土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 日本小高层“砖瓦”住宅
日本小高层“砖瓦”住宅
发布于:2021-02-08 13:43:08 来自:建筑设计/居住建筑设计 [复制转发]
这座公寓大楼位于东京市中心,许多写字楼和公寓大楼交错地靠在一起。
This apartment building is located in heart of Tokyo, where many office buildings and apartment buildings are jumbled up close together.
它需要特别的设计,以保持适当的距离。在东京,大多数公寓都有水平的连续开放式阳台。必须为阳光和通风提供足够的空间。
It would need special arrangements to keep moderate distance from neighborhood. In Tokyo, most apartments have continuous and opened balconies horizontally. It is necessary to provide an adequate aperture for sunlight and ventilation.
在高密度的生活区中,室内外的关系是通过窗帘来切换的,就像“开/关”一样。窗帘表示存在或不存在。
In high-density living area, the relationship between the inside and outside are switched by a curtain, like "on / off" . Then curtains express presence or absence.
然而,这座城市的大多数窗帘都是拉着的。在城市中提供缝隙的矛盾,通过在阳台上使用砖墙来解决。
However, most curtains are kept closed in the city. The contradiction of providing an aperture in the city, was solved by using a brick screen at balconies.
此外,多孔屏风非常适合在炎热潮湿环境中使用,以提供舒适居住环境。
Moreover, porous screen is fine example of comfortable living in hot and humid environment.
这些砖挡住视线,但提供阳光、通风和烟气。所以需要宽的宽度。因此,位于著名的砖生产区的濑户工厂定制了这些砖。
Those bricks intercept line of sight, but supply sunlight, ventilation and flue gas. So wide width are needed. Therefore, the Seto factory that is in famous production area for bricks made Those bricks to order.
在大多数公寓中,每个楼层的居住单元都是一样的,这是出于经济的考虑。在该公寓中,屏幕的位置在奇数层和偶数层交替切换。住宅单元变化多样,用少许的安排打造出美丽的立面。
In most apartment, dwelling units are same on each floor because of the economic principle. In this apartment the position of screen are switched alternately on the odd floors and even floors. The dwelling unit changes diversify and makes beautiful facade with a little arrangement.
设计理念图
温度分析图
平面图
立面图
剖面图
砖块细部图
建筑师:KINO建筑事务所
地点:日本东京
年份:2014
  • 加倍努力
    加倍努力 沙发
    学习了砖结构建筑的设计理念,多谢了。
    2021-04-07 09:06:07
  • s9201109
    s9201109 板凳
    我想知道这个砖是什么砖?
    2021-04-02 15:27:02
居住建筑设计
28.74 万条内容 · 423 人订阅
希腊,米洛斯岛,HourglassCorralDECAArchitecture
凭借其Hourglass Corral,DECA Architecture完成了希腊米洛斯岛上一系列住宅中最新的部分。该项目是由其场地固有的自然条件塑造而成的,旨在引起人们对当地传统和著名景观的敏感和持续关注。阳光普照,在海风的吹拂下,令人印象深刻的建筑作品沉入了地平面以下。这座住宅有四间朝南的卧室,构成了Voronoi’s Corrals住宅的一部分,这是建筑师们在过去十年里设计的一个更大的区域。该项目以绿色屋顶为背景,旨在创造建筑与自然、逻辑几何和有机荒野之间的对话。
