继纽约蜿蜒曲折的摩天大楼方案之后,Hayri Atak建筑设计工作室又推出了另一个引人注目的概念。
这次,工作室分享了其设计的152间客房的 "生态漂浮酒店",设想在卡塔尔海岸。
设计的目的是最大限度地减少能量损失,并以零浪费为原则,该方案包括一个旋转系统,该系统可以移动建筑物以产生电能。
following its sinuous skyscraper proposal for new york, hayri atak architectural design studio is back with another eye-catching concept. this time around, the studio shares its design for a 152 room ‘eco-floating hotel’ envisioned off the coast of qatar. designed to minimize energy loss and with a zero waste principle, the scheme includes a rotating system that moves the building around to generate electrical energy.
生态漂浮酒店的建筑形式和运营灵感都来自于大海,尤其是漩涡。"为酒店提供通道的码头是静止的,但HAADS设想圆环形的酒店会慢慢地旋转,在24小时内通过持续的水流完成一个完整的圆圈。"
酒店有三个不同的入口,由于周围有140度的码头,可以在一天中的任何时间从岸边进入。
both the architectural form and operation of the eco-floating hotel are inspired by the sea and in particular, a vortex. the pier that provides access to the hotel remains static but HAADS envisions the circular-shaped hotel to slowly revolve, completing a full circle in 24 hours with a continuous current. the hotel features three different entrances that provide access from the shore at any time of the day thanks to the 140-degree pier that surrounds it.
旋转系统利用动态定位(DP),这是一个计算机控制系统,可以自动保持船舶的位置。"HAADS的设计团队以设计一个具有 "生态平衡 "的项目为目标,整合了一套名为VAWTAU的绿色能源生产系统,即垂直轴风力涡轮机和太阳伞。"
在垂直平面上,它可以作为风力涡轮机工作,而在水平平面上,它可以作为太阳伞。HAADS表示,这个系统可以从55个VAWTAU模块中获得25千瓦的能量。
the rotating system utilizes dynamic positioning (DP), which is a computer-controlled system to automatically maintain a ship’s position. with their goal of designing a project with ‘ecological balance’, the design team at HAADS integrates a system of green energy production called VAWTAU, vertical axis wind turbine and umbrella. on the vertical plane, this works as a wind turbine, while on the horizontal plane it serves as a sun umbrella. HAADS says that this system can obtain 25 kW of energy from each of the 55 VAWTAU modules.
除了产生绿色能源外,酒店还结合了雨水收集。"涡流启发 "的屋顶收集的雨水经过处理后可作为灰水使用或浇灌酒店的绿色区域。
净化海水后可获得清洁的水,而废水则会经过处理,以避免对环境造成损害。HAADS还计划开发垃圾分类装置,将厨余转化为园林绿化的肥料。
客人可以乘车、乘船或乘坐直升机和无人机前往位于浮动码头的直升机停机坪.酒店拥有700平方米的巨大大堂,152间客房都有自己的阳台,随着建筑的旋转,为客人提供不同的视角.该项目还包括室内和室外游泳池、桑拿、水疗、健身房和迷你高尔夫球场。
酒店的所有平台,包括连接大陆的平台,都是浮动平台。凭借这一移动设计,HAADS计划将酒店移动到不同的地区。第一站,酒店计划驻扎在卡塔尔的沿海水域。
all of the hotel’s platforms, including the connection to the mainland, are floating platforms. with this mobile aspect of the design, HAADS plans to move the hotel to different areas. for its first leg, the hotel is planned to be stationed in the coastal waters of qatar.
在最初的概念过程之后,HAADS告诉我们,下一阶段是继续进行可行性和技术研究,以实现实施阶段。虽然这些工程没有确切的完工日期,但多学科团队的目标是2025年。
整体分析图
建筑师:Hayri Atak建筑设计工作室
地点:阿拉伯卡塔尔
面积:35,000平方米
年份:2025
公共建筑设计
返回版块51.18 万条内容 · 448 人订阅
韶关龙归粮所改造倪阳工作室收录于话题 从主入口往里面望 ?战长恒 龙归镇位于广东省韶关市,镇内有多家粮食加工厂,龙归粮所便为其一。1949年后,粮所陆续经历了公私合营制度的实行对象,改造成过干部“上山下乡”接受再教育的学校,最后作为对外出租给私人进行粮食加工的场所。随着时代变迁,龙归粮所也逐渐闲置废弃,但园区内的基本格局依然保留了下来。 ? 战长恒
