土木在线论坛 \ 园林景观 \ 景观规划设计 \ 飘幻光影KlinMaiHom展览空间
飘幻光影KlinMaiHom展览空间
发布于:2021-03-02 16:33:02 来自:园林景观/景观规划设计 [复制转发]
这个270平方米的围合式花园是利用临时结构插入到原有树木散落的场地环境中建立起来的。 通过依托场地而生,结构也作为项目空间的一部分, 随机摆放的柱子支撑着天花板,与树干在垂直方向上相互配合。
The 270 square meter enclosed garden area is builted by using temporary structures to be inserted into the existing site context where the original trees are scattered. By relying on the land as part of a new garden and being part of the structural work by itself.  The ramdom position of column run follow the ceiling for support together with tree trunk playing with vertical line of garden.
天花板的设计采用半透明的聚碳酸酯板,使光线和空气能够通过,也能在内部空间形成空气流动,因此树木可以正常生长。但同时,吊顶板材将反射的光线带到半透明材料上,在不同的时间营造出不同的气氛。水平线的阴影映射在园林的肌理和硬质景观上,使光影的重复模式,使参观这个花园的人有多种不同的体验。
The ceiling is designed to use a translucent polycarbonate sheet to  be airy flow that allows light and air to pass through. So the tree can grow normally. But at the same time, the ceiling sheet bring the reflected light to the translucent material to create an atmosphere in the area at various times. Horizontal line shading mapping on garden texture and hardscape for make a repetitions pattern of light and shadow make a variety and different experience for people who visit this garden.
我们设计在前面设置暗室亭子,将花园隐藏在后面,使这个区域有一个连续的流线。这个暗区尽可能的减少了室内的光线。
We design to put dark room pavilion in the front for hiding the garden behind and make a circulation sequent for this area.  This dark area was decrease light as much as possible inside.
从入口处看,画面和光线对比明显。为了创造一种走进花园的步行体验,设计师在入口大厅创造一个进入主要区域,在这个空间里将会有一个艺术家展览的临时展览。
Both the image and the light contrast clearly from the entrance, which was designed to be a dark room with limited visibility. To create a walking experience when walking into the garden and creating an order to access the main area in the entrance hall, there will be a temporary exhibition from the artist show in this space.
景观规划设计
25.18 万条内容 · 282 人订阅
景观设计的骨架——道路
一个成熟的景观设计一定有成功的路径设计。 那么要怎么做到科学而美观地设计道路呢? 首先我们要了解人的步行规律以及如何处理视觉关系。例如: 「不经意地」行走
