土木在线论坛 \ 园林景观 \ 景观规划设计 \ 解构主义艺术花园IlGiardinoDeiPassiPerduti
发布于:2021-03-29 14:06:29 来自:园林景观/景观规划设计 [复制转发]
在考虑如何与卡洛-斯卡帕在Castelvecchio的作品进行对话时,我们选择了在看似不同的路径上的反思,也代表了对建筑内部学科逻辑的寻找。 这种反思将是项目及其批判性反思的综合,将主题和对象结合在一起,超越了它们以前的限制。 它将试图将项目重塑为一个批判性的项目,这个想法更能实现,因为它必须解决斯卡帕作品的碎片化和诗意的一面。
When considering ways to have a dialogue with the work of Carlo Scarpa at Castelvecchio, we chose to demonstrate that the struggle over seemingly disparate paths also represents a search   for an internal disciplinary logic for architecture. This reflection would be an amalgam of projects and their critical reflection, an excessive “hypertext,” as it were, combining text and objects    beyond the limits of their former textuality. It would attempt to reinvent the project as a metacritical one, an idea that is more problematic, but also more realizable, because it must address the fragmentary and the poetic aspect of Scarpa’s work.
展览本身是一个位于花园中的说教作品以及位于画廊中的零碎作品的项目。斯卡帕在内部的五个展室中放置了条形混凝土地板,这五个广场在花园中被替换成五个"挖掘"的垫子,位于平行于内部房间序列的轴线上。第二个,轴线在花园中对角线移动,与斯卡帕的垫子相交并交叉。它在Scarpa的空间序列的末端键掉了旋转的房间,暗示着倾斜的轴线预先存在。当人们从Scarpa的转角桥向博物馆入口移动时,混凝土垫就会显现出来。垫子裂开后,露出了艾森曼项目卡纳雷吉奥、IBA社会住宅、韦克斯纳艺术中心、Quai Branly博物馆和加利西亚文化城,它们从地面上迸发出 "时间重获 "的普鲁斯特式品质。
The exhibition itself is a project located as a didactic work in the garden and as a fragmentary  work in the galleries. Scarpa placed striated concrete floors in the five interior exhibition rooms. These five squares are replaced in the garden as five “excavated” pads, located on an axis  parallel to the internal sequence of rooms. A second, Eisenman axis move diagonally across the garden, intersecting with and crossing over Scarpa’s pads. It keys off the rotated room at the end of Scarpa’s sequence of spaces, suggesting that the skewed axis preexisted. The concrete pads are revealed as one moves from Scarpa’s corner bridge toward the museum entry. The pads  crack open to reveal an amalgam of Eisenman project – Cannaregio, IBA Social Housing, the Wexner Center for the Arts, the Musée di Quai Branly, and The City of Culture of Galicia – which erupt out of the ground with a Proustian quality of “time regained.”
在内部,项目作品的碎片性与Scarpa和他的主题形成对峙。这些被 "挖掘"出来的柏林网格和圣地亚哥的笛卡尔网格的碎片,被涂成红色,作为一系列诗意的残留物出现在Scarpa的地板和城堡的走道之间的间隙中。在这里,就像在花园里一样,时间变成了通往过去和未来地方的交叉路径网络的一部分。作品不再是一个博物馆展览(博物馆中的展览),而是对博物馆本身性质的改造。
Inside, the fragmentary nature of the project pieces confronts Scarpa and his thematic. These fragments of the “excavated” grid of Berlin and the Cartesian grid of Santiago, painted red, appear as a series of poetic residues in the interstices between Scarpa’s floors and the walks of the    castle. Here, as in the garden, time becomes part of network of crossing paths to a past and future place. The work is no longer a museum exhibition (an exhibition in a museum) but rather a transformation of the nature of the museum itself.
▼平面图 Plan
景观规划设计
25.18 万条内容 · 282 人订阅
绽放在春城活力城市综合体典范:昆明恒隆广场
这里的四季只剩下春天 。 昆明恒隆广场位于昆明主城核心区域,东风东路与北京路的交界,紧邻昆明轨道交通2号线与3号线交换站——东风广场站。 恒隆广场是昆明市最大的商业综合体之一,同时,恒隆广场办公楼也是昆明的第一高楼。优越的地理位置,加上具有纪念意义的体量,项目从诞生之初一直备受瞩目。
