土木在线论坛 \ 园林景观 \ 园林绿化养护 \ 树林环抱的生态休闲交流空间
树林环抱的生态休闲交流空间
发布于:2021-04-07 17:06:07 来自:园林景观/园林绿化养护 [复制转发]
这是位于日本岐阜县关市的产业园区 "Nabeya Bi-tech Kaisha "的小型交流广场,约有400名员工在该工厂工作,从事运动控制技术的机械元件和部件的设计、制造和销售。这个广场是作为工作场所与停车场的连接点,主要空间是一个楼梯。在建设之前,园区内很少有与建筑物外的工人交流的空间,在前董事长的花园式工厂理念下,这个广场被设计成森林环绕的交流空间,广场旁边的建筑设有休息空间和健身俱乐部,使广场成为职工交流的场所。
This is a small communication plaza for the industry campus "Nabeya Bi-tech Kaisha" in Seki, Gifu, Japan. About 400 people work in this factory for design, manufacturing and sale of machine elements and components for motion control technology. This plaza is constructed as connection points from workplace to parking area with the staircases. Before the construction, in the campus there is few spaces to communication with workers outside buildings. Under the garden factory concept by former chairman, this plaza is designed as communication space surrounding with forest. The building next to the plaza has rest space and fitness club, so that the plaza can play a role of communication place for workers.
广场的构成非常简单,白色混凝土的弧形长椅,木质平台作为平台。长椅的形状是弧形的,可以接受和容纳人们在那里交谈,长椅的脚部空间用鲜艳的橙色作为校园主轴线的端点,邀请人们前来。长椅背面与主干道的宽度比正面宽,使人感到放松。长椅上方的桌子轻巧地摆放着布巾,上面有弧形的冲压金属和深色的结构。
Composition of the plaza is so simple with a curved white concrete bench, wooden decks as a terrace and a table with white punching metal. The shape of bench is curved to receive and hold people to talk and communication there. Foot space of the bench is colored with vivid orange as an end point of main axis of the campus to invite people to come. Width of the bench in backside from main path is wider than in foreside to much relaxative. The table is placed above the bench lightly as fabric scarf with curved punching metal and dark colored structures.
傍晚时分,由于缺乏照明和周围的森林,广场上一片漆黑,主要是照明设备只配备在校园内只有冷色光的道路上。我们尝试在工厂内设置家庭空间,用暖色的灯光来沟通工人之间的交流。暖色调的橘色照明,配合立体曲线的长椅,将空间作为工厂内的特殊照明颜色,邀请您来参观。桌灯和杆灯的层叠照明,产生空间的深度和夜间活动的印象空间。
In evening time, the plaza was dark because of lack of lighting and surrounding forest. Mainly lighting are equipped only for roads with only cold colored light in the campus. We try to set home space in the factory to communicate between workers with warm lighting. Warm orange colored lighting with the three dimension-curving bench invites you the space as special lighting color in the factory. Layer lighting with table lighting and a lighting with a pole generates depth of the space and impressive space with night activities
园林绿化养护
3.99 万条内容 · 192 人订阅
农业温室地面硬化后如何选购苗床才能物有所值?
农业温室一般建好后,为了方便种植花卉或者育苗后期还会选购苗床,方便后期管理,而苗床大意可分为固定苗床,移动苗床,潮汐苗床,三大类,在选购的时候要根据自身大棚的规模以及资金情况来选择合适的苗床。 先来简单介绍下这三类苗床。 固定苗床  相对价格低廉的苗床,一般日光棚或者建议大棚会用到,它没有防范限位装置的,因为固定苗床使用了竖支撑也就没有必要再安装滚轴管了。高度放方便种植户不弯腰,减轻劳动力。
