土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 独特“树状”结构——高层办公楼
独特“树状”结构——高层办公楼
发布于:2021-01-26 16:26:26 来自:建筑设计/公共建筑设计 [复制转发]
从交通便利性和能见度来看,该地块是芝加哥最好的写字楼位置之一,如果不是因为其梯形的形状,该地块早在很多年前就已经被开发了。
由于东西两边的房产线并不平行,要适合典型的甲级写字楼板块,包括中心核心区和理想的租赁跨度,是一个挑战。
此外,对于任何沿河的场地,城市要求有一条30英尺宽的公共河道,使场地更加复杂。该设计通过一个不寻常的阶梯式中心核心来解决这些挑战,允许每边有45英尺的租赁跨度。
为了避免倾斜的周边,西墙有一系列30英尺宽、5英尺的后退,在整个建筑中容纳一个正交的、5英尺的规划模块。
Offering one of the best office building locations in Chicago in terms of accessibility and visibility, this site would have been developed many years ago if not for its trapezoidal shape. Given that the east and west property lines are not parallel, fitting a typical Class A office floor plate, including the center core and desired lease spans, is a challenge. In addition, for any site along the river, the city requires a 30-foot-wide publicly accessible riverwalk, further complicating the site. The design addresses the challenges with an unusual stepped center core, which allows for a 45-foot lease span on each side. To avoid an angled perimeter, the west wall has a series of 30-foot-wide, five-foot setbacks, accommodating an orthogonal, five-foot planning module throughout the building.
地面平面图
这座先进的甲级写字楼共56层,面积达177万平方英尺。内部空间规划因沿河5英尺的后退而得到加强,提供了相当于14个角落的办公室。
后退创造了一种独特的形式,突出了建筑的垂直度,避免了典型写字楼的纯箱体外观。为了满足城市的要求,该设计提供了一个45英尺宽的河道,河道被覆盖,但实际上是向天空开放的,在62英尺以上。
三个间隔90英尺的 大型树状结构元素 将塔柱沿河转移出去,并进一步开放场地。
The state-of-the-art Class A office tower totals 56 stories and 1,770,000 square feet. Interior space planning is enhanced by the five-foot setbacks along the river, providing the equivalent of 14 corner offices. The setbacks create a distinctive form that accentuates the building’s verticality and avoids the pure box-like appearance of typical office towers. To satisfy the city’s requirements, the design provides a 45-foot-wide riverwalk that is covered, but effectively open to the sky, 62 feet above. Three large, tree-like structural elements spaced 90 feet apart transfer out the tower columns along the river and further open the site.
标准层平面图
结果是一个景观的、有盖的步行道,连接了两条非常重要的人行道,并保持了有效的无遮挡的河景。
结合其他空间,该地块有50%的空间是开放的,并可在地面上向公众开放。在Wacker Drive一侧,一个45英尺高的大厅由电缆支撑的玻璃墙围住,雕刻的折叠式石灰石覆层覆盖了电梯核心。
低铁玻璃墙的透明性几乎消除了室内外空间的区别,大堂与街景融为一体。
The result is a landscaped, covered walkway that connects two very important pedestrian paths and maintains an effectively unobstructed river view. In combination with other space, the site is 50% open and publicly accessible at grade. On the Wacker Drive side, a 45-foot-high lobby is enclosed by a cable-supported glass wall, and sculpted, folded-limestone cladding covers the elevator cores. The transparency of the low-iron glass wall virtually eliminates the distinction between interior and exterior space, with the lobby and streetscape becoming one.
区位图
平面设计草图
西立面图
南立面图
南北向剖面图
东西向立面图
设计单位:Goettsch合伙人事务所
地点:芝加哥
建筑面积:1700000平方英尺
建筑年份:2020
公共建筑设计
51.18 万条内容 · 448 人订阅
一个“蜿蜒”结构,无定形的形状的——摩天大楼
hayri atak建筑设计工作室为曼哈顿的天际线设想了一座引人注目的摩天大楼,其无定形的形状和材料特性使其在邻近的建筑中脱颖而出。 虽然在规模和比例上可以比较,“sarcostyle tower”与它的背景明显不同。 与一些静态的、几何形状的建筑不同,该建筑受到生物概念的启发,包括解剖学和细胞,这使该项目在密集的城市景观中具有有机的观感。 hayri atak architectural design studio has envisioned a striking skyscraper for the manhattan skyline, whose amorphous shape and material properties make it stand out among the neighboring buildings. while comparable in terms of scale and proportion, ‘sarcostyle tower’ is distinctly different from its context. unlike some of its static, geometrically formed neighbors, the building is inspired by biological concepts, including anatomy and cells, which lend the project an organic sensibility within the dense cityscape.
