土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 一变二,二合一,一个遮风避雨的筑舍Robot3Studio
发布于:2021-02-03 14:57:03 来自:建筑设计/居住建筑设计 [复制转发]
  感谢 Robot 3 Studio 的分享
△ 建筑外观 ?Robot3 Studio
 依山筑舍
Paper airplane
△ 远眺建筑 ?Robot3 Studio
项目位于北京怀柔沙峪口村,依山筑山庄,依山筑的名字取自苏轼的诗句,依山筑阁见平川,夜阑箕斗插屋椽。
The project is located in Beijing Huairou Sha yukou village , Yishanzhu B&B Resort. Its name is from the poem of Su Shi:The Songfeng Pavilion is built amidst beautiful mountains. It is backed by green mountains and overlooks the boundless plains. Whenever the night is quiet, the Northern Star and comet seem to be stuck on the eaves.
△航拍 建筑外观 ?Robot3 Studio
这个小房子是建在一片果林的山坡上,用途是为游人在山上提供一处休息的地方,师傅们在做果木维护时也可在此落脚歇息。
This hut was built on a hillside with fruit trees.It is used to provide visitors with place to take a break when climbing the mountain, and also for workers who maintain fruit trees.
△三角形的 建筑外观 ?Robot3 Studio
建造的目的是为提供一处遮风避雨的场所,所以只要考虑对环境的影响减少到最小,同时方便建造就好。为节省成本,房子的顶和墙融为一体,防水油毡整体包裹,所以才有这个灰黑色三角形体的基本框架。空间上两个三角体块叠加形成的梯形平面既可以满足使用功能,又可以让场地尽量缩小。入口在一棵过百年的柿子树下,透视的缘故,立面上单从一个方向看去是绝不会想到另外一面的样子,一变二,二合一。侧面窗口方形,朝向东南,正面西南向的三角形大窗面朝远方。对周边环境的影响要减少到最小,所以把整个房子抬了起来,地面的植被可以恢复,同时来到屋子里更有登高望远的视野。
Because the main purpose of building this hut is to provide a shelter from wind and rain, the only thing to consider is to minimize the impact on the environment and facilitate construction.The top surface of the hut is embedded into the wall and is wrapped by waterproof linoleum to form the basic gray-black triangle frame. The trapezoidal plane formed by the superposition of two triangular blocks in space can not only satisfy the use function, but also narrow the required area.Under a hundred-year-old persimmon tree there is the entrance. Looking at it from one direction, you will never imagine the other side. The side window is square and faces southeast. To the southwest there is a large triangular window on the front. In order to minimize the impact on the environment, the entire house was elevated a bit, and the vegetation on the ground can be replanted as before. In the house, you can also have a farther and higher vision.
每到黄昏时眺望,夕阳的余晖逐渐褪色,远方薄雾弥漫,这里总能显露出北方苍茫万顷的辽阔,身处林中,百草丰茂,疏逸一时,如果用一首曲子来形容,我的脑海里总能浮现出东邪西毒的电影插曲。
When viewing at dusk, the vast expanse of the north can always be revealed here. In the forest, there is lush grass. If I have to come up with an idea for the design of this house, I will say I always think of the soundtrack of the movie Ashes of Time when I see this view.
△树林中的建筑  ?Robot3 Studio
所有事物的进程都是线性的,时间就是刻度,无法逆转。世界的组成就是无数条进程的叠加,世间相遇的一刻,一个瞬间的截取,这一刻只可在记忆中停留,在形式中凝结。
All things in the whole process move linearly. The scale is time of this line and cannot be reversed. The composition of the world is the superposition of countless processes. At the moment of encounter, a momentary interception can only stay in memory and solidify in form.
逝者如斯,不舍昼夜。
The passage of time is just like the flow of water, which goes on day and night.
△夕阳下的建筑  ?Robot3 Studio
△ 建筑细节?Robot3 Studio
△夕阳下的 建筑?Robot3 Studio
 技术图纸
DRAWINGS
△ 建筑模型?Robot3 Studio
△ 平面图?Robot3 Studio
△ 立面图?Robot3 Studio
△ 手绘建筑?Robot3 Studio
△ 轴测图?Robot3 Studio
设计机构:Robot3 Studio
建筑设计:潘飞、韩冬
项目地址:北京市怀柔区沙峪口村
业主:北京依山筑文旅度假区
项目类型:住宅建筑
建筑面积:16平米
施工单位:北京汇嘉建润建筑装饰工程有限公司
材料:金属方管、木板、玻璃
设计时间:2020.5-2020.8
建成时间:2020.10
摄影:Robot3 Studio
Architect:Robot3 Studio
Design Team: Pan Fei,Han Dong,
Project Type:Residential building
Building Area: 16 sqm
Building Material: Steel tube,Plank,Glass
Design Period:2020.5-2020.8
Completion: 2020.10
Photographer:Robot3 Studio
居住建筑设计
28.74 万条内容 · 423 人订阅
美国影子山屋,将山色引入室内
收录于话题 建筑观,观世界。 每日优选全球最新作品,推荐关注。 项目位于阿斯彭市区的边缘,是一座充满挑战性的家庭住宅,垂直的住宅结构可以捕捉到远处山腰高耸的树梢风景。 三层的住宅包含4672英尺的空间,生活区位于上层和屋顶,卧室位于下层。 创造了一个“形式跟随功能”的聚会场所,采用大孔径风格的落地窗,直接面向主要景观。
