土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 301米高,游泳池屋顶!!迪拜“椭圆型”酒店 公寓塔楼
发布于:2021-04-15 10:04:15 来自:建筑设计/公共建筑设计 [复制转发]
killa设计公司完成了 "地址海滩度假村 "塔楼,该塔楼耸立在迪拜的海岸线上。该塔楼由一个单一的结构定义,被一个狭窄的中央空隙所打断,两座细长的塔楼与一个广阔的游泳池屋顶相连接。
该项目高达301米,即近1000英尺。两座塔楼 规划 有酒店和住宅。西半部有14层酒店和54层服务公寓,东半部有68层住宅公寓。
killa design completes its ‘address beach resort’ tower, which rises above the shoreline of dubai. the tower is defined by a single structure interrupted by a narrow central void, suggesting two slender towers which reconnect with a sweeping, pool-topped rooftop. the project rises to a height of 301 meters, or nearly 1,000 feet. the two towers are organized with both hotel and residential programming. while the western half hosts 14 floors dedicated to hotel and 54 floors of services apartments, the eastern half is occupied by 68 floors of residential apartments.
屋顶上的 游泳 池 ?
Killa Design的团队为其 "地址海滩度假村 "点缀了一个屋顶餐厅、酒吧和无边泳池。同时,在整个塔楼、泳池甲板以及作为迪拜码头入口的护栏尽头,都可以看到各种特色餐厅和全天营业的餐厅,以及充满设计感的酒吧。
停车场位于大楼的地下三层,而三层裙楼则设有代客泊车位,为酒店服务。
the team at killa design punctuates its ‘address beach resort’ with a roof-top destination restaurant, bar and infinity pool. meanwhile, a wide selection of specialty and all-day dining restaurants, along with design-minded bars, are discovered throughout the tower, on the pool decks, and at the end of the revetment as an entrance to the dubai marina. car parking is located along the three basement levels of the building while three podium levels host valet parking to serve the hotel.
Killa Design的 "地址海滩度假区 "塔楼采用椭圆计划,而其中央的空隙则是为了增加自然阳光。竖直的空隙进一步提升了棕榈树、迪拜JBR海滩和远处地平线的视野。
从本质上讲,这栋建筑具有两座塔楼的功能,两座塔楼分别由底部的大堂和顶部的顶层公寓和空中阁楼连接。
killa design’s ‘address beach resort’ towers are expressed with an elliptical plan while its central void serves to increase natural sunlight. the vertical void further enhances views out across the palms, dubai’s JBR beach, and the distant horizon beyond. in essence, the building functions as two towers with separate cores that are connected by the lobby at its base and by the penthouses and sky lofts at the top.
屋顶上的 游泳 池
建筑师:killa
地点:迪拜 阿拉伯联合酋长国
年份:2020
公共建筑设计
51.18 万条内容 · 448 人订阅
入“洞”,海口云洞图书馆MAD建筑事务所
收录于话题 ? 存在建筑 ? 存在建筑 “海口云洞图书馆”是大型国际公共艺术项目“海口·海边的驿站”中第一个落成的高标准驿站,该项目是邀请十余位全球顶尖的建筑师、艺术家以及跨学科专家共同打造的 16座地标性公共驿站 ,以“自然·共生·未来”为理念的精品民生工程。   项目地处海口湾畔的世纪公园,占地面积4397平方米,建筑面积1380米,包含书馆和市民活动配套:建筑南侧的书馆,内含可以藏书万本的的阅读空间及多功能影音区,向公众免费开放。北侧为向人们提供服务的设施,包括咖啡厅、公共卫生间、无障碍卫生间、淋浴间、母婴室、公共休息区及屋顶花园。ArchDaily
