土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 酒店立面——11层高的设计方案
酒店立面——11层高的设计方案
发布于:2021-01-26 15:48:26 来自:建筑设计/居住建筑设计 [复制转发]
由FCBStudios设计的英国新皮卡迪利酒店已获得曼彻斯特市议会的规划批准。
该酒店为Pestana的Cristiano Ronaldo CR7品牌设计,位于Piccadilly和Newton街的拐角处,设有休息室酒吧和屋顶露台。
该方案重新利用了一栋二级建筑,并新建了一座11层楼高的建筑,作为通往北区和市中心的门户。
The new Piccadilly Hotel in the United Kingdom by FCBStudios has received planning approval from the Manchester City Council. Designed for Pestana’s Cristiano Ronaldo CR7 brand, the hotel is sited at the corner of Piccadilly and Newton Street with a lounge bar and rooftop terrace. The scheme reuses a Grade II listed building with an 11-story new build to mark the gateway to the Northern Quarter and city center.
新酒店将包括超过150间客房,并将对列入二级名录的皮卡迪利69-75号酒店进行翻新,该酒店是一座19世纪的办公和仓库式综合建筑,被称为哈尔斯大厦。
位于该建筑底层的Piccadilly酒馆也将作为项目的一部分进行翻新。
正如团队解释的那样,该地块位于史蒂文森广场保护区内,位于曼彻斯特北区的入口处。
该方案旨在通过材料、色彩和外立面比例的设计,参考保护区的独特特征,重新设计了这个建筑。
The new hotel will include over 150 rooms and feature the refurbishment of the Grade II listed 69-75 Piccadilly, a former 19th Century combined office and warehouse building known as the Halls Building. The Piccadilly Tavern, which occupies the ground floor of the listed building, will also be refurbished as part of the project. As the team explains, the site is located within the Stevenson Square Conservation Area at the entry point into Manchester’s Northern Quarter. The proposal seeks to re-engage this corner with a design that references the unique character of the Conservation Area through materiality, color and facade proportions.
FCBStudios合伙人Simon Doody说:"该地块早就应该重新开发,而且位置突出,需要一个强有力的建筑形象。
围绕建筑的拱形拱门真实地体现了酒店简介的重复性,形成了一个符合情境的优雅立面设计。这为酒店和皮卡迪利地区的改造奠定了基调。"
Simon Doody, Partner, FCBStudios said “The corner site is long overdue for redevelopment and in a prominent position that requires a strong architectural presence. The vaulted archways wrapping around the building offer an honest representation of the repetitive nature of the hotel brief, resulting in a contextual and elegant fa?ade design. This sets the tone for the 4* hotel and transformation of the Piccadilly area.”
设计单位:FCBStudios
地点:英国
居住建筑设计
28.74 万条内容 · 423 人订阅
2.7米宽,17米长,日本建筑师设计最狭长住宅
因为宅基地宽4米,深35米,建筑师将住宅设计为2.7米宽,17米长的范围内,通过一条狭长的走廊将各个功能房间联系在一起。尽管空间局促,通过局部挑空的设计及巧妙的开窗方式,营造了一个充满趣味的室内环境。 房屋主人是年轻夫妇和他们的孩子,设计充分考虑了居住者家庭的成员结构,即满足了公共空间需求,也在端头设计了私密的房间。这座住宅的设计体现了简单有趣的现代日本建筑理念。
