土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ “螺旋形”的教育建筑
“螺旋形”的教育建筑
发布于:2021-03-01 11:39:01 来自:建筑设计/公共建筑设计 [复制转发]
在曼谷郊区,plan architect完成了一座名为“肯辛顿学习空间”的教育建筑。螺旋形体量的设计使每个空间都受益于自然光线和绿色庭院的视野。
in a suburban area of bangkok, plan architect has completed an educational building called ‘the kensington learning space’. housing both classrooms and a sports complex, the spiral-shaped mass is designed so that each and every space benefits from natural light and views onto a green courtyard.
由于其 "不那么有趣 "的郊区位置,Plan architect决心赋予学习空间自己的氛围,这一点通过引人注目的建筑来实现。"为每个房间提供自然光和景观的概念推动了最初的设计过程。
从立方体的盒子到线性的体量,设计团队最终落脚在一个螺旋形的建筑上,这个建筑有一个中央庭院,每个房间的两边都有窗户。
with its ‘not-so-interesting’ suburban location, plan architect resolved to give the learning space its own atmosphere, which is achieved by the striking architecture. the concept of providing each room with natural light and views drove the initial design process. from a cube-like box to a linear volume, the design team finally landed on a spiral-shaped building with a central courtyard, which allows windows on both sides of each room.
螺旋形向建筑前部扩展,以容纳体育综合区。这些更大的空间包括游泳池和一个巨大的没有柱子健身房,供孩子们自由玩耍。
螺旋结构的狭窄部分位于场地的后方,其中包含了教室。在这里,孩子们更接近大自然,让他们在树林中学习。
the spiral grows thicker toward the front of the building to house the sports complex zone. these bigger spaces contain the swimming pools and a huge column-free gym for the kids to play freely. the narrow part of the spiral is situated toward the rear of the site and it contains the classrooms. here, the children are brought closer to nature, allowing them to learn among the trees.
建筑的亮点必须是屋顶花园,孩子们可以从绕着庭院慢慢旋转的坡道进入屋顶花园。从学习到玩耍和发现自然,肯辛顿学习空间包括了这一切。
the highlight of the building has to be the roof garden, which kids can access from the ramp that slowly spirals around the courtyard. from learning to playing and discovering nature, the kensington learning space encompasses it all.
设计分析图
结构分析图
建筑师:计划建筑事务所
地点:泰国曼谷
公共建筑设计
51.18 万条内容 · 448 人订阅
迪拜新地标——170米“搞怪”的摩天大楼!!两个灵魂,走到一起?
来源:搜建筑(ID:sjz9999) 以色列艺术家zygo和他的创意团队一起计划建造有史以来较大的艺术作品——晾衣杆塔。该设计设想在阿联酋迪拜建造一栋高度为170米的摩天大楼,极具雕塑感和象征意义。 这个独特的项目计划于2023年开始建设,目前正在寻找战略合作伙伴,以确保土地和施工权等。 israeli artist zygo, together with his creative team, plans to build the largest piece of art ever created – the clothespin tower. the design imagines a highly sculptural and symbolic 170m-tall skyscraper in dubai, UAE. it turns the common peg into a new dimension that soars up into the city’s skyline. aiming to start construction in 2023, the unique project is currently looking for strategic partners for securing land, construction rights and more.
