土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 竹制幼儿园——另一种美!!
竹制幼儿园——另一种美!!
发布于:2021-01-28 13:28:28 来自:建筑设计/公共建筑设计 [复制转发]
这座建筑是儿时对教室应该有的幻想。它由一根中央竹篮般的柱子支撑着,中间有一个天窗。这座建筑没有墙壁,"门 "是一个竹制的拱门,作为班级与外界的门槛。
This building is a childhood fantasy of what a classroom should look like. It is supported by a central bamboo basket-like column with a skylight in the center. The building has no walls and the ‘door’ is a bamboo arch that acts as a threshold between the class and the outside world.
'绿色学校的特点,尤其是在幼儿园,你不会经常让所有的学生排排坐看着老师。所以要在中间有一个塔,有一个圆形的空间,这真的很有效。
他们有一个小的储物角,他们还有一个游戏角,他们用不同的方式来使用这个空间。IBUKU'S创始人兼创意总监Elora hardy说:"这个经典、简单的空间仍然鼓舞着我们。
'The thing about Green School, especially in Kindergarten, is that you don't often have all the students sitting in rows looking at the teacher. So to have a tower in the middle, and having a circular space, it really works. They have a little storage corner, they have another play corner, they use the space in different ways. This classic, simple space still inspires us' says Elora hardy, IBUKU'S Founder & Creative Director.
建筑物的总体概念围绕着它的屋顶展开,屋顶在其周边降低到大约1米-1.5米的高度,以避免在上课时间分散注意力。中央天窗通过释放上面的光线来实现这一操作。
The general concept of the building revolves around its roof, which lowers to approx 1m - 1.5m height in its perimeter to avoid distractions during school hours. The central skylight allows this operation, by releasing the passage of light from above.
屋顶下的开放空间通过一系列的游戏站来限定,此外还有不同类型的家具,可以适应不同的活动。
该结构放置在泥浆和混凝土的混合表面上,由于其使用率高,更容易维护。外表面已被沙子覆盖,以便安全自由地进行游戏。
The open space under the roof is qualified through a series of play stations, in addition to different types of furniture that can be adapted to different activities. The structure is placed on a mixed surface of mud and concrete, which is easier to maintain due to its high use. The outer surfaces have been covered with sand, to allow the game safely and freely.
约翰-哈迪邀请约尔格-施塔姆带来他的德国结构木工技能和他在传统哥伦比亚竹子建筑方面的经验来帮助实现设计。
"这座建筑所使用的创新竹塔最初是在弗雷-奥托的一本关于竹子在轻质结构中的潜力的书中提出的,"斯塔姆说。
John Hardy invited J?rg Stamm to bring his German structural carpentry skills and his experience with traditional Columbian bamboo construction to help realize the designs. "The innovative bamboo tower used in this building was initially proposed in a book of Frei Otto about the potential of bamboo in light weight structures," says Stamm.
区位图
立面图
剖面图
设计单位:IBUKU
地点:印尼
建筑面积:155 m2
建筑年份:2008
  • lijiawei411
    lijiawei411 沙发
    2021-02-04 14:26:04
公共建筑设计
51.18 万条内容 · 448 人订阅
SOM为旧金山打造全景滨海住宅——令人耳目一新
以下文章来源于:SOMChina 源于这里多元文化和各具特色的建筑风格,旧金山一直被誉为全美“最具多元文化氛围”的国际化大都市。 由 SOM 负责建筑与室内空间设计的“斯图尔特大道一号”(One Steuart Lane)住宅大楼位于旧金山的“英巴卡德罗”(Embarcadero)滨海城区。
