土木在线论坛 \ 施工技术 \ 建筑施工 \ 世界一流边坡计算软件Slide v5.014破解版
发布于:2008-03-07 12:47:07 来自:施工技术/建筑施工 [复制转发]
世界一流边坡稳定计算软件 Rocscience Slide v5.014 破解版 下载
官方介绍:
Slide 5.0 is the most comprehensive slope stability analysis software available, complete with sensitivity, probabilistic and back analysis capabilities. This 2-D program combines an attractive, easy to use CAD based graphical interface with a wide range of modeling and data interpretation options that enable you to perform analyses more thoroughly, more quickly.
Using Slide 5.0, you may determine the probability of failure and reliability index for either the deterministic failure surface with the smallest factor of safety, or for the entire slope. Sensitivity capabilities allow you to easily determine the effect of any parameter on the factor of safety. Determine which parameter has the most effect and optimize your slope remediation based on this knowledge.
Slide 5.0 is the only slope stability software to include built-in steady-state unsaturated groundwater analysis capabilities using the finite-element method. Calculate pore-pressures, heads, discharge using geometry from your slope stability analysis. Meshing is all automatic and done at the click of a button. Pore pressures are seamlessly integrated into your slope stability analysis.
Slide 5.0 easily models complex slope geometry. Draw the interface as you would in any CAD or drawing program or import a scanned image of your slope and digitize over it. Man-made and natural slopes with complex layering, soil lenses, and inclusions are easily modeled. Earth dams with complex core and shell geometries are also easily modeled.
The simple to use editing tools provide a convenient method for performing parametric studies. The graphical data interpreter provides a rich set of tools for the convenient display of model results. With Slide 5.0, you can very quickly and easily create a model, perform a stability analysis, and interpret the results.
安装文件及破解文件太大,30多兆,无法上传,给个我从网上找到的下载地址。
下载地址:
http://www.bbsyantu.cn/viewthread.php?tid=58
整合版 官方使用手册 下载地址:
http://www.bbsyantu.cn/viewthread.php?tid=59
[ 本帖最后由 keery666 于 2009-1-12 03:47 编辑 ]
全部回复(41 )
  • freeanycall
    freeanycall 沙发
    楼主,好像现在网页链接失效了 啊。
    2011-09-25 08:43:25
  • zengle2011
    zengle2011 板凳
    好东西啊!我真的好喜欢啊!!
    2011-08-18 20:19:18
建筑施工
66.04 万条内容 · 1650 人订阅
独立基础之间的联系地梁(拉梁)需要做垫层吗?
独立基础之间的联系地梁(拉梁)需要做垫层吗?是否有地梁悬空这种情况,即地梁的底面没有和土接触?
