”? That dark, pixel-shaped structure of the scoreboard was an integral part of the city’s silhouette and played an important role in urban memory.
我们决定利用这一强烈的形象,参加在原体育场的场地上举行的建筑办公楼竞赛。最初的纪念碑,像素化外墙和躺方尖碑式的结构,坐落在城市最重要的动脉之一。对于我们来说,创造一个外向型的综合体是很重要的,它让光线和人可以流畅地穿过建筑,让我们找到一个娱乐、工作和观察城市生活的地方。
We decided to take advantage of this strong image by participating in an architectural office building competition that was held on the site of the former stadium. The original monumental, pixelated fa?ade and lying obelisk-like structure, settled along with one of the city’s most important arteries. It was important for us to create an extraverted complex that lets the light and people flow fluently through the building, allowing us to find a place for recreation, work, and observation of urban city life.
近180米的建筑结构由中庭的体量划分。中庭位于城市轴线上,从西面的街道,让太阳照亮东面的广场。主入口位于北侧,在这里最大的体量切割形成了对空间的最大开放。所有的“切口”都是由透明的、漂白的玻璃制成的。这种明暗效果不仅有助于识别出入点,还在光学上将体量划分为多个部分——体量在尺度上变成了情境。
The nearly 180 m long structure of the building was divided by the volume of the atrium. The atrium settled on the urban axis from the street on the west letting the sun illuminate the square on the east. The main entrance is provided on the north side, where the largest volume cut on the corners forms the maximum opening to space. All "cutouts" are made of clear, bleached glass. Such a light-dark effect not only helps to identify points of access but also optically divides the volume into parts - volume becomes contextual in scale.
在黑暗的外墙办公空间后面,像素结构部分的设计确保了整个建筑环境的概览。深色的铝型材突出了单个单元的结构(像素),也隐藏了为每个工作场所提供自然通风的通风口。
Behind the dark, pixel-structured parts of the fa?ade office spaces are designed to ensure an overview of the whole building environment. The dark aluminum profiles highlight the structure of the individual cells (pixels) and also hide the air vents providing natural ventilation for each workplace.
中庭被设计成光的绿洲,其中的吊桥和会议室打开了维尔纽斯的全景,并为社会互动提供了空间。为了最大限度地提高透明度,设计了悬挂玻璃墙,由特殊的电缆支撑。中庭以光线为主——室内采用白色的水磨石地板、漂白的玻璃墙和白色的结构。
The central atrium designed as an oasis of light where hanging bridges and meeting rooms open the panoramas of Vilnius and provide spaces for social interactions. In order to maximize transparency, the hanging glass walls were designed, which are held by special cables. The atrium is dominated by light - the interior is designed with white terrazzo floors, bleached glass walls, and white-painted structures.
在一层形成的切口创造了一个悬浮结构的印象。这些雕刻的空间用于地下停车场的有盖通道,而在东侧的切口是一个小的“论坛”,在这里你可以观看活动,找到避雨的地方,并在冬天获得温暖。它的选址并非偶然——它曾经是旧体育场的中央护坛。
The cutouts formed on the ground floor create the impression of a levitating structure. These carved spaces are used for covered access to the underground parking while on the east side the cutout is made for a small “tribune”, where you can watch the events, find shelter from the rain, and warm in the winter. Its location was chosen not accidentally - it was once the central tribune of the old stadium.
然而,建筑和城市之间的积极互动并不仅仅停留在一层的开口。建筑的屋顶也成为举办活动和欣赏城市全景的重要场所——它打开了维尔纽斯的主要象征——gedianas城堡塔的视野。这座建筑从不睡觉——有人在交流,有人在工作,有人坐在露天剧场欣赏街舞。在今天的记分板上,市民们会看到什么:“1:0”,还是“我爱你”?
However, the active interaction between the building and the city does not stop only on the ground floor openings. The rooftop of the building also becomes a vital place for events and views of the city’s panoramas – it opens the views of the main symbol of Vilnius - the tower of Gediminas Castle. The building never sleeps - someone is communicating, someone is working, someone is sitting in the amphitheater enjoying the street dance. What will the citizens see today on this scoreboard: "1 : 0", or maybe "I LOVE YOU"?..
区位图
场地平面图
平面图
西立面图
剖面图
设计理念图
模型图
建筑师:arches
地点:立陶宛 维尔纽斯
面积:25250 m2
年份:2020
公共建筑设计
51.18 万条内容 · 448 人订阅
竹“伞”,佛山黄龙滨水竹廊竖梁社-华南理工大学建筑学院
? 李锐波 600年前的护龙桥静默不语,300年前的杜氏祠堂肃穆而立,黄龙村浓厚的历史质感穿过南安巷,与富临公园两座火红的雕塑交相辉映,历史与现实在这里巧妙交融。黄龙滨水竹廊2.0位于广东省佛山北滘镇黄龙古村。北滘,古称“百滘”,意为“百河交错、水网密集”。典型的岭南水乡内,滨水的灰空间气候适宜。在黄龙村,大大小小穿插在村子里的公共空间是黄龙村最具人气与场所魅力的活动场所。融合自然更成为居民们生活、闲聊与娱乐的亲水营地。
